电子发烧友论坛|
您好,我正在尝试更新我的Skull Canyon NUC上的固件以使用Sonnet Breakaway Box eGPU。
我正在运行Windows 10 64位 NUC BIOS版本/日期最新系统BIOS英特尔公司KYSKLi70.86A.0055.2018.0516.1629,5 / 16/2018 Thunderbolt软件17.2.71.250 霹雳一代霹雳3(1575) NVM固件版本18.05 我正在尝试更新到最新的NVM固件 - 版本27失败,版本25也失败了。 它给出错误:“错误:获取PD固件版本时出现0x10A 266错误” 运行Thunderbolt 3固件更新时,始终会连接Sonnet Breakaway Box eGPU。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am trying to update the firmware on my Skull Canyon NUC to use a Sonnet Breakaway Box eGPU. I am running Windows 10 64bit Latest System BIOS on NUC BIOS Version/Date Intel Corp. KYSKLi70.86A.0055.2018.0516.1629, 5/16/2018 Thunderbolt software 17.2.71.250 Thunderbolt generation Thunderbolt 3 (1575) NVM Firmware version 18.05 I am trying to update to the latest NVM Firmware -- version 27 fails, as does version 25. It gives error: "Error: 0x10A 266 Error while getting the PD firmware version" The Sonnet Breakaway Box eGPU is always attached when running the Thunderbolt 3 Firmware Update. Thanks! |
5个回答
您好hornedfrog,感谢您在我们的英特尔社区提交此问题。为了更好地帮助您,我想收集有关您在计算机中配置的更多信息。
请在.txt文件中附上.txt文件,英特尔®系统支持实用程序将生成https://downloadcenter.intel.com/download/25293/Intel-System-Support-UtilityPlease让我知道您的固件更新的下载链接 尝试安装。要附加文件,必须单击响应框右上角的“使用高级编辑器”,然后“附加”选项将出现在响应框的右下角.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello hornedfrog, Thanks for submitting this question on our Intel Communities. In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Please let me know the download link of the firmware update you are trying to install. To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box. Regards, Fred D. |
jerry1978 发表于 2018-11-27 12:25 谢谢,我搞定了。 也许我正在与Tbolt托盘图标进行交互,因为它提到不做? 以上来自于谷歌翻译 以下为原文 Thank you, I got it working. Perhaps I was interacting with the Tbolt tray icon as it mentions not do do? |
你好hornedfrog,你是如何解决这个问题的?eGPU如何使用英特尔®NUC套件NUC6i7KYK?这是你的吗? https://www.sonnettech.com/product/egfx-breakaway-box.htmlRegards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello hornedfrog, How did you fix the issue? How is the eGPU working with the Intel® NUC Kit NUC6i7KYK? Is this the one you have? https://www.sonnettech.com/product/egfx-breakaway-box.html Regards, Fred D. |
jerry1978 发表于 2018-11-27 12:43 你好 我仔细按照说明操作,没有与Thunderbolt的系统托盘图标进行交互,我点击了该图标来检查驱动器和固件版本。 我第一次更新了Thunderbolt软件,它看到了这个盒子,但我的NVM固件版本18.05没有断开连接。 经过5次尝试后,我重新启动了更新程序,更新程序现在在NVM固件版本27上运行。 是的,我有这个方框:https://www.sonnettech.com/product/egfx-breakaway-box.html 我非常喜欢盒子和GFX速度升级,它安静而快速。 它现在也正常断开连接,当我移动NUC时我可以立即使用Iris Pro 580。 谢谢, 艾伦 以上来自于谷歌翻译 以下为原文 Hi I followed the directions carefully and did not interact with the system tray icon for Thunderbolt which I had clicked on to check for drive and firmware versions. I first updated the Thunderbolt software and it saw the box but my NVM Firmware version 18.05 did not disconnect. After 5 tries I did a fresh reboot and the updater worked now at NVM Firmware version 27. Yes, I have this box: https://www.sonnettech.com/product/egfx-breakaway-box.html I really like to box and the GFX speed upgrade, it is quiet and fast. It now disconnects properly too and I can use the Iris Pro 580 instantly when I move the NUC. Thanks, Allan |
csyyyyy 发表于 2018-11-27 12:58 您好hornedfrog,感谢您提供给我们的其他详细信息。 我希望这些信息有助于其他社区同行.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello hornedfrog, Thanks for the additional details you are providing to us. I hope this information helps other Community peers. Regards, Fred D. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 01:44 , Processed in 0.767072 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2382
