电子发烧友论坛|
海佬。我想知道我的代码执行我的程序需要多少时间。假设我写了一个简单的代码,用于LED闪烁在MPLAB IDE和HTC编译器的PIC16F87A使用4兆赫。因此,一个指令的执行时间是1US。从上面的C代码中,除了方括号之外,还有16行代码,延迟函数由9行代码组成。这意味着我要把它作为9条指令吗?????!我说的对吗????我想知道的是这个程序包含多少指令?我的意图是我应该说有多少指令是通过看到C代码编写的。
以上来自于百度翻译 以下为原文 Hai guys. I want to know how much time my code take to execute my program. Suppose i write a simple code for led blinking in MPLAB IDE & HTC Compiler for PIC16F877A using 4 MHz. So, Execution Time for One Instruction is 1us. #include #define _XTAL_FREQ 4e6 __CONFIG(0x3F3A); void main() { PORTD=0x00; TRISD=0x00; while(1) { RD0=1; __delay_ms(500); RD0=0; __delay_ms(500); } } From the above c code consists 16 lines of code apart from square brackets, delay function it consists 9 lines of code. That means shall i take it as 9 instructions????! am i right???? what i want to know is how much instruction this program consists of? My intention is i should say how many instructions is written by just seeing c code. |
12个回答
不可能。您需要查看拆卸视图或列表文件来确定。用一个非常小的简单程序,你可以猜得相当好,但是随着代码变得越来越大,越来越复杂,它不值得付出努力。编译代码告诉你它有多大。
以上来自于百度翻译 以下为原文 Not really possible. You need to look at the disassembly view or listing file to determine that. With a very small simple program you might be able to guess reasonably well, but as the code gets bigger and more complex it's not worth the effort. Compiling the code tells you how big it is. |
这不可能是9条指令。但是一些C语句是一对一将是一个操作码。然而大多数不是。
以上来自于百度翻译 以下为原文 That is not likely to be 9 instruction. But some C statements are one to one will an an opcode. However most are not. |
不完全错。你不允许PoIC1F架构所需要的银行选择指令。正如其他人建议的,你需要检查编译的代码来了解它是如何做的。查看你的项目文件夹中的.LST文件。如果你使用的话,它也会有很大的不同。在自由模式或PRO模式下编译。
以上来自于百度翻译 以下为原文 No. Completely wrong. You're not allowing for bank selecting instructions required by POIC1F architecture, etc. As others suggested, you need to examine the compiled code to get an idea of how it does it. Look in the .LST file in your project folder. It also makes a HUGE difference if you are using the compiler in FREE mode or PRO mode. |
好了,伙计们!谢谢你的建议MrBuff宁,Nkurzman和Qub。
以上来自于百度翻译 以下为原文 Ok guys! Thank u for the suggestions mbrowning, Nkurzman and qub. |
在项目文件夹中打开LST文件时,我得到了这样的结果:这里有多少条指令?如何识别这些指令?
以上来自于百度翻译 以下为原文 while opening lst file in project folder i get like this.. HI-TECH Software PIC Macro Assembler V9.80 build 6745 Sat Dec 09 15:29:56 2017 1 2 ; HI-TECH C Compiler for PIC10/12/16 MCUs V9.80 3 ; Copyright (C) 1984-2010 HI-TECH Software 4 5 ; Auto-generated runtime startup code for final link stage. 6 7 ; 8 ; Compiler options: 9 ; 10 ; -otest.cof -mtest.map --summary=default --output=default main.p1 11 ; --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g 12 ; --asmlist --errformat=Error [%n] %f; %l.%c %s 13 ; --msgformat=Advisory[%n] %s --warnformat=Warning [%n] %f; %l.%c %s 14 ; 15 16 17 processor 16F877A 18 19 global _main,start,_exit,reset_vec 20 fnroot _main 21 psect config,class=CONFIG,delta=2 22 psect idloc,class=IDLOC,delta=2 23 psect code,class=CODE,delta=2 24 psect powerup,class=CODE,delta=2 25 psect reset_vec,class=CODE,delta=2 26 psect maintext,class=CODE,delta=2 27 0000 C set 0 28 0002 Z set 2 29 0002 PCL set 2 30 0000 INDF set 0 31 32 0003 STATUS equ 3 33 000A PCLATH equ 0Ah 34 35 psect eeprom_data,class=EEDATA,delta=2,space=2 36 psect intentry,class=CODE,delta=2 37 psect functab,class=CODE,delta=2 38 global intlevel0,intlevel1,intlevel2, intlevel3, intlevel4, intlevel5 39 0000 intlevel0: 40 0000 intlevel1: 41 0000 intlevel2: 42 0000 intlevel3: 43 0000 intlevel4: 44 0000 intlevel5: 45 psect init,class=CODE,delta=2 46 psect cinit,class=CODE,delta=2 47 psect text,class=CODE,delta=2 48 psect end_init,class=CODE,delta=2 49 psect clrtext,class=CODE,delta=2 50 0004 FSR set 4 51 psect strings,class=CODE,delta=2,reloc=256 52 53 psect reset_vec 54 0000 reset_vec: 55 ; No powerup routine 56 ; No interrupt routine 57 58 59 psect init 60 0000 start 61 0000 _exit 62 psect end_init 63 global start_initialization 64 0000 120A 118A 2FD2 ljmp start_initialization ;jump to C runtime clear & initialization HI-TECH Software PICC Macro Assembler V9.80 build 6745 Symbol Table Sat Dec 09 15:29:56 2017 _main 07D6 _exit 0000 start 0000 start_initialization 07D2 intlevel0 0000 intlevel1 0000 intlevel2 0000 intlevel3 0000 intlevel4 0000 intlevel5 0000 reset_vec 0000 Here, How many instructions are present? How to identify those instructions? |
在那个文件中只有一个指令。您使用的是HistC.C的旧版本。我认为一个生成多个LST文件。稍后的版本和XC8的所有版本都将其全部放入一个LST文件中。
以上来自于百度翻译 以下为原文 There is only one instruction in that file. You're using an old version of HiTech C. I think that one produces multiple LST files. Later versions, and all versions of XC8, put it all into one LST file. |
好的。现在我在MPLAB XIDE中用PIC18F450构建了一个闪烁的LED代码,用XC8编译器编写。这个代码集的源代码文件已经提到了……这里有多少条指令?如何识别这些指令?
以上来自于百度翻译 以下为原文 Yeah Ok. Now i have built one example code of Blinking Led using PIC18F4550 in MPLAB XIDE with XC8 Compiler. Source Code /* Led blinking using PIC18F4550 */ #include "osc_config.h" /*Header file for Configuration Bits*/ #include #define LED LATB void MSdelay(unsigned int); void main() { OSCCON=0x72; /* Use internal oscillator of 8MHz Frequency */ TRISB=0x00; /* Set direction of PORTB as OUTPUT to which LED is connected */ while(1) { LED = 0xff; /* Turn ON LED for 500 ms */ MSdelay (500); LED = 0; /* Turn OFF LED for 500 ms */ MSdelay (500); } } void MSdelay(unsigned int val) { unsigned int i,j; for(i=0;i } Lst file of this code Microchip Technology PIC18 LITE Macro Assembler V1.40 build -251452761 Wed Oct 04 16:06:58 2017 Microchip Technology Omniscient Code Generator v1.40 (Free mode) build 201612010151 1 processor 18F4550 2 fnconf rparam,??,?,0 3 opt pw 120 4 opt lm 5 psect cinit,global,reloc=2,class=CODE,delta=1 6 psect cstackCOMRAM,global,class=COMRAM,space=1,delta=1,noexec 7 psect text0,global,reloc=2,class=CODE,delta=1 8 psect text1,global,reloc=2,class=CODE,delta=1 9 psect intsave_regs,global,class=BIGRAM,space=1,delta=1,noexec 10 psect rparam,global,class=COMRAM,space=1,delta=1,noexec 11 0000 12 ; Version 1.40 13 ; Generated 01/12/2016 GMT 14 ; 15 ; Copyright © 2016, Microchip Technology Inc. and its subsidiaries ("Microchip") 16 ; All rights reserved. 17 ; 18 ; This software is developed by Microchip Technology Inc. and its subsidiaries ("Microch + ip"). 19 ; 20 ; Redistribution and use in source and binary forms, with or without modification, are 21 ; permitted provided that the following conditions are met: 22 ; 23 ; 1. Redistributions of source code must retain the above copyright notice, this lis + t of 24 ; conditions and the following disclaimer. 25 ; 26 ; 2. Redistributions in binary form must reproduce the above copyright notice, this + list 27 ; of conditions and the following disclaimer in the documentation and/or other 28 ; materials provided with the distribution. 29 ; 30 ; 3. Microchip's name may not be used to endorse or promote products derived from th + is 31 ; software without specific prior written permission. 32 ; 33 ; THIS SOFTWARE IS PROVIDED BY MICROCHIP "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, 34 ; INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS F + OR 35 ; PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL MICROCHIP BE LIABLE FOR ANY DIRECT, INDIREC + T, 36 ; INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING BUT NOT LIMITED TO 37 ; PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA OR PROFITS; OR BUSINESS 38 ; INTERRUPTION) HOWSOEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, ST + RICT 39 ; LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE U + SE OF 40 ; THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. 41 ; 42 ; 43 ; Code-generator required, PIC18F4550 Definitions 44 ; 45 ; SFR Addresses 46 0000 _LATB set 3978 47 0000 _OSCCON set 4051 48 0000 _TRISB set 3987 49 50 ; #config settings 51 0000 52 psect cinit 53 007F9C __pcinit: 54 opt stack 0 55 007F9C start_initialization: 56 opt stack 0 57 007F9C __initialization: 58 opt stack 0 59 007F9C end_of_initialization: 60 opt stack 0 61 007F9C __end_of__initialization: 62 opt stack 0 63 007F9C 0100 movlb 0 64 007F9E EFD1 F03F goto _main ;jump to C main() function 65 66 psect cstackCOMRAM 67 000001 __pcstackCOMRAM: 68 opt stack 0 69 000001 MSdelay@val: 70 opt stack 0 71 72 ; 2 bytes @ 0x0 73 000001 ds 2 74 000003 MSdelay@i: 75 opt stack 0 76 77 ; 2 bytes @ 0x2 78 000003 ds 2 79 000005 MSdelay@j: 80 opt stack 0 81 82 ; 2 bytes @ 0x4 83 000005 ds 2 84 000007 85 ; 1 bytes @ 0x6 86 ;; 87 ;;Main: autosize = 0, tempsize = 0, incstack = 0, save=0 88 ;; 89 ;; *************** function _main ***************** 90 ;; Defined at: 91 ;; line 12 in file "blink_of_led.c" 92 ;; Parameters: Size Location Type 93 ;; None 94 ;; Auto vars: Size Location Type 95 ;; None 96 ;; Return value: Size Location Type 97 ;; 1 wreg void 98 ;; Registers used: 99 ;; wreg, status,2, status,0, cstack 100 ;; Tracked objects: 101 ;; On entry : 0/0 102 ;; On exit : 0/0 103 ;; Unchanged: 0/0 104 ;; Data sizes: COMRAM BANK0 BANK1 BANK2 BANK3 BANK4 BANK5 BANK6 BANK7 105 ;; Params: 0 0 0 0 0 0 0 0 0 106 ;; Locals: 0 0 0 0 0 0 0 0 0 107 ;; Temps: 0 0 0 0 0 0 0 0 0 108 ;; Totals: 0 0 0 0 0 0 0 0 0 109 ;;Total ram usage: 0 bytes 110 ;; Hardware stack levels required when called: 1 111 ;; This function calls: 112 ;; _MSdelay 113 ;; This function is called by: 114 ;; Startup code after reset 115 ;; This function uses a non-reentrant model 116 ;; 117 118 psect text0 119 007FA2 __ptext0: 120 opt stack 0 121 007FA2 _main: 122 opt stack 30 123 124 ;blink_of_led.c: 14: OSCCON=0x72; 125 126 ;incstack = 0 127 007FA2 0E72 movlw 114 128 007FA4 6ED3 movwf 4051,c ;volatile 129 130 ;blink_of_led.c: 15: TRISB=0x00; 131 007FA6 0E00 movlw 0 132 007FA8 6E93 movwf 3987,c ;volatile 133 007FAA l662: 134 135 ;blink_of_led.c: 17: { 136 ;blink_of_led.c: 18: LATB = 0xff; 137 007FAA 688A setf 3978,c ;volatile 138 139 ;blink_of_led.c: 19: MSdelay (500); 140 007FAC 0E01 movlw 1 141 007FAE 6E02 movwf MSdelay@val+1,c 142 007FB0 0EF4 movlw 244 143 007FB2 6E01 movwf MSdelay@val,c 144 007FB4 ECE5 F03F call _MSdelay ;wreg free 145 146 ;blink_of_led.c: 20: LATB = 0; 147 007FB8 0E00 movlw 0 148 007FBA 6E8A movwf 3978,c ;volatile 149 150 ;blink_of_led.c: 21: MSdelay (500); 151 007FBC 0E01 movlw 1 152 007FBE 6E02 movwf MSdelay@val+1,c 153 007FC0 0EF4 movlw 244 154 007FC2 6E01 movwf MSdelay@val,c 155 007FC4 ECE5 F03F call _MSdelay ;wreg free 156 007FC8 D7F0 goto l662 157 007FCA __end_of_main: 158 opt stack 0 159 160 ;; *************** function _MSdelay ***************** 161 ;; Defined at: 162 ;; line 24 in file "blink_of_led.c" 163 ;; Parameters: Size Location Type 164 ;; val 2 0[COMRAM] unsigned int 165 ;; Auto vars: Size Location Type 166 ;; j 2 4[COMRAM] unsigned int 167 ;; i 2 2[COMRAM] unsigned int 168 ;; Return value: Size Location Type 169 ;; 1 wreg void 170 ;; Registers used: 171 ;; wreg, status,2, status,0 172 ;; Tracked objects: 173 ;; On entry : 0/0 174 ;; On exit : 0/0 175 ;; Unchanged: 0/0 176 ;; Data sizes: COMRAM BANK0 BANK1 BANK2 BANK3 BANK4 BANK5 BANK6 BANK7 177 ;; Params: 2 0 0 0 0 0 0 0 0 178 ;; Locals: 4 0 0 0 0 0 0 0 0 179 ;; Temps: 0 0 0 0 0 0 0 0 0 180 ;; Totals: 6 0 0 0 0 0 0 0 0 181 ;;Total ram usage: 6 bytes 182 ;; Hardware stack levels used: 1 183 ;; This function calls: 184 ;; Nothing 185 ;; This function is called by: 186 ;; _main 187 ;; This function uses a non-reentrant model 188 ;; 189 190 psect text1 191 007FCA __ptext1: 192 opt stack 0 193 007FCA _MSdelay: 194 opt stack 30 195 196 ;blink_of_led.c: 26: unsigned int i,j; 197 ;blink_of_led.c: 27: for(i=0;i 199 ;incstack = 0 200 007FCA 0E00 movlw 0 201 007FCC 6E04 movwf MSdelay@i+1,c 202 007FCE 0E00 movlw 0 203 007FD0 6E03 movwf MSdelay@i,c 204 007FD2 D00F goto l658 205 007FD4 l646: 206 207 ;blink_of_led.c: 28: for(j=0;j<165;j++); 208 007FD4 0E00 movlw 0 209 007FD6 6E06 movwf MSdelay@j+1,c 210 007FD8 0E00 movlw 0 211 007FDA 6E05 movwf MSdelay@j,c 212 007FDC l648: 213 007FDC 5006 movf MSdelay@j+1,w,c 214 007FDE E107 bnz l656 215 007FE0 0EA5 movlw 165 216 007FE2 5C05 subwf MSdelay@j,w,c 217 007FE4 B0D8 btfsc status,0,c 218 007FE6 D003 goto l656 219 007FE8 4A05 infsnz MSdelay@j,f,c 220 007FEA 2A06 incf MSdelay@j+1,f,c 221 007FEC D7F7 goto l648 222 007FEE l656: 223 007FEE 4A03 infsnz MSdelay@i,f,c 224 007FF0 2A04 incf MSdelay@i+1,f,c 225 007FF2 l658: 226 007FF2 5001 movf MSdelay@val,w,c 227 007FF4 5C03 subwf MSdelay@i,w,c 228 007FF6 5002 movf MSdelay@val+1,w,c 229 007FF8 5804 subwfb MSdelay@i+1,w,c 230 007FFA B0D8 btfsc status,0,c 231 007FFC 0012 return 232 007FFE D7EA goto l646 233 008000 __end_of_MSdelay: 234 opt stack 0 235 0000 status equ 0xFD8 236 status equ 0xFD8 237 238 psect rparam 239 0000 status equ 0xFD8 Data Sizes: Strings 0 Constant 0 Data 0 BSS 0 Persistent 0 Stack 0 Auto Spaces: Space Size Autos Used COMRAM 95 6 6 BANK0 160 0 0 BANK1 256 0 0 BANK2 256 0 0 BANK3 256 0 0 BANK4 256 0 0 BANK5 256 0 0 BANK6 256 0 0 BANK7 256 0 0 Pointer List with Targets: None. Critical Paths under _main in COMRAM _main->_MSdelay Critical Paths under _main in BANK0 None. Critical Paths under _main in BANK1 None. Critical Paths under _main in BANK2 None. Critical Paths under _main in BANK3 None. Critical Paths under _main in BANK4 None. Critical Paths under _main in BANK5 None. Critical Paths under _main in BANK6 None. Critical Paths under _main in BANK7 None. Call Graph Tables: --------------------------------------------------------------------------------- (Depth) Function Calls Base Space Used Autos Params Refs --------------------------------------------------------------------------------- (0) _main 0 0 0 178 _MSdelay --------------------------------------------------------------------------------- (1) _MSdelay 6 4 2 178 0 COMRAM 6 4 2 --------------------------------------------------------------------------------- Estimated maximum stack depth 1 --------------------------------------------------------------------------------- Call Graph Graphs: _main (ROOT) _MSdelay Address spaces: Name Size Autos Total Cost Usage BITCOMRAM 5F 0 0 0 0.0% EEDATA 100 0 0 0 0.0% NULL 0 0 0 0 0.0% CODE 0 0 0 0 0.0% COMRAM 5F 6 6 1 6.3% STACK 0 0 0 2 0.0% DATA 0 0 0 3 0.0% BITBANK0 A0 0 0 4 0.0% BANK0 A0 0 0 5 0.0% BITBANK1 100 0 0 6 0.0% BANK1 100 0 0 7 0.0% BITBANK2 100 0 0 8 0.0% BANK2 100 0 0 9 0.0% BITBANK3 100 0 0 10 0.0% BANK3 100 0 0 11 0.0% BITBANK4 100 0 0 12 0.0% BANK4 100 0 0 13 0.0% BITBANK5 100 0 0 14 0.0% BANK5 100 0 0 15 0.0% BITBANK6 100 0 0 16 0.0% BANK6 100 0 0 17 0.0% BITBANK7 100 0 0 18 0.0% BANK7 100 0 0 19 0.0% ABS 0 0 0 20 0.0% BIGRAM 7FF 0 0 21 0.0% BITSFR 0 0 0 200 0.0% SFR 0 0 0 200 0.0% Microchip Technology PIC18 Macro Assembler V1.40 build -251452761 Symbol Table Wed Oct 04 16:06:58 2017 __CFG_BOR$ON 000000 __CFG_BORV$3 000000 __CFG_CP0$OFF 000000 __CFG_CP1$OFF 000000 __CFG_CP2$OFF 000000 __CFG_CP3$OFF 000000 l646 7FD4 l662 7FAA l656 7FEE l648 7FDC l658 7FF2 __CFG_CPB$OFF 000000 __CFG_CPD$OFF 000000 __CFG_LVP$OFF 000000 __CFG_WDT$OFF 000000 _LATB 000F8A _main 7FA2 start 0000 __end_of_MSdelay 8000 __CFG_IESO$OFF 000000 ___param_bank 000000 __CFG_CCP2MX$ON 000000 ?_main 0001 _TRISB 000F93 __CFG_PWRT$OFF 000000 __CFG_WRT0$OFF 000000 __CFG_WRT1$OFF 000000 __CFG_WRT2$OFF 000000 __CFG_WRT3$OFF 000000 __CFG_EBTR0$OFF 000000 __CFG_FCMEN$OFF 000000 __CFG_EBTR1$OFF 000000 __CFG_EBTR2$OFF 000000 __CFG_EBTR3$OFF 000000 __CFG_WRTB$OFF 000000 __CFG_WRTC$OFF 000000 __CFG_WRTD$OFF 000000 __CFG_EBTRB$OFF 000000 status 000FD8 __CFG_ICPRT$OFF 000000 __CFG_MCLRE$OFF 000000 __initialization 7F9C __end_of_main 7FCA ??_main 0007 __activetblptr 000000 ??_MSdelay 0003 _OSCCON 000FD3 __CFG_XINST$OFF 000000 __CFG_STVREN$ON 000000 __accesstop 0060 __end_of__initialization 7F9C __CFG_PBADEN$OFF 000000 ___rparam_used 000001 __pcstackCOMRAM 0001 _MSdelay 7FCA __CFG_VREGEN$OFF 000000 __Hparam 0000 __Lparam 0000 __pcinit 7F9C __ramtop 0800 __ptext0 7FA2 __ptext1 7FCA end_of_initialization 7F9C start_initialization 7F9C __CFG_LPT1OSC$OFF 000000 ?_MSdelay 0001 MSdelay@i 0003 MSdelay@j 0005 __CFG_WDTPS$32768 000000 __size_of_MSdelay 0036 __Hrparam 0000 __Lrparam 0000 __size_of_main 0028 MSdelay@val 0001 __CFG_FOSC$INTOSC_EC 000000 As i already mentioned ....... Here, How many instructions are present? How to identify those instructions? |
这里是你的主()函数。第一列只是一个行号。第二列是PIC代码存储器中的地址。第三列是指令。然后是指令的解体。原来的C代码在每个指令组之前被显示为注释。所以:在地址7FA2上的行α127是指令0x0E72,它是“MOVLW 114”。114=0x72。IS正在准备在下一个指令中向OSCCon写这个值。当然,您需要理解PIC16汇编代码来理解所有这些。
以上来自于百度翻译 以下为原文 Here is your main() function 124 ;blink_of_led.c: 14: OSCCON=0x72; 125 126 ;incstack = 0 127 007FA2 0E72 movlw 114 128 007FA4 6ED3 movwf 4051,c ;volatile 129 130 ;blink_of_led.c: 15: TRISB=0x00; 131 007FA6 0E00 movlw 0 132 007FA8 6E93 movwf 3987,c ;volatile 133 007FAA l662: 134 135 ;blink_of_led.c: 17: { 136 ;blink_of_led.c: 18: LATB = 0xff; 137 007FAA 688A setf 3978,c ;volatile 138 139 ;blink_of_led.c: 19: MSdelay (500); 140 007FAC 0E01 movlw 1 141 007FAE 6E02 movwf MSdelay@val+1,c 142 007FB0 0EF4 movlw 244 143 007FB2 6E01 movwf MSdelay@val,c 144 007FB4 ECE5 F03F call _MSdelay ;wreg free 145 146 ;blink_of_led.c: 20: LATB = 0; 147 007FB8 0E00 movlw 0 148 007FBA 6E8A movwf 3978,c ;volatile 149 150 ;blink_of_led.c: 21: MSdelay (500); 151 007FBC 0E01 movlw 1 152 007FBE 6E02 movwf MSdelay@val+1,c 153 007FC0 0EF4 movlw 244 154 007FC2 6E01 movwf MSdelay@val,c 155 007FC4 ECE5 F03F call _MSdelay ;wreg free 156 007FC8 D7F0 goto l662 157 007FCA __end_of_main: The first column is just a line number. The second column is the address in PIC code memory. The third column is the instruction. That is then followed by disassembly of the instruction. The original C code is shown as a comment just before each group of instructions. So: 127 007FA2 0E72 movlw 114 This is line#127, at address 7FA2 is the instruction 0x0E72, which is a "MOVLW 114". 114 = 0x72. Is is preparing to write that value to OSCCON in the next instruction. Of course you need to understand PIC16 assembly code to understand all this. |
伟大的解释,先生!因此,至少在一个C代码中,我至少得到两个指令。是的,需要理解汇编代码。
以上来自于百度翻译 以下为原文 Great Explanation sir! So, at the least case i get minimum of two instructions for a c code. Yes, need to understand Assembly code. |
我有两个疑问,我不想创建另一个线程。??????哪一个最适合编程?Sy-DelaysMy()类似循环运行延迟吗???????这会影响CPU速度吗?不同于定时器。怀疑NO: 2:如何基于FoSC创建循环运行延迟?虽然上面的代码是为了编程而复制的。我什么都懂。除了延迟运行for循环…如何创建这样?他们是如何发现第二个循环的?????
以上来自于百度翻译 以下为原文 I have two doubts, i don't want to create another thread. Doubt No:1 What is the difference between __delay_ms() , Timer delay and Loop running delay ????? Which one is ideal for programming....? __delay_ms() is like Loop running delay????? Will this affect CPU speed unlike Timer. Doubt No:2 How to create Loop Running Delay based on Fosc? Though the above code i copied for programming. I understand everything.. Except the delay running for loop.. void MSdelay(unsigned int val) { unsigned int i,j; for(i=0;i } How to create like this? How they found specifically 165 for the second for loop???? |
对于精确的定时,类似的回路必须通过实验或通过检查拆卸器来手动调节。实际的延迟可能会从编译到编译,或者用一个新的编译器版本。这就是为什么XC8提供了一个新的版本或代码更改创建一个一致的延迟的方法。我个人从来没有使用过yy-DelayyMs-()函数,除非在启动过程中偶尔会出现,因为(就像上面的循环),PIC在运行LO时什么也不能做。我将总是使用100ms或1ms定时器中断来延迟超过我们几个。
以上来自于百度翻译 以下为原文 For precise timing, a loop like that has to be hand tuned either experimentally or by inspecting the dissassembly. And the actual delay will change maybe a bit from compile to compile, or with a new compiler version. This is why XC8 provides the __delay_ms() , _us() functions to create a consistent delay over new versions or changes in code. I personally never use the __delay_ms() function except maybe occasionally during startup because (like the loop above) the PIC can do nothing else while it's running the loop. I will always use a 100us or 1ms timer interrupt to make delays beyond a few us. |
LED = 0xFF;/*打开LED 500毫秒/这将导致你以后的问题,因为你正在设置8位,而不是一个位。
以上来自于百度翻译 以下为原文 LED = 0xff; /* Turn ON LED for 500 ms */ That will cause you problems later on because you are setting 8bits rather than one bit. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 16:52 , Processed in 0.936921 second(s), Total 94, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
274
