电子发烧友论坛|
我试图通过labview读取Lightwave Compnent Analyzer(LCAN 4376B,与PNA N5242A连接)的端口数据,使用以下语法写入和读取VISA函数:MMEM:STOR:TRAC:FORM:SNP RI FORM:DATA ASCII,0
CALC1:数据:SNP:PORTs? “1,2”但它在读取VISA中返回错误。 错误代码:-1073807339,超时操作命令之前已过期。 我想知道这是否是LCA的问题。 我使用纯PNA(N5247A)测试了相同的语法,并可以在读缓冲区中获取测量数据。 任何人都可以帮我配置问题吗? 还有用于LCA的SCPI命令的参考手册吗? 在网站上找不到它。 谢谢。 以上来自于谷歌翻译 以下为原文 I am trying to read the port data of Lightwave Compnent Analyzer (LCAN 4376B, connected together with PNA N5242A) by Labview write and read VISA function with the following syntax: MMEM: STOR: TRAC: FORM: SNP RI FORM: DATA ASCII,0 CALC1: DATA: SNP: PORTs? "1,2" But it returns error in read VISA. Error Code: -1073807339, Timeout Expired before operation command. I am wondering whether it is the problem of LCA. I tested the same syntax with pure PNA (N5247A) and can get the measurement data in read buffer. Could anyone help me to configure the problem? Also is there any reference manual of the SCPI commands for LCA? Cannot find it in the website. Thanks. |
1个回答
N5242A应响应相同的SCPI命令,无论它是否配置为N4376B LCA。
LCA软件正在处理将网络分析仪与光学前端一起使用的额外校准步骤,但是一旦设置了测量,就可以使用N5242A的常规SCPI命令。 因此,N5242A的编程指南应该提供正确的信息。 链接:[http://na.tm.agilent.com/pna/help/index.html]在两台分析仪之间如何设置测量方面是否存在一些差异? 问候,迈克 以上来自于谷歌翻译 以下为原文 The N5242A should respond to the same SCPI commands, whether or not it is configured as an N4376B LCA. The LCA software is handling the additional calibration steps for using the network analyzer together with the optical frontend, but once it has set up the measurement, the regular SCPI commands for the N5242A can be used. So the programming guide for the N5242A should give the right information. Link: [http://na.tm.agilent.com/pna/help/index.html] Is there otherwise some difference in how the measurement is set up between your two analyzers? Regards, Mike |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:31 , Processed in 0.782445 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4360
