电子发烧友论坛|
嗨,大家好,
我是STM社区和那些微控制器的新手,我正在学习使用它们;) 我已经通过DMA配置了基于SPI的通信,除了SCK之外,一切都正常工作。我将其配置为低电平而非有效,这是SPI模块处于活动状态且时钟信号切换时的情况,但在此期间SCK为高电平。 如何强制SCK降低? #spi 以上来自于谷歌翻译 以下为原文 Hi everyone, I'm new to the STM community and those microcontrollers too, I'm learning to use them;) I've configured a communication based on SPI through DMA, everything is working excepting the SCK. I've configured it to be low while inactive, this is the case when the SPI module is active and the clock signal toggling, but outside this period the SCK is high. How is it possible to force the SCK to be low? #spi |
2个回答
发现''问题',
我来自MSP430世界,每个模块都可以被禁用以备用电源但保持配置(好的粗略解释:p)。我想用STM8L做同样的事情并且仅在通信需要时启用SPI和DMA模块,但实际上我无法禁用SPI模块或引脚松动配置,不知道这是否会增加功耗系统,但我想是的。 以上来自于谷歌翻译 以下为原文 ''Problem'' found, I come from the MSP430 world, each module could be disabled to spare power but keep the configuration (ok rough explanation:p). I wanted to do the same with STM8L and enable the SPI and DMA module only while required for communication, but in fact I can't disable the SPI module or the pin loose the configuration, don't know if this will increase the power consumption of the system, but I think so. |
好的,最后让模块正常工作......
我所做的是我手动''控制SCK引脚并强制它输出低电平,然后禁用SPI模块。 为了开始通信,我启用SPI模块,然后让SPI模块控制SCK将引脚设置为外部上拉。 因此更容易处理MSP430中的低功耗特性;)ST应该制作关于如何优化这些事情的应用说明,至少这篇文章应该有所帮助,即使这个论坛上没有人也没有;) 以上来自于谷歌翻译 以下为原文 Ok, finally make the module working as I want... What I do is that I ''manually'' take the control on the SCK pin and force it to output low before disabling the SPI module. And for starting a communication, I enable the SPI module and then let the SPI module control the SCK setting the pin as external pull up. So more easy to handle the low power feature in MSP430;) ST should make an app note on how to optimize such things, at least this post should help, even if there is quite nobody on this forum;) |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 06:11 , Processed in 0.659490 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3442
