电子发烧友论坛|
你好!我在新计算机(Windows 7—64位)中安装MPLABX V 2.26。没有运行。为了重新安装,我使用了卸载程序,但是计算机说卸载不是Win32有效的。有人能帮我吗?TKS!
以上来自于百度翻译 以下为原文 Hi ! I am tryng to install MPLABX v 2.26 in a new computer (Windows 7 - 64 bits). Is not running. To try to install again i used the uninstall program but the computer says that uninstall is not a Win32 valid aplicative. Someone could me help ? TKS ! |
15个回答
你好,我想你现在的安装程序文件已经损坏了。你需要再次下载MPLABX。你为什么要安装这样一个老版本的MPLAB X(V2.26)?我建议您下载V4.05(http://www. McCux.COM/MPLABX),确保您安装MPLABX时是管理员。
以上来自于百度翻译 以下为原文 Hi, I guess your current installer filer is simply corrupted. You need to download again MPLABX. Why do you want to install such an old version of MPLAB X (v2.26) ? I suggest you download v4.05 (http://www.microchip.com/MPLABX) Make sure you are administrator as you install MPLABX Regards |
谢谢您!我也安装了V4.05。没关系。我尝试了2.26,只是为了保持与我们的学生使用PLIB相同的环境。
以上来自于百度翻译 以下为原文 Thank you ! I install the v4.05 too. Its ok. I tried the 2.26 just to keep the same enviroment as my students where we are using PLIB. |
嗨,PLIB与MPLAB X没什么可看的。PLIB必须使用编译器版本(XC8、XC16、XC32)来查看。甚至可以使用最新的编译器并添加旧的PLIB。转到编译器下载页面,您将看到可以加载传统的PLIB并安装它。但现在是分开的
以上来自于百度翻译 以下为原文 Hi, PLIB has nothing to see with MPLAB X. PLIB has to see with the compiler version (XC8, XC16, Xc32). It is even possible to use the latest compilers and add the old PLIBs. Go to the compiler download page and you'll see that you can dwonload the legacy PLIB and install it. It used to be within the compiler but now it is separated Regards |
对于XC8绝对不是!大多数PIC头文件已经“清理”了,现在在新版本中,与“旧”PLIB有冲突。
以上来自于百度翻译 以下为原文 For xc8 it's definitely not! Most of PIC header files have been "cleaned up" and now in newer versions there are conflicts with "old" PLIB. -> see this Old thread |
如果您关注PLIB,那么XC8 V0.34可以安装,但仍然不必要,因为这也可以单独下载并安装在当前版本的编译器中。
以上来自于百度翻译 以下为原文 If you are concerned about PLIB, then XC8 v0.34 can be installed, but still not necessary as this can also be downloaded separately and installed in your current version of compiler. |
大多数PIC18和XC8比V1.34:没有太多的乐趣:
以上来自于百度翻译 以下为原文 Not much fun with most PIC18 and XC8 later than v1.34 :-( |
谢谢你们,但我仍然在黑暗中。我不是你的专家,我认为我有两种选择:卸载V.2.26并尝试重新安装(找到一种方法,因为卸载程序不工作);-安装PLIB(我发现它,遗留PLIB,但没有指令如何安装)我所需要的就是继续使用PLIB使用MPLABX。
以上来自于百度翻译 以下为原文 Thank you guys but i am still in the darkness. I am not an expert as you and i think i have two options: - uninstall the v.2.26 and try to install again (finding an way to do this because uninstall program is not working); - install PLIB (i found it, legacy-plib, but no instruction how to install) All i need is to continue to use MPLABX with PLIB. |
在安装遗产之前,请确保已经安装了XC8编译器的版本,因为您必须在XC8编译器的安装文件夹中安装传统的PLIB(在版本文件夹中)。
以上来自于百度翻译 以下为原文 Before you install the legacy, make sure you have installed a version of XC8 compiler already, as you'll have to install the legacy plib in the installation folder of the xc8 compiler (in the version folder). |
我想如果你想用PICB的PIC18。你最好不要安装或使用XC8版本比V1.34(它可能与一些PIC18,但我们不知道你想使用哪一个)不管你安装的MPLABX版本,不管你安装IDE或编译器第一次…
以上来自于百度翻译 以下为原文 I think if you want to use PLIB with a PIC18. you better do not install/use a XC8 version later than v1.34. (it MAY work with some PIC18, but we do not know which one you want to use) No matter what MPLABX version you install and it doesn't matter if you install the IDE or the compiler first... |
或者,从旧的PLIB窃取代码并添加(适应也许)到你的代码…
以上来自于百度翻译 以下为原文 Or, steal the code from old PLIB and add (adapt maybe) to your code... |
MPLABX是IDE(集成开发环境)。它不是编译器,它是分开的。PLIB是编译器的附加组件。(XC8、XC16、XC32……)没有什么可以阻止您使用最新版本的MPLABX编译器。
以上来自于百度翻译 以下为原文 You are still confused. MPLABX is the IDE (Integrated Development Environment). It is NOT the compiler, which is separate. PLIB is an add on to the compiler. (XC8, XC16, XC32...) There's nothing stopping you from using an older version of the compiler with the latest version of MPLABX. |
我还将添加,如果出现问题:您应该能够使用较新的XC版本,新的部分,不支持的XC你正在使用..你只需要下载“部分支持补丁”
以上来自于百度翻译 以下为原文 I'll also add, in case the question arises: you should be able to use older XC versions with newer parts, unsupported by the XC you are using.. you just have to download the "Part Support Patch" |
HTTP://WW1.MICCHIP.COM/DeLoSt/En/DeaveCID/OuturalAudioRealsFo-PIC18-V2.0RC3-WiDOWS安装程序。EXEI知道什么是编译器,什么是IDE。也许我无法解释到底发生了什么。Microchip表示给了我解决方案:上面的链接,任何人都可以使用MPLABX或XC8的新版本(但是)用PLIB!谢谢您!!
以上来自于百度翻译 以下为原文 http://ww1.microchip.com/downloads/en/DeviceDoc/peripheral-libraries-for-pic18-v2.00rc3-windows-installer.exe I know whats a compiler and whats an IDE. May be I cant explain exactly whats going on. Microchip represntative gave me the solution: with the link above anyone can use new versions of MPLABX or XC8 (however) with the PLIB ! Thank you !! |
从你的问题,我不同意。PLIB是编译器的一个特性,而不是IDE,但是你一直在问如何用MPLABX而不是XC8来使用PLIB。正如上面已经提到的,这不是一个完整的解决方案。旧的PLIB对于XC8的最新版本的PIC18设备都不起作用,因为在他们的无限智慧中,Microchip对一些设备进行了更改,这些文件包括与PLIB兼容的文件。正如VoLogi在POST第11版中所解释的,坚持XC8版本1.34与PLIB完全兼容是更安全的。这与您正在运行的MPLABX版本无关。
以上来自于百度翻译 以下为原文 From your questions, I do not agree. PLIB is a feature of the compiler, not the IDE, but you keep asking how to use PLIB with MPLABX, not XC8. As has already been mentioned above, that is NOT a complete solution. The old PLIB does NOT work for all PIC18 devices in the latest versions of XC8, because in their infinite wisdom, Microchip made changes to some of the device include files which break compatibility with PLIB. As vloki explained in post#11, it's safer to stick with XC8 version 1.34 for full compatibility with PLIB. This has nothing to do with which version of MPLABX you are running. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-3 01:17 , Processed in 1.463968 second(s), Total 103, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2950
