我试图在我的64位Linux系统上安装iMPACT。
由于我使用的是非常新的udev版本,我不得不手动更新udev规则以加载固件。 我得到了这个工作,所以当我将电缆插入电脑时,程序员的灯变绿了。 令我惊讶的是,iMPACT仍在抱怨缺少司机。 我甚至尝试将环境变量设置为使用'force'lib-u***用法(虽然它应该是我的11.4版本的默认值) 除了预装了固件的设备外,iMPACT还需要什么? 以上来自于谷歌翻译 以下为原文 I am attempting to install iMPACT on my 64-bit linux system. Since I was using a very new udev version, I had to manually update the udev rules to get the firmware to load. I got this working so when I plug the cable into my computer, the light on the programmer turns green. To my amazement however, iMPACT is still complaining about missing drivers. I even tried setting the environment variable to use 'force' lib-u*** usage (although it should be default for my 11.4 version) What does iMPACT need besides the device with its firmware preloaded? |
3个回答
我从系统中删除了驱动程序并安装了开源lib-u***驱动程序。
这解决了我的问题:) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I removed the drivers from my system and installed the open-source lib-u*** driver. This solved my problem :)View solution in original post |
这解决了我的问题:) 以上来自于谷歌翻译 以下为原文 I removed the drivers from my system and installed the open-source lib-u*** driver. This solved my problem :) |
这只是为了阐述未来可怜的灵魂。
这适用于以下的ISE 13.1: root @ leno:/opt/Xilinx/13.1/ISE_DS/ISE/bin/lin# uname -a Linux leno 2.6.35-27-generic#48-Ubuntu SMP Tue Feb 22 20:25:29 UTC 2011 i686 GNU / Linux root @ leno:/opt/Xilinx/13.1/ISE_DS/ISE/bin/lin#l***_release -a 没有LSB模块可用。 分销商ID:Ubuntu 描述:Ubuntu 10.10 发布:10.10 代号:特立独行 更多信息: http://rmdir.de/~michael/xilinx/ http://translate.google.com/translate?js=n&prev=_t&hl=da&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http% 3A%2F%2Fcs.stu.cn.ua%2Fpost%2F888%2F&安培; ACT = URL 我选择在$ XILINX / cable中添加addtional东西: ei***aw @ leno:〜$ ls /opt/Xilinx/13.1/cable/ ei***aw_startise.sh libu***-driver.so 确保您的开始脚本以下面的行结束,即: ei***aw @ leno:〜$ tail -n 3 /opt/Xilinx/13.1/cable/ei***aw_startise.sh #http://cs.stu.cn.ua/post/888/ export LD_PRELOAD = / opt / Xilinx / 13.1 / cable / libu***-driver.so exec /opt/Xilinx/13.1/ISE_DS/ISE/bin/lin/ise //////////////////// USB线的注意事项(摘自http://git.zerfleddert.de/cgi-bin/gitweb.cgi/u***-driver?a=blob_plain;f=README;hb=HEAD) ======================= 要将设备用作普通用户,请将以下行添加到新用户中 /etc/udev/rules.d/中的文件“libu***-driver.rules”并重新启动udev: ACTION ==“add”,SUBSYSTEMS ==“u***”,ATTRS {idVendor} ==“03fd”,MODE =“666” 如果您的电缆在lsu***的输出中没有ID 03fd:0008, 尚未加载初始固件(加载它会更改 product-ID从另一个值到8)。 要加载固件,请按照 这些步骤: 1.如果您没有/etc/udev/rules.d/xu***dfwu.rules文件,请从中复制 /opt/Xilinx/13.1/ISE_DS/ISE/bin/lin/xu***dfwu.rules到/etc/udev/rules.d/xu***dfwu.rules 2.如果您正在运行更新版本的udev(如Debian Squeeze和 Ubuntu 9.10),你需要将rules-file改编为新的udev-version: sed -i -e's / TEMPNODE / tempnode /'-e's / SYSFS / ATTRS / g'-e's / BUS / SUBSYSTEMS /'/etc/udev/rules.d/xu***dfwu.rules 3.从Linux发行版安装包含/ ***in / fxload的软件包。 它通常被称为“fxload” 4.将文件/path/to/ISE/bin/lin/xu****.hex复制到/ usr / share / 5.重启udev 服务udev重启 6.插入电缆 如果连接了多根电缆,则可以指定要使用的电缆 在XILINX_USB_DEV环境中变量为“bus:device”。 这些标识符在lsu***的输出中可用: 总线001设备004:ID 03fd:0008 Xilinx,Inc。 ^^^ ^^^ 要使用此电缆,请将XILINX_USB_DEV变量设置为“001:004”。 以上来自于谷歌翻译 以下为原文 This is just to elaborate for future poor souls.This works with ISE 13.1 as of: root@leno:/opt/Xilinx/13.1/ISE_DS/ISE/bin/lin# uname -a Linux leno 2.6.35-27-generic #48-Ubuntu SMP Tue Feb 22 20:25:29 UTC 2011 i686 GNU/Linux root@leno:/opt/Xilinx/13.1/ISE_DS/ISE/bin/lin# l***_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 10.10 Release: 10.10 Codename: maverickMore info: http://rmdir.de/~michael/xilinx/ http://translate.google.com/translate?js=n&prev=_t&hl=da&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fcs.stu.cn.ua%2Fpost%2F888%2F&act=urlI chose to put addtional stuff in $XILINX/cable: ei***aw@leno:~$ ls /opt/Xilinx/13.1/cable/ ei***aw_startise.sh libu***-driver.soMake sure that your start script end with the lines below, ie: ei***aw@leno:~$ tail -n 3 /opt/Xilinx/13.1/cable/ei***aw_startise.sh # http://cs.stu.cn.ua/post/888/ export LD_PRELOAD=/opt/Xilinx/13.1/cable/libu***-driver.so exec /opt/Xilinx/13.1/ISE_DS/ISE/bin/lin/ise////////////////////Notes for the USB cable (taken from http://git.zerfleddert.de/cgi-bin/gitweb.cgi/u***-driver?a=blob_plain;f=README;hb=HEAD)=======================To use the device as an ordinary user, put the following line in a newfile "libu***-driver.rules" in /etc/udev/rules.d/ and restart udev:ACTION=="add", SUBSYSTEMS=="u***", ATTRS{idVendor}=="03fd", MODE="666"If your cable does not have the ID 03fd:0008 in the output of lsu***,the initial firmware has not been loaded (loading it changes theproduct-ID from another value to 8). To load the firmware followthese steps:1. If you have no /etc/udev/rules.d/xu***dfwu.rules file, copy it from /opt/Xilinx/13.1/ISE_DS/ISE/bin/lin/xu***dfwu.rules to /etc/udev/rules.d/xu***dfwu.rules2. If you are running a newer version of udev (as in Debian Squeeze and Ubuntu 9.10), you need to adapt the rules-file to the new udev-version: sed -i -e 's/TEMPNODE/tempnode/' -e 's/SYSFS/ATTRS/g' -e 's/BUS/SUBSYSTEMS/' /etc/udev/rules.d/xu***dfwu.rules3. Install the package containing /***in/fxload from your linux distribution. It is usually called "fxload"4. copy the files /path/to/ISE/bin/lin/xu****.hex to /usr/share/5. restart udev service udev restart6. Plug in the cableIf you have multiple cables connected, you can specify the cable to usein the XILINX_USB_DEV environment-variable as "bus:device".These identifiers are available in the output of lsu***:Bus 001 Device 004: ID 03fd:0008 Xilinx, Inc. ^^^ ^^^To use this cable, set the XILINX_USB_DEV variable to "001:004". |
只有小组成员才能发言,加入小组>>
2177 浏览 7 评论
2614 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3155 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2202 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
444浏览 1评论
1536浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2183浏览 0评论
513浏览 0评论
1655浏览 0评论
GMT+8, 2024-5-8 12:44 , Processed in 1.164534 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
