电子发烧友论坛扫一扫,分享给好友
嗨,我必须将testexec日志文件处理到其他数据库。
使用tesetexec,我可以创建xml日志文件。 有没有办法在同一个测试计划中开始处理日期? 我想构建一个动作,获取创建的日志文件的路径和文件名。 logdirectory的路径在选项中设置,没问题。 xml文件的名称是somhow ****代码。 它是否在tesexec中可用? 是否有机会添加数据处理步骤,结果数据存储在日志文件中后会执行? 或者甚至可以在存储之前通过动作访问完整的结果字符串/对象? 顺便说一下:我在helpfile中找到了建议,通过修改用户界面来实现这一点。 由于我们通过第三方应用程序启动testpan,因此我们无法通过commanline参数传递用户界面。 亲切的问候Andreas 以上来自于谷歌翻译 以下为原文 Hi I have to process testexec logfiles into an other database. With the tesetexec I'm able to create xml logfiles. Is there a way to start processing date within the same testplan, where they are build? I would like to build an action which get the path and filename of the created logfile. The path of the logdirectory is set in the option, no problem. The name of the xml file is somhow a **** code. Is it somewhere available within the tesexec ? Is ther a chance to add a dataprocessing step, wich will be executed after the resultdata is stored in the logfile? Or even can I access the full resultstring/object by an action, before it will be stored? By the way: I have found the suggestion in the helpfile, doing this by modifing the userinterface. Since we start the testpan by a thirdpatrty application, we can not pass a userinterface by commanline parameter. Kind regards Andreas |
1个回答
嗨Andreas_h,xml日志文件的文件名包括Year(4位),Month(2),Day(2),Minute(2),Second(2),Milisecond(3),ProcessId(参见任务管理器)Is
这些信息有助于您生成动作吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi Andreas_h, The file name of xml log file consist of Year (4 digit), Month (2), Day (2), Minute (2), Second (2), Milisecond (3), ProcessId (see task manager) Is this information helpful for you to generate the action? Thanks. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 21:49 , Processed in 1.103523 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4080
