扫一扫,分享给好友
你好
我在个人笔记本电脑上安装了VIVADO的网络包。 但出于某种原因,当我在硬件管理器中吃午餐并寻找新的目标时,它找不到连接到正常工作的USB端口的ZYBO板。 我应该寻找一个端口配置吗? 我还在另一台计算机上安装了VIVADO Web包。 在此计算机中,许可证管理器不会向我提供Web包许可证,仅提供评估版本。 以上来自于谷歌翻译 以下为原文 Hi I have installed the web pack of the VIVADO on my personal laptop. But for some reason when I lunch the Hardware Manager and looking for a new target it don't find the ZYBO board, which is connected to a working USB port. Is there a port configuration I should look for? I also installed the VIVADO web pack on a second computer. In this computer the license manager doesn't give me the web pack license, only the evaluation versions. |
2个回答
嗨,在第二台计算机的tcl控制台中运行tcl命令并共享output.txt以调试issue.report_environment -file output.txt
关于您对Hardware Manager的查询,是否安装了电缆驱动程序? 通过查看设备管理器确认 谢谢,维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Run the tcl command in the tcl console of second computer and share the output.txt to debug the issue. report_environment -file output.txt Regarding your query on Hardware Manager, Is cable drivers installed? confirm by looking at Device Manager Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,转到许可委员会。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Moving to licensing board.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2219 浏览 9 评论
3296 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
657浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
465浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
229浏览 1评论
671浏览 0评论
1865浏览 0评论
GMT+8, 2024-10-2 14:12 , Processed in 1.132452 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
