电子发烧友论坛|
任何人都可以指出任何关于非标准(即:不等于50 +/- j0)负载的影响的学术文章及其对矢量网络分析仪的校准过程的影响吗?
非标准负载如何使得到的校准结果偏斜。 我知道如果你通过与信号流图相关的数学,可以确定结果,但是我现在不能解决这些方程式,并且想知道是否有人写过一篇或两篇描述效果的论文。 问候,卡琳 以上来自于谷歌翻译 以下为原文 Can anyone point me to any scholarly articles on the effect of a non-standard (ie: not equal to 50+/-j0) load and its effects on the resulting calibration process for vector network analyzers? How does a non-standard load skew the resulting calibration results. I know if you go thru the math related to the signal flow graphs one may determine the results, however I'm not up to solving these equations right now and am wondering if anyone has written a paper or two describing the effects. Regards, Karin |
3个回答
许多论文都描述了非标准负载(我认为你的意思是非Z0或非50欧姆)对S参数的影响,但可能并不是你想要的那么直接。
我将在本书的第3.9节中介绍这些案例,在这里你会发现,如果所有其他错误都很小,那么加载中的错误也会成为源匹配中的错误,并且加载中的错误会匹配。 如公式3.86所述,这会产生回波损耗,其中负载误差变为EDF~R~和ESF~R~,ERF很小。 它将影响传输不确定性,如等式3.99至3.101所述。 在这种情况下,唯一的误差是ESF~R~和ELF~R~EDF~R~是负载误差的度量,它是负载的线性回波损耗,因此如果你有45欧姆的负载 在50欧姆系统上,您的误差将是EDF~R~ = |(45-50)/(45 + 50)| = 0.052线性或26 dB残余负载匹配。 注意,通常负载是复杂的,并且由于寄生L或C而误差通常较大,而不是实际(DC)值中的误差.REF:微波元件测量手册,http:// www。 wiley.com/WileyCDA/WileyTitle/productCd-1119979552.html 以上来自于谷歌翻译 以下为原文 The effect of non-standard loads (which I suppose you mean non-Z0, or non-50 ohm) on S-parameters has been described in many papers, but maybe not so directly as you like. I cover the cases in section 3.9 of my book , where you will discover that, if all other errors are small, the error in the load also becomes the error in the source match, and the error in the load match. This effects return loss as described in equation 3.86 where load error becomes EDF ~R~ and ESF ~R~, ERF being small. It will effect transmission uncertainty as described in equaition 3.99 through 3.101. In this case the only errors are ESF ~R~ and ELF ~R~ The EDF ~R~ is a measure of the error in the load, it is the linear return loss of the load, so that if you had a 45 ohm load on a 50 ohm system, your error would be EDF ~R~ =|(45-50)/(45+50)|=0.052 linear or 26 dB residual load match. Note that in general the load is complex and the error will often be larger due to the parasitic L or C, rather than the error in the real (DC) value.. REF: Handbook of Microwave Component Measurements, http://www.wiley.com/WileyCDA/WileyTitle/productCd-1119979552.html |
脑洞大赛9 发表于 2018-12-18 13:43 谢谢Joel博士。 得到这本书。 好消息。 关心卡琳 以上来自于谷歌翻译 以下为原文 Thank you Dr. Joel. Gotta get the book. Good info. Regards Karin |
关于这个主题的一篇好文章是D.K.
Rytting,“网络分析仪准确度概述”,第59届ARFTG会议摘要,11月29日& 2001年3月30日本文可在IEEE Exporer Ken中进行搜索 以上来自于谷歌翻译 以下为原文 A good paper on this topic is D.K. Rytting, " Network Analyzer Accuracy Overview", 59th ARFTG Conference Digest, Nov. 29 & 30, 2001 This paper is searchable in IEEE Exporer Ken |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:50 , Processed in 0.791910 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1139
