电子发烧友论坛|
我在惠普上安装了Windows 10,带有Intel HD Graphics 5500,试图通过连接到第二个屏幕和笔记本电脑的HDMI线将HP屏幕连接到我的笔记本电脑。
当我右键单击桌面,然后左键单击图形属性时,它将打开英特尔高清图形控制面板。 我单击“显示”和“多个显示”,除了单一显示外,它不会让我做任何事情。 我同时按下Windows键和P键,然后单击“扩展”,它不会执行任何操作。 据intel.com称,“所有英特尔®图形产品都支持跨两个显示器的扩展桌面模式。” 鉴于我对这款特定的英特尔产品的困难以及此论坛上的其他人对此发表了评论,我觉得这很难相信。 该连接适用于我的另一台笔记本电脑,所以我知道它不是电缆,连接等。第二个屏幕无法识别。 以上来自于谷歌翻译 以下为原文 I have Windows 10, on an HP, with Intel HD Graphics 5500, trying to connect an HP screen to my laptop via HDMI cable connected to the second screen and the laptop. When I right click on the desktop, and left click Graphics Properties, it opens the Intel HD Graphics Control Panel. I click on Display, and Multiple Displays, and it won't let me do anything other than Single Display. I press the windows key and P simultaneously, and click Extend, and it doesn't do anything. According to intel.com, "All Intel® graphics products support extended desktop mode across two displays." I find this extremely hard to believe, given my difficulty with this particular Intel product and since others on this forum have commented on this. The connection works for another laptop I have, so I know it is NOT the cable, connection, etc. The second screen is not recognized. |
14个回答
Hellowmc840,据我所知,多显示器工作不正常。关于这一点,我们需要更多的系统信息,请提供英特尔®系统支持实用程序报告,这个报告可以从我们的工具生成,你可以参考
下面的链接,你可以下载它:https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-确保将创建的报告附加到这个主题。还有,你有吗 尝试将系统连接到另一台显示器? 你试过的显示器的型号是什么?请跟我说.Regards,David V. 以上来自于谷歌翻译 以下为原文 Hello wmc840, I understand that the multi monitor is not working properly. Regarding this, we will need more information of the system, please provide us with an Intel ® System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Make sure to attach the created report to this thread. Also, have you tried connecting the system to another monitor? What is the model of the monitor(s) you have tried? Let me know please. Regards, David V |
Hellowmc840,感谢您的回复。我正在审核您提交的报告,似乎有一个过时的集成显卡驱动程序。 建议更新它,以便我们可以看到这是否是问题的根源。 请从以下链接下载“.zip”文件:https://downloadcenter.intel.com/download/27780/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product = 86210一旦下载,请 按照以下步骤进行手动安装:1 - 将文件解压缩到指定位置或文件夹.2 - 右键单击Windows“开始”图标,然后打开“设备管理器”.3 - 提示用户帐户控制权限时,单击“是”。 - 展开显示适配器部分.5 - 右键单击英特尔®图形条目,然后选择更新驱动程序软件.6 - 单击“浏览计算机以查找驱动程序软件”.7 - 单击“让我从我的设备驱动程序列表中选择” 计算机“.8 - 单击”从磁盘安装“.9 - 单击”浏览“.10 - 访问指定的位置或文件夹,并访问名为”图形“的文件夹.11 - 选择名为”igdlh64“或”igdlh“的文件( 设置信息).12 - 单击“打开”,然后单击“确定”,最后单击“下一步”。 现在正在安装驱动程序.13 - 重新启动计算机完成后,请尝试再次连接显示器。 如果这不能解决问题,那么它可能与您的计算机具有混合图形的事实有关,我们不确定Nvidia控制器是否试图提供外部显示器或集成图形。 强烈建议与系统制造商讨论这个问题,以便他们能够指导您最好的方法。我希望这会有所帮助.Regards,David V 以上来自于谷歌翻译 以下为原文 Hello wmc840, Thank you for your response. I was reviewing the report you submitted and it seems to have an out-dated integrated graphics driver. It is recommended to update it so we can see if this is the root of the problem. Please download the ".zip" file from the link below: https://downloadcenter.intel.com/download/27780/Graphics-Intel-Graphics-Driver-for-Windows-15-40-?product=86210 Once downloaded, please follow the steps below to do a manual driver installation: 1 - Unzip the file to a designated location or folder. 2 - Right-click Windows Start icon and open Device Manager. 3 - Click Yes when prompted for permission from User Account Control. 4 - Expand the Display adapters section. 5 - Right-click the Intel® graphics entry and select Update Driver Software. 6 - Click "Browse my computer for driver software". 7 - Click "Let me pick from a list of device drivers on my computer". 8 - Click "Have Disk". 9 - Click "Browse". 10 - Access the designated location or folder, and access a folder called "Graphics". 11 - Select the file called "igdlh64" or "igdlh"(Setup information). 12 - Click Open, then click OK, and finally click Next. Drivers are now being installed. 13 - Reboot your computer When done, please try to connect the monitor again. If this does not address the problem then it could be related to the fact that your computer has hybrid graphics, we would be uncertain if the Nvidia controller is trying to give the external display or the integrated graphics. It is highly recommended to discuss this with the manufacturer of the system so they can guide you the best way. I hope this helps. Regards, David V |
jerry1978 发表于 2018-11-30 17:29 大卫,谢谢你花时间回应。 我没有成功安装新驱动程序。 我仍然无法访问第二台显示器。 我将尝试USB连接而不是HDMI端口。 以上来自于谷歌翻译 以下为原文 Thank you, David, for taking the time to respond. I installed the new driver without success. I still cannot access the second monitor. I will try a USB connection instead of the HDMI port. |
jerry1978 发表于 2018-11-30 17:29 我还更新了NVIDIA驱动程序。 仍然没有变化。 以上来自于谷歌翻译 以下为原文 I have also updated the NVIDIA driver. Still no change. |
Hellowmc840,感谢您的回复。在这种情况下,我建议您做的是联系系统制造商以检查它是否与硬件问题更相关。 此外,由于您的系统具有混合图形,因此必须以某种方式进行安装。对于给您带来的任何不便,我深表歉意.Regards,David V 以上来自于谷歌翻译 以下为原文 Hello wmc840, Thank you for your response. In this case, what I can recommend you to do is to contact the manufacturer of the system to check if it is more related to a hardware problem. Also because of the fact that your system has Hybrid graphics, the installation must be done in a certain way. I apologize for any inconvenience. Regards, David V |
Hellowmc840,我跟进你的情况,看到我们没有收到你的回复。你能联系制造商吗?如果你需要更多帮助,请不要犹豫回复.Regards,David V 以上来自于谷歌翻译 以下为原文 Hello wmc840, I am following up with your case and see that we have not heard back from you. Were you able to contact the manufacturer? If you need more assistance do not hesitate to reply. Regards, David V |
jerry1978 发表于 2018-11-30 18:20 还是行不通。 以下是制造商(HP)的建议: 感谢您在此论坛上发布您的查询,这是一个寻找答案的好地方。 别担心,我向你保证,我会尽力让它排序。 为了让我可以为您提供准确的解决方案,我需要更多细节。 计算机最后一次正常工作是什么时候?您是否进行了任何软件或硬件更改?搜索设备管理器,单击顶部结果以打开体验。展开显示适配器类别。 如果您仍然遇到此问题,请按照以下步骤操作。 打开Start.Search for Device Manager,然后单击顶部结果以打开体验。展开显示适配器类别。重新启动计算机。再次打开设备管理器。 如果问题仍然存在,请检查问题是否已解决。 打开Start.Search for Device Manager,然后单击顶部结果以打开体验。展开“显示适配器”类别。单击“驱动程序”选项卡。快速提示:如果“回滚驱动程序”按钮显示为灰色,则无法使用此选项 。 但是,您可能仍然可以通过下载旧版本的驱动程序从HP支持网站回滚。 让我知道它是怎么回事,你有一个美好的一天! 不工作。 我把HDMI转USB适配器。 这很好用。 以下是英特尔控制面板显示的内容。 我认为问题在于英特尔软件不允许识别两个显示器。 以上来自于谷歌翻译 以下为原文 Still not working. Here is what the manufacturer (HP) suggested: Thank you for posting your query on this forum, it's a great place to find answers. Don’t worry, I assure you I will try my best to get this sorted. In order that I may provide you with an accurate solution, I will need a few more details.
If you continue to face the issue, follow the below steps.
Check whether the issue is resolved if the issue persists continue troubleshooting.
Let me know how it goes and you have a great day! Did not work. I bot a HDMI to USB adapter. This works fine. Below is what the Intel Control panel is showing. I think the problem is that the Intel software will not allow for the recognition of two monitors. |
您好wmc840,感谢您的回复。我知道您无法解决问题。在这种情况下,我现在建议您现在要做的是将Windows版本更新为最新版本,我可以看到, 根据您提供给我的英特尔®系统支持实用程序报告,您拥有的版本是Build 10240,这是一个非常古老的Windows 10版本。更新Windows非常重要,因为最新的驱动程序已经过最新的操作系统版本测试 我希望这有帮助。大卫五 以上来自于谷歌翻译 以下为原文 Hello wmc840, Thank you for your response. I understand that you have not been able to address the problem. In this case, what I can now recommend you to do now is to update the Windows version to the latest one, I can see, according to the Intel ® System Support Utility report you have provided me, that the version you have is the Build 10240 which is a really old Windows 10 build. It is important to update Windows because the latest drivers have been tested with the latest O.S builds. I hope this helps. Regards, David V |
kasonandy 发表于 2018-11-30 18:46 操作系统版本现在显示为17134.多个显示器仍无法在英特尔软件下工作.... 以上来自于谷歌翻译 以下为原文 The OS build now shows as 17134. Multiple monitors still not working under the Intel software.... |
您好wmc840感谢您提供的信息。 您是否验证了笔记本电脑和显示器上的HDMI®版本? 这可能导致连接不兼容。 希望这有帮助。 最诚挚的问候,莱昂纳多C. 以上来自于谷歌翻译 以下为原文 Hello wmc840 Thank you for the information. Have you verified what is the HDMI® revision on both laptop and display? This could be causing an incompatibility on the connection. Hope this help. Best Regards, Leonardo C. |
我如何获得这些信息? 以上来自于谷歌翻译 以下为原文 How do I get this information? |
Hellowmc840,感谢您的回复。我正在检查,在这种情况下,为了获得您需要检查系统规格以及显示器的信息。 这些信息可以在线,或者,您可以联系不同的制造商并直接与他们核实。这很重要,因为显示器无法识别计算机通过HDMI 1.3发送的信号,例如,大卫V 以上来自于谷歌翻译 以下为原文 Hello wmc840, Thank you for your response. I was checking and in this case, in order to get the information you will need to check both the specifications of the system, as well as the monitor's. This information could be online or else, you can contact the different manufacturers and check with them directly. This is important because the monitor could not be recognizing the signal sent by the computer via HDMI 1.3 for example. Regards, David V |
Hellowmc840,我跟进你的案子,看到我们没有收到你的回复。如果你需要更多的帮助,请不要犹豫回复。大卫V 以上来自于谷歌翻译 以下为原文 Hello wmc840, I am following up with your case and see that we have not heard back from you. If you need more assistance do not hesitate to reply. Regards, David V |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-1 16:23 , Processed in 1.132754 second(s), Total 101, Slave 83 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
369
