你好
我需要在不在网络上的远程PC上运行SDK。 我需要这台机器的许可证吗? 我将在网络上的机器上进行所有构建,但是我必须在未连接网络的PC上编程硬件。 我有一个节点锁定许可证但我不能使用它,因为它需要访问网络来验证它。 有什么建议吗? 皮特 以上来自于谷歌翻译 以下为原文 Hi I need to run the SDK on a remote PC that isn't on the network. Do I need a license for this machine? I will do all the builds on a machine that is on the network but I have to programme the hardware on a PC that isn't connected the network. I have a node locked licence but I can't use this as it needs to access the network to validate it. Any suggestion please? Pete |
2个回答
嗨@ pcaddick,
是的,您需要运行SDK的许可证。 如果您只想对硬件进行编程,可以使用不需要许可证的实验室工具(http://www.xilinx.com/support/download.html)。 您的节点锁定许可证是否基于证书(即它是否具有.lic扩展名)?如果是,请从连接到网络的计算机为您的计算机生成它,将其带到您的计算机并将其加载到许可证管理器(VLM或 XLCM) 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @pcaddick, Yes you need a license for running SDK. If you want to only programme the hardware, you can go for lab tools(http://www.xilinx.com/support/download.html), which do not require a license. Is your node-locked license certificate-based(i.e. does it have a .lic extension)? If yes, generate it for your machine from a machine connected to network, bring it to your machine and load it in the License Manager(VLM or XLCM) Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嗨,我设法获得SDK许可。
我不得不将PC带到有互联网的地方。 以上来自于谷歌翻译 以下为原文 Hi, I managed to get the SDK licensed. I had to take the PC to a place that had the internet. |
只有小组成员才能发言,加入小组>>
2209 浏览 7 评论
2633 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2110 浏览 9 评论
3179 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2235 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
479浏览 1评论
1560浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2207浏览 0评论
532浏览 0评论
1691浏览 0评论
GMT+8, 2024-6-18 20:33 , Processed in 1.678141 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
