电子发烧友论坛扫一扫,分享给好友
我已经为我的新ZC706评估套件下载并安装了节点锁定许可证。
一切都在许可证管理器中正确显示。 但是当我尝试在vivado 2016.2内的新项目中选择电路板时,只有Zedboard,AC701和ZC702可用。 如何让vivado识别我新安装的许可证? 以上来自于谷歌翻译 以下为原文 I have downloaded and installed the node-locked license for my new ZC706 Eval Kit. Everything shows correctly in the license manager. But when I try to select the board in a new project inside vivado 2016.2, only the Zedboard, the AC701, and the ZC702 are available. How can I get vivado to recognize my newly installed license? |
5个回答
Hijohn@ontargetenterprises.com,
您似乎已经安装了webpack,因为您可以访问AC701和ZC702。 请安装该工具的其他版本以访问ZC706。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi john@ontargetenterprises.com, It seems you have installed webpack as you are able to access AC701 and ZC702. Please install other edition of the tool to access ZC706. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
你安装了Vivado的webpack版本吗?
webpack不支持这些板,并且工具错误地显示消息传递以通知此情况。 您可以忽略这些消息。 要解决此问题,请使用完整版Vivado(设计或系统版本)重新安装工具,并在那里使用webpack许可证。 消息不会出现。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Did you install webpack edition of Vivado? These boards are not supported in webpack and the tools are incorrectly displaying the messaging to inform of this. You can ignore these messages. To workaround the issue reinstall the tools with the full version of Vivado (design or system edition) and use the webpack license there. The messages will not appear.Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
您似乎已经安装了webpack,因为您可以访问AC701和ZC702。 请安装该工具的其他版本以访问ZC706。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi john@ontargetenterprises.com, It seems you have installed webpack as you are able to access AC701 and ZC702. Please install other edition of the tool to access ZC706. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
谢谢。
这解决了问题。 我如何“接受解决方案”? 以上来自于谷歌翻译 以下为原文 Thanks. That fixed the problem. How do I "Accept as solution"? |
没关系。
当我尝试发送上一个回复时,会弹出“接受”按钮 以上来自于谷歌翻译 以下为原文 Never mind. When I tried to send the previous reply the Accept button popped up |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 08:19 , Processed in 0.937075 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5220
