我最近尝试将ISE Embedded Edition的永久许可证重新托管到另一台计算机。
虽然许可证管理器找到许可证并且它与我的计算机主机ID(网络MAC ID)匹配, ISE 13.4似乎无法识别它,只允许我选择WebPack列表中的设备。 不幸的是,该设计适用于Spartan 6 100t部件。 计算机是运行Win-XP的旧机器,ISE 13.4软件位于D:驱动器上。 有关如何调试此问题的任何想法? 谢谢! 约翰P. 以上来自于谷歌翻译 以下为原文 I recently tried to rehost a permanent license for ISE Embedded Edition to another computer. Although the License Manager finds the license and that it matches my computer Host ID (a network MAC ID), ISE 13.4 does not seem to recognize it and only lets me select devices that ar ein the WebPack list. Unfortunately, the design is for a Spartan 6 100t part. The computer is an older machine running Win-XP and the ISE 13.4 software is located on the D: drive. Any thoughts as to how I can debug this? Thanks! John P |
7个回答
我已经附加了xinfo.txt文件。
请注意,由于我的许可日期,我认为我需要坚持使用ISE 13.4。 谢谢你的帮助。 约翰P. 在原帖中查看解决方案 xinfo.txt 83 KB 以上来自于谷歌翻译 以下为原文 I've attached the xinfo.txt file. Note that I think I need to stick with ISE 13.4 because of my license date. Thanks for your help. John P View solution in original post xinfo.txt 83 KB |
嗨@jprovidenza
请在此处发布xinfo详细信息。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @jprovidenza Pleas post the xinfo details here. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
使用仅支持的ISE 14.7和最新版本的ISE
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 use ISE 14.7 which is only supported and latest version of ISEThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我已经附加了xinfo.txt文件。
请注意,由于我的许可日期,我认为我需要坚持使用ISE 13.4。 谢谢你的帮助。 约翰P. xinfo.txt 83 KB 以上来自于谷歌翻译 以下为原文 I've attached the xinfo.txt file. Note that I think I need to stick with ISE 13.4 because of my license date. Thanks for your help. John P xinfo.txt 83 KB |
@jprovidenza,
您似乎只安装了ISE 13.4的WebPACK版本。 您可以转到此位置并检查install.log文件:C: Xilinx 14.7 ISE_DS .xinstall 并查看您是否安装了System Edition或WebPACK版本。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @jprovidenza, It seems you have installed only WebPACK version of ISE 13.4. You can go to this location and check the install.log file: C:Xilinx14.7ISE_DS.xinstall And see if you have installed System Edition or WebPACK edition. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
努普尔 -
这似乎是问题所在。 我重新安装了ISE 13.4,现在我看到了Spartan 100t部件。 谢谢! 约翰P. 以上来自于谷歌翻译 以下为原文 Nupur - That seems to have been the problem. I re-installed ISE 13.4 and I now see the Spartan 100t part. Thanks! John P |
@jprovidenza,
很高兴知道这个问题已经解决了! 请将相应的回复标记为“接受为解决方案”以关闭该主题。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @jprovidenza, Glad to know that the issue is resolved! Please mark the appropriate reply as "Accept as solution" to close the thread. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
2416 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3372 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2459 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1149浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
582浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
448浏览 1评论
2003浏览 0评论
727浏览 0评论
GMT+8, 2024-12-22 19:32 , Processed in 1.451290 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
