电子发烧友论坛|
突然间,我有一个问题,我的代码花了很长的时间来开始构建阶段。一切都编译得很好,但在我选择生产运行或调试MPLAB只是坐。在输出日志中的最后几行是许可类型:节点配置::警告:(1273)在自由模式中不可用的全知代码生成。在状态行中看到小绿色条向下闪烁,但是在输出日志中没有更新几分钟。P将在几秒钟内编程。这个程序很小。只是几行。我不明白为什么要花这么长时间才开始建造。我在4.01中有这个问题,所以我刚刚更新到V4.05,但是我仍然有同样的问题。
以上来自于百度翻译 以下为原文 All of a sudden I am having a issue with my code taking a long time to start the build phase. Everything compiles just fine but after I select Production Run or Debug MPLab just sits. there. The last couple of lines in Output log are License type: Node Configuration :: warning: (1273) Omniscient Code Generation not available in Free mode I see the little green bar down in the status line flashing but nothing gets updated in the Output log for several minutes. Once it is built the chip will program in seconds. The program is tiny. Just a few lines. I can't see why it would take so long to start to build. I was having this issue in 4.01 so I just updated to v4.05 but I am still having the same issue. |
5个回答
如果删除/断开LAN/Internet连接,这会继续发生吗?
以上来自于百度翻译 以下为原文 Does this continue to happen if you remove/disconnect the LAN/Internet connection ? |
我不确定我理解你的问题。你的意思是把电脑和互联网断开?
以上来自于百度翻译 以下为原文 I am not sure I understand your question. Do you mean disconnect the PC from the internet? |
是的,将它与任何网络断开连接,即拔出以太网电缆或关闭WiFi。
以上来自于百度翻译 以下为原文 Yes, disconnect it from any networking at all. i.e. pull out the ethernet cable or turn off wifi. |
是的(正如QHB所说),断开PC将有助于你确定“某物”是否试图访问互联网/LAN减速。如果你发现这加速了进程,你可以看看是什么导致了减速。
以上来自于百度翻译 以下为原文 Yes ( as qhb says ), disconnecting the PC will help you determine if "something" is trying to access the internet/lan slowing things down. Should you find this speeds up the process you can look into what is causing the slowdown. |
也可能是病毒扫描器在创建文件后扫描输出文件,然后才开始编程。
以上来自于百度翻译 以下为原文 It may also be your virus scanner scanning the output file after it is created, before programming begins. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 07:10 , Processed in 0.648685 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2594
