嗨,
刚买了一台带有HD 500显卡的笔记本电脑,当笔记本电脑重新启动时,外接显示器丢失,必须再次检测。 ***的皇室痛苦。 笔记本电脑:HP G6 250(2FG08PA) 显示器:华硕23.6“VP247HA通过HDMI连接 开箱即用的笔记本电脑驱动程序版本是22 ..我升级到最新的24.和同样的事情。 发现这也发生在笔记本电脑进入睡眠状态时。 这是荒唐的。 有什么想法吗? 干杯, 法案 下面链接的这个线程的问题与HD530有相同的问题,我首先回复,OP回答说英特尔没人提供过去6个月的解决方案.. Re:HD530多显示器设置在上电时复位 老实说,我不敢相信是这种情况,因为如上所述,对于集成GPU来说,这是一个非常荒谬的错误,通常是在通常连接到外部显示器的笔记本电脑中。 请帮忙。 干杯, 法案 以上来自于谷歌翻译 以下为原文 Hi, Just bought a laptop with a HD 500 Graphics and when the laptop is restarted the external monitor is lost and must be detected again. A royal pain in the ***. Laptop: HP G6 250 (2FG08PA) Monitor: Asus 23.6" VP247HA connected by HDMI Out of the box laptop driver version was 22.. and I upgraded to the latest 24. and the same thing. Found this also happens when the laptop goes to sleep. This is ridiculous. Any ideas please? Cheers, Bill Identical issue to this thread linked below that is having the same issue with the HD530, I replied to first and the OP just replied saying no-one at Intel had provided a solution in the last 6 months.. Re: HD530 multiple monitor setting resets on powerup I honestly cannot believe that is the case, because as said above this is an a***olutely ridiculous fault for an integrated GPU which are typically in laptops which typically get connected to external monitors. Please help. Cheers, Bill |
12个回答
好吧,要获得任何帮助,请下载并运行此实用程序,并获取结果:下载适用于Windows *的英特尔®系统支持实用程序
然后,其中一位英特尔支持工程师将能够为您提供帮助。 文件 以上来自于谷歌翻译 以下为原文 Well, to get any help, download and run this utility, and ATTACH the results: Download Intel® System Support Utility for Windows* Then, one of the Intel support engineers will be able to assist you. Doc |
mapleasdf 发表于 2018-11-29 17:43 ^谢谢,作为txt文件附加 我在记录这份工作时是否遗漏了一些东西,因为在我发布之前我会非常方便地知道这件事? 此外,我之前运行过英特尔®驱动程序& 支持助手,一切都是最新的。 已经排名1/5,哇。 英特尔®驱动程序和 支持助理 适用于Windows.txt.zip的英特尔系统支持实用程序 5.6 K. 以上来自于谷歌翻译 以下为原文 ^ Thanks, attached as txt file Did I miss something when logging this job as that would have been very handy to know before I posted? Also I had previously run the Intel® Driver & Support Assistant and everything is up to date. 1/5 ranking already, wow. Intel® Driver & Support Assistant |
HenryRain 发表于 2018-11-29 18:03 感谢您的信息。 由于现在是周末,你可能在周一之前没有回复。 文件 以上来自于谷歌翻译 以下为原文 Thanks for the information. Since it is the weekend now, you may not have a response until Monday. Doc |
^很酷,再次感谢。 尝试安装DisplayFusion作为一个改变,看看它是否可行,它在第一次运行时工作,监视器已经存在但是在让笔记本电脑进入睡眠状态并唤醒它之后显示器再次消失,所以它在DisplayFusion中也丢失了,当我 我试图加载我用2台监视器创建的DisplayFusion配置文件,因为没有第二台监视器。 这是可以预期的,因为作为一个应用程序,它依赖于由英特尔高清图形控制面板控制的硬件和硬件,并且由于这不起作用,我无法看到如何解决这个问题? 以上来自于谷歌翻译 以下为原文 ^ Cool, thanks again. Tried installing DisplayFusion as an alterrnative to see if that might work, it worked when first ran and the monitor was already there but after putting the laptop to sleep and waking it the monitor was gone again and so it was also missing in DisplayFusion and when I tried to load the DisplayFusion profile I created with the 2 monitors that failed because there was no second monitor. This was to be expected given that as an application it relies upon the hardware, hardware which is controlled by the Intel HD Graphics Control Panel, and since that doesn't work I can't see how this can be fixed? |
您好likwidsh0k,感谢您加入英特尔社区。您使用HDMI转HDMI电缆吗?
如果可能,请尝试使用VGA到VGA线。我希望您尝试按特定顺序重新安装某些计算机驱动程序。请安装此驱动程序,然后重新启动计算机https://support.hp.com/us-en / drivers / selfservice / swdetails / hp-250-g6-notebook-pc / 15747807 / model / 15747881 / swItemId / ob-190404-1?sku = 2FG08PA安装此其他驱动程序,并再次重启计算机https:// support .hp.com / us-en / drivers / selfservice / swdetails / hp-250-g6-notebook-pc / 15747807 / model / 15747881 / swItemId / ob-184046-1?sku = 2FG08PAPlease下载此图形驱动程序 链接,但不要安装它https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-250-g6-notebook-pc/15747807/model/15747881/swItemId/ob-186798- 1?sku = 2FG08PAOnce已下载图形驱动程序,请按照以下步骤操作:1。 断开计算机与Internet2的连接。 右键单击“开始”按钮,然后单击“设备管理器3”。 双击显示适配器 - >英特尔(R)HD Graphics 500 - >驱动程序选项卡,然后选择卸载 - >选中复选框删除此设备的驱动程序软件4。 重启电脑5。 返回“设备管理器” - >“显示适配器”,然后检查操作系统是否重新安装了图形驱动程序。 如果Windows重新安装了另一个图形驱动程序,请返回步骤3,直到获得Microsoft Basic Display Adapter.6。 重新安装我在上面提供的图形驱动程序。 启用Internet连接。还请从另一个链接安装显示器驱动程序http://dlcdnet.asus.com/pub/ASUS/LCD%20Monitors/VP247/VP247_WHQL_20160510.zip让我知道问题是否仍然存在.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello likwidsh0k, Thank you for joining the Intel Communities. Are you using HDMI to HDMI cable? If possible try VGA to VGA cable as well. I would like you to try reinstalling some of the computer drivers in a specific order. Please install this driver, and then restart the computer https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-250-g6-notebook-pc/15747807/model/15747881/swItemId/ob-190404-1?sku=2FG08PA Install this other driver, and restart the computer one more time https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-250-g6-notebook-pc/15747807/model/15747881/swItemId/ob-184046-1?sku=2FG08PA Please download the graphics driver that is on this link, but do not install it yet https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-250-g6-notebook-pc/15747807/model/15747881/swItemId/ob-186798-1?sku=2FG08PA Once the graphics driver has been downloaded follow the next steps: 1. Disconnect the computer from the Internet 2. Right click on Start button, and then click on Device Manager 3. Double click on Display Adapters -> Intel(R) HD Graphics 500 -> Driver tab, and select Uninstall -> Select the check box Delete the driver software for this device 4. Restart the computer 5. Go back to Device Manager -> Display Adapters, and check if the operating system reinstalled a graphics driver. If Windows reinstalled another graphics driver go back to Step 3 until you get the Microsoft Basic Display Adapter. 6. Reinstall the graphics driver I provided above. 7. Enable Internet connection. Please also install the monitor driver from this other link http://dlcdnet.asus.com/pub/ASUS/LCD%20Monitors/VP247/VP247_WHQL_20160510.zip Let me know if issue persists or not. Regards, Fred D. |
jerry1978 发表于 2018-11-29 18:44 编辑:抓住这一切,但保持这... 再加上你的论坛不记得你。 以上来自于谷歌翻译 以下为原文 EDIT: Scratch all that, but kept this... Plus your forums dont remember you. |
你好likwidsh0k,我在我们的网站(24.20.100.6229)上测试了我们在不同图形控制器上的最新图形驱动程序,但我无法重现你遇到的问题。 我在双显示器上测试系统,将它们置于睡眠模式,重新启动它们,从冷启动尝试它们,系统记住我设置的扩展桌面设置。您是否尝试过联系HP *以获得其他一些故障排除步骤? 我不确定您遇到的问题是与操作系统有关还是与您的特定系统有关的硬件问题。 HP *在其网站上提供的驱动程序已经过测试和验证,可以在您的特定计算机型号中正常运行。 此链接将为您提供HP *联系信息https://support.hp.com/us-en/contact-hpRegards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello likwidsh0k, I tested the latest graphics driver we have on our website (24.20.100.6229) on different graphics controllers, but I was not able to reproduce the issue you are having. I tested the systems in dual display, put them on sleep mode, restarted them, tried them from a cold boot, and the systems remembered the extended desktop setting I set. Have you tried contacting HP* in order to get some other troubleshooting steps? I am not sure if the issue you are having is related to either the operating system or a hardware issue with your specific system. The drivers HP* provides on their website have been tested and validated to work fine in your specific computer model. This link will give you HP* contact information https://support.hp.com/us-en/contact-hp Regards, Fred D. |
jerry1978 发表于 2018-11-29 19:07 嗨弗雷德, 我试过VGA线,它工作,抱歉。 如果VGA电缆工作,这意味着我的HDMI电缆可能有问题吗? 可能会看到我如何解决空白屏幕问题。 干杯 编辑:我怀疑空白屏幕问题可能是我的登录屏幕显示在外部显示器上,但然后通过HDMI不起作用,所以接受我的按键但我无法看到它们然后当我按下电源键 lappie然后用不正确的密码键将屏幕转移到lappie屏幕。 现在使用VGC电缆并重新启动或从睡眠状态唤醒外部监视器屏幕使用密码提示,所有工作都完美。 所以,可能是HDMI线或HDMI上的外接显示器每次都需要手动检测显示器,但是使用VGA可以正常工作。 可惜HDMI很方便,因为它将声音传到显示器上并使用lappie上的堆酮端口用于耳机,并且可以在两者之间切换,我现在没有选择。 对不起我的随意。 所以新的问题是为什么HDMI不起作用? 以上来自于谷歌翻译 以下为原文 Hi Fred, I tried the VGA cable and it works, sorry about that. If the VGA cable works does that mean maybe the HDMI cable I have is at fault? Might see how I can fix the blank screen issue. Cheers Edit: I suspect the blank screen issue might have been that my logon screen was showing on the external monitor but was then over HDMI which doesnt work and so was accepting my key presses but I couldnt see them and then when i hit the power key on the lappie it then transferred that screen to the lappie screen with my incorrect password key presses. Now using VGC cable and restarting or waking from sleep the external monitor screen works with password prompt and all works perfectly. So yeah it may be the HDMI cable or that an external monitor over HDMI you need to manually detect the monitor each time, but with VGA it is working. Pity as HDMI was handy as took sound to the monitor and used the heaphone port on the lappie for headphones and could switch between the two, I don't have the option now. Sorry for my ramblings. So new question is why doesnt HDMI work? |
你好likwidsh0k,由于VGA端口工作正常,问题可能是HDMI线,显示器上的hdmi端口,笔记本电脑上的硬件问题或Windows *的问题。如果可能尝试另一条HDMI线或测试你目前有的电缆 在另一个系统上。如果可用,请尝试另一个HDMI显示器(显示器或电视)。如果显示器和电缆都工作正常,那么问题很可能与计算机本身有关。 在这种情况下,最好的选择是联系笔记本电脑制造商,以便他们可以确定这是硬件问题还是Windows *中的某种配置问题.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello likwidsh0k, Since VGA port works fine then the issue could be either the HDMI cable, the hdmi port on the monitor, hardware issue on the laptop or a problem with Windows*. If possible try another HDMI cable or test the cable you currently have on another system. If available, try another HDMI display (monitor or TV). If both monitor and cable work fine then the issue most likely will be related to the computer itself. In this case the best option would be contacting the laptop manufacturer so they can determine if this is a hardware issue or some type of configuration problem in Windows*. Regards, Fred D. |
jerry1978 发表于 2018-11-29 19:27 嗨弗雷德, 再次感谢你的回复。 好吧......这很令人尴尬,HDMI现在完美运行。 根据你的建议尝试我的三星电视通过HDMI,这是有效的,所以再次尝试lappie并完美地工作,如果我让它睡觉或如果我重新启动两个外部显示器醒来,等待我登录。 我真诚的道歉,我不知道发生了什么,因为以前一定没有用,我所能猜测的可能就是VGA唤醒了什么,我不知道,也许530的人也可以先尝试VGA? 感谢你在我失去冷静时的所有帮助,气质和耐心。 Stoked this已经排序,现在可以关闭工作,但除了VGA之外没有真正的答案。 干杯 以上来自于谷歌翻译 以下为原文 Hi Fred, Thanks again for the reply. And well... this is embarrassing, the HDMI works perfectly now. On your advice tried my Samsung TV over HDMI and that worked, so tried the lappie again and worked perfectly, if I put it to sleep or if I restart with both the external monitor wakes up and waiting for me to logon. My sincere apologies, I have no idea what happened as definitely didn't work before, all I can surmise is maybe the VGA woke something up, I dunno, maybe the guy with the 530 could try the VGA first too? Thanks for all your help, temperament and patience when I lost my cool. Stoked this is sorted and can close the job now, though no real answer except maybe the VGA. Cheers |
jerry1978 发表于 2018-11-29 19:27 嗨弗雷德, 一个快速友好的碰撞,它现在完美地工作,其中一个奇怪的PC事情,不知道为什么,但尝试VGA后HDMI工作。 只是碰撞所以你可以关闭线程。 再次感谢。 以上来自于谷歌翻译 以下为原文 Hi Fred, A quick friendly bump that its working perfectly now, one of those odd PC things that no idea why but after trying the VGA the HDMI worked. Just bumping so you can close the thread. Thanks again. |
jerry1978 发表于 2018-11-29 19:43 你好likwidsh0k,我很高兴听到电脑现在工作正常。 如果您有任何其他疑问,请不要犹豫与我们联系.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello likwidsh0k, I am glad to hear computer is working fine now. Do not hesitate in contacting us back if you have any other inquiry. Regards, Fred D. |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-20 08:04 , Processed in 0.786182 second(s), Total 78, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
