板子做出来很长时间都问题,前几天在烧写时有一个板子突然出现如下错误,网上搜索答案未果,请大家帮忙看下,谢谢
Contents mismatch at: 08000039H (Flash=FFH Required=14H) ! Contents mismatch at: 0800003AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800003BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800003CH (Flash=FFH Required=E7H) ! Contents mismatch at: 0800003DH (Flash=FFH Required=14H) ! Contents mismatch at: 0800003EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800003FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000040H (Flash=FFH Required=63H) ! Contents mismatch at: 08000041H (Flash=FFH Required=55H) ! Contents mismatch at: 08000042H (Flash=FFH Required=00H) ! Contents mismatch at: 08000043H (Flash=FFH Required=08H) ! Contents mismatch at: 08000044H (Flash=FFH Required=63H) ! Contents mismatch at: 08000045H (Flash=FFH Required=55H) ! Contents mismatch at: 08000046H (Flash=FFH Required=00H) ! Contents mismatch at: 08000047H (Flash=FFH Required=08H) ! Contents mismatch at: 08000048H (Flash=FFH Required=63H) ! Contents mismatch at: 08000049H (Flash=FFH Required=55H) ! Contents mismatch at: 0800004AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800004BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800004CH (Flash=FFH Required=D5H) ! Contents mismatch at: 0800004DH (Flash=FFH Required=14H) ! Contents mismatch at: 0800004EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800004FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000050H (Flash=FFH Required=63H) ! Contents mismatch at: 08000051H (Flash=FFH Required=55H) ! Contents mismatch at: 08000052H (Flash=FFH Required=00H) ! Contents mismatch at: 08000053H (Flash=FFH Required=08H) ! Contents mismatch at: 08000054H (Flash=FFH Required=63H) ! Contents mismatch at: 08000055H (Flash=FFH Required=55H) ! Contents mismatch at: 08000056H (Flash=FFH Required=00H) ! Contents mismatch at: 08000057H (Flash=FFH Required=08H) ! Contents mismatch at: 08000058H (Flash=FFH Required=63H) ! Contents mismatch at: 08000059H (Flash=FFH Required=55H) ! Contents mismatch at: 0800005AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800005BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800005CH (Flash=FFH Required=29H) ! Contents mismatch at: 0800005DH (Flash=FFH Required=15H) ! Contents mismatch at: 0800005EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800005FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000060H (Flash=FFH Required=EBH) ! Contents mismatch at: 08000061H (Flash=FFH Required=14H) ! Contents mismatch at: 08000062H (Flash=FFH Required=00H) ! Contents mismatch at: 08000063H (Flash=FFH Required=08H) ! Too many errors to display ! |
21个回答
把flash全部擦除再下载试下。
把板子仔细检查下,看有无虚焊,尤其是vdd
要么 电源 要么底线 没有接好吧 我原来也遇到过这种问题!!!!!
我在网上看到有人取消verify可以完成烧写,我试了试,果然没有出现错误,但是程序仍然跑不起来!这个方法不科学……
我又看到网上有人说是复位电路的原因,也没有说具体是什么原因,害我找了半天硬件复位的原因,也没有找出结果…… 然后擦除整个FLASH,还是不行。。。 不知道各位有什么办法没有 |
有一个比较低级的错误也会出现你这样类似的提示,比如拿F1(M3)的程序烧写F4(M4)的板子,估计你应该不是这个问题导致的。 |
1 条评论
STM32F103? 串口下载?SWD ? JATG ? DFU ?
这个STM32F205RE我有,做过最小系统板,做过JLINK-V9,都没有出现过问题,如果自己做的板子,请仔细看看 有无虚焊,205的可以用OTG ,也可以用串口试下,JATG 也试下。看看下载程序是否有问题,先确定是否芯片有问题,硬件问题也尽量缩减到SWD所用管脚,逐步减少范围。这个故障现象应该不是软件的问题。
csw_ying 发表于 2018-12-13 15:03 我就是做USB OTG的时候出现的这个问题,之前下载很多次都是好的。能尝试的方法也只有你刚说的方法没试过,因为板子上只有SWD,在下载的时候如果不勾选Verity选项,程序可以下载,但是运行的时候好像是部分代码在运行 |
楼主解决了么,我也遇到了,急需帮助解决
重点检查硬件,尤其电源,电源脚不要有不接的。虚焊方面也注意下。
楼上说的都试了 没有解决
如果偶尔可以下载偶尔不行,一般都是虚焊或者电源问题,看下电源上是否带了启动电流较大的负载,例如我就是板子上接入4G模块就会出现上面的状态,所以我加大电源和电容就搞定了
我是把内部flash算法stm32h750xx.FLM,改为stm32h7x_128K_ATK.FLM,解决了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 09:32 , Processed in 1.249775 second(s), Total 91, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3432
