电子发烧友论坛|
您好 - 我负责通过MS SCCM为我的雇主打包和部署各种驱动程序作为个人/独立应用程序或软件包,最近遇到了一些问题,其中包括IGXPIN.EXE或IGXPUN.EXE(作为Intel的一部分)
驱动程序安装)在部署日志中抛出错误,然后无法部署有问题的驱动程序。 我们经常可以通过DPINST.EXE来完全使用它们,但是如果我们使用DPINST,那么在制作卸载程序时会有额外的复杂性,所以在可能的情况下我更愿意使用英特尔提供的安装实用程序(虽然是静默的)。 所以基本上,我发帖询问是否有这两个可执行文件的错误代码列表及其含义? 最近我们在安装英特尔高清显卡520和620时使用了IGXPIN的退出代码65和4(使用来自英特尔和原厂的确认正确的驱动程序),但我们在没有参考这些代码含义的情况下进行故障排除很困难 。 任何帮助将被感激地接受! 提前致谢... 以上来自于谷歌翻译 以下为原文 Hi there - I'm responsible for packaging and deploying various drivers as individual/standalone applications or packages via MS SCCM for my employer, and more recently have experienced a few problems where either IGXPIN.EXE or IGXPUN.EXE (as part of an Intel driver install) threw up an error in the deployment logs, and subsequently failed to deploy the driver in question. We can often get around using them altogether via DPINST.EXE, but there's an extra level of complexity in crafting an uninstaller if we use DPINST, so where possible I'd prefer to use the provided install utility from Intel (albeit silently). So basically, I'm posting to ask if there's a list of error codes and their meanings for these two executables? Most recently we've seen exit codes 65 and 4 from IGXPIN when installing Intel HD Graphics 520 and 620 (using confirmed correct drivers, both from Intel and OEM), but we're having difficulty troubleshooting without a reference to the meanings of those codes. Any help would be gratefully accepted! Thanks in advance... |
3个回答
Hellojongrandin感谢您加入社区。我看到您正在寻找GBXPIN.EXE和IGXPUN.EXE的错误代码列表。
请允许我与您分享,为了向您提供有关开发或编程的更好帮助,请参阅我们的英特尔®开发人员专区(https://software.intel.com/en-us/support)以便为您提供更好的帮助 关于这个话题。 希望他的帮助。 此致,莱昂纳多C. 以上来自于谷歌翻译 以下为原文 Hello jongrandin Thank you for joining the community. I see that you are looking for error code list for the IGXPIN.EXE and IGXPUN.EXE. Allow me to share with you that in order to provide you with better assistance about developing or programming please refer to our Intel® developer zone (https://software.intel.com/en-us/support) to provide you with better assistance on the topic. Hope his help. Regards, Leonardo C. |
jerry1978 发表于 2018-11-22 06:37 嗨莱昂纳多, 我实际上不是一个开发人员 - 只是一个系统管理员,而我所要做的就是使用无人值守的安装命令,通过常规的MS ADT脚本从Microsoft SCCM部署标准的Intel驱动程序。 我实际上并没有做任何与开发相关的事情。 我查看了您提供的链接,但这与此问题无关。 基本上,当英特尔的IGXPIN.EXE广告IGXPUN.EXE安装程序使用适当的静默/无人值守开关从提升的命令提示符执行时,它们工作正常,而(在我们的环境中,至少)当SCCM将它们作为LOCAL SYSTEM启动时,它们会抛出 出错并无法安装。 不幸的是,退出代码没有任何进一步的描述,这就是为什么我问英特尔是否可以提供退出/错误代码列表及其对这两个标准英特尔安装程序的含义,以便我可以找出为什么安装是 失败。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi Leonardo, I'm not actually a developer - just a systems administrator, and all I'm trying to do is to deploy standard Intel drivers from Microsoft SCCM using an unattended install command, via the regular MS ADT scripts. I'm not actually doing anything related to development. I checked the link you provided, but it's not relevant to this issue. Basically, when Intel's IGXPIN.EXE ad IGXPUN.EXE installers are executed from an elevated command prompt with the appropriate silent/unattended switches, they work fine, whereas (in our environment, at least) when SCCM launches them as LOCAL SYSTEM, they throw up an error and fail to install. Unfortunately the exit code doesn't come with any further description, which is why I asked if Intel can provide a list of exit/error codes and their meanings for these two standard Intel installers, in order that I can work out why the installation is failing. Thanks. |
cd340823 发表于 2018-11-22 06:48 Hellojongrandin,感谢您的回复。在这种情况下,您被转介到那里是因为他们是处理您正在寻找的信息的人。 您可以随时注册然后加入他们的支持论坛,然后您可以在那里发布,您将获得所需的帮助。注意,David VIntel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello jongrandin, Thank you for your response. In this case, you have been referred there because they are the ones who handle this information that you are looking for. You can always register and then join their support forums, you can then post there and you will be getting the assistance you need. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 13:52 , Processed in 0.678170 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3925
