电子发烧友论坛|
PIC32 MK1024MCF064和声2.04BUG 1:在PIN设置中:RA0 PIN 13不能在函数中被选择为AN0。BUG 2:DRVYADCYSTORD不包含信道5的初始化,尽管它在MHC中被选择。NATE输入选择,AddSyOrthaTeNe22.Cy22AAN6应该是CHIR1,2个bug是100%正确的,我已经找到了它们的解决方案,但是仍然很难找到问题并且应该在下一个版本中修复。Bug 3:没有必要作为Bug,但是您可以在PIN集中选择。STOP引脚47和引脚48(SCOSCI和SOSCO)作为输出,但实际上它们将不工作,并且数据表确认它们不能被选择为输出,即使没有使用振荡器。检查附件文件希望有人能找到这方面的帮助。
以上来自于百度翻译 以下为原文 PIC32MK1024MCF064 HARMony 2.04 Bug 1 : In the Pin settings : RA0 pin 13 cannot be chosen in the functions to be AN0 . Bug 2: drv_adc_static doesnot contain the initialization for Channel 5 although it is selected in the MHC . inaddtion : when selecting from the channel 5 analog (class-1) default or alternate input selection , ADHS_Alternate_2_CLASS2_AN6 should be CLASS1 instead. The 2 bug are 100% correct and i have found workarounds for them , but still it was time consuming to find the problem and should be fixed in the next version . bug 3 : not necessary as bug , but you can select in the pin settings PIN 47 and PIN 48 (SOSCI and SOSCO) as output , but in reality they will not work , and the data sheet confirms that they cannot be selected as output even if no oscillator to be used . check the attached file hopefully someone will find this helpful regards Attached Image(s) |
相关推荐 |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:58 , Processed in 0.840957 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1645
