扫一扫,分享给好友
我安装了xilinx 9.1i。
安装完成后我写了VERILOG TEST FIXTURE。 但是,当我尝试模拟它时,会出现以下错误: “Project Navigator无法找到Model Technology的ModelSim可执行文件。 请转到“修改”菜单,选择“首选项”,然后选择“集成工具”标签。 使用此对话框选择要用于模拟的ModelSim可执行文件。 然后再试一次这个过程。“ 我试图搜索并安装MXE,但页面不可用。 我试图改变模拟器并使用另一个..但无法理解如何做到这一点。 请有人建议我解决这个问题。 以上来自于谷歌翻译 以下为原文 I installed xilinx 9.1i. After installation when i wrote the VERILOG TEST FIXTURE. But when i try to simulate it is giving the following error : " Model Technology's ModelSim executable cannot be found by Project Navigator. Please go to the 'Edit' menu, select 'Preferences' and then select the 'Integrated Tools' tab. Using this dialog select the ModelSim executable that you wish to use for simulation. Then try this process again. " i tried to search and install MXE but the page was not available. I tried to change the simulator and use another one..but could not understand how to do it. Please Someone suggest me the solution for this problem. |
5个回答
你有Modelim(PE,SE或其他版本)吗?
如果没有,您应该注意不再提供ModelSim XE(Xilinx版本),这就是您没有找到该网页的原因。 如果你想使用ISIM,那么你可能最好使用更新版本的ISE,因为ISIM在版本9.1中非常原始 你的设计目标是什么? 如果您使用比Spartan 3或Virtex 4更旧的部件,那么您应该安装ISE 10.1.03i(10.1和SP 3),对于较新的部件,您应该使用最新的ISE,或至少13.4,这是一个主要的修订版但是 已经有一个相当不错的ISIM版本,是一个非常稳定的版本。 - Gabor - Gabor 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Do you already have Modelsim (PE, SE or other version)? If not you should note that ModelSim XE (Xilinx edition) is no longer offered, which is why you did not find the web page. If you want to use ISIM, then you'd probably be better off using a newer version of ISE, since ISIM was pretty primitive in version 9.1 What parts are you targetting with your design? If you use parts older than Spartan 3 or Virtex 4, then you should install ISE 10.1.03i (10.1 with SP 3), and for newer parts you should probably use the latest ISE, or at least 13.4 which is one major revision back but already has a fairly good version of ISIM included and is a quite stable release. -- Gabor -- GaborView solution in original post |
嗨narendra,
从你发帖我强调你想要使用ModelSim。 请按照以下步骤使用带ISE的Modelsim模拟器。 第一步是获取,安装和许可ModelSim。 编译仿真模型:如果您尚未编译仿真模型,请查看(Xilinx答复15338)。 从Project Navigator运行模拟: Project Navigator应自动定位ModelSim安装并准备好运行模拟。 必须将测试平台添加到项目中。 单击Project Navigator中Sources窗口中的testbench,ModelSim Simulator进程应出现在Processes窗口中。 注意:如果没有出现ModelSim过程,请确定您是否选择了正确的模拟器,以及是否通过执行以下操作在集成模拟器部分中指定了模拟器 a)转到项目 - >设计属性 - >模拟器 - > 在模拟属性中提供已编译库的路径,如下所示。 (在设计窗口中选择测试平台,然后右键单击模拟行为模型,现在选择流程属性) 湾 转到编辑 - >首选项 - >集成工具(类别) - > 4.双击“模拟行为模型”以运行模拟。 问候, 赛义德 -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi narendra, From you post I undersatnd that you want to use ModelSim. Please follow the below steps to use Modelsim simulator with ISE.
a) Go to Project--> Design properties-->simulator--> Give the path to compiled libraries in the simulation properties as shown below. (select test bench in design window and right click Simulate Behavioral Model, now select process properties) b. Go to Edit-->preferences-->integrated tools (category)--> 4. Double-click on the “Simulate Behavioral Model” to run the simulation. Regards, Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
如果没有,您应该注意不再提供ModelSim XE(Xilinx版本),这就是您没有找到该网页的原因。 如果你想使用ISIM,那么你可能最好使用更新版本的ISE,因为ISIM在版本9.1中非常原始 你的设计目标是什么? 如果您使用比Spartan 3或Virtex 4更旧的部件,那么您应该安装ISE 10.1.03i(10.1和SP 3),对于较新的部件,您应该使用最新的ISE,或至少13.4,这是一个主要的修订版但是 已经有一个相当不错的ISIM版本,是一个非常稳定的版本。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 Do you already have Modelsim (PE, SE or other version)? If not you should note that ModelSim XE (Xilinx edition) is no longer offered, which is why you did not find the web page. If you want to use ISIM, then you'd probably be better off using a newer version of ISE, since ISIM was pretty primitive in version 9.1 What parts are you targetting with your design? If you use parts older than Spartan 3 or Virtex 4, then you should install ISE 10.1.03i (10.1 with SP 3), and for newer parts you should probably use the latest ISE, or at least 13.4 which is one major revision back but already has a fairly good version of ISIM included and is a quite stable release. -- Gabor -- Gabor |
谢谢..非常实用..
猜猜我现在必须使用Modelsim SE版本.. 以上来自于谷歌翻译 以下为原文 Thanks..really useful.. Guess i have to now go with Modelsim SE version.. |
首先找到modelsim的安装路径
打开ise Edit -> Preferences -> integrated Tools 第一个 Model Tech Simulator: F:Modelsimwin64modelsim.exe 你的modelsim的地址 |
只有小组成员才能发言,加入小组>>
2220 浏览 7 评论
2643 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2125 浏览 9 评论
3197 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2248 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
494浏览 1评论
1574浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2219浏览 0评论
544浏览 0评论
1711浏览 0评论
GMT+8, 2024-7-1 16:59 , Processed in 1.391249 second(s), Total 54, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
