电子发烧友论坛|
亲爱的All,我已经购买了新的53210A,并尝试使用Agilent Interactive IO进行写入和读取,结果是:*连接到:USB0 :: 0x0957 :: 0x1707 :: MY50002282 :: 0 :: INSTR - > * IDN?
但是,我在53210a看到显示:“ERR”,“ERR”的含义是什么以及如何解决这个问题? 我在vc#2008 express的文件夹“Basic_Measurement”中尝试了示例,当我按下连接按钮时,结果是“Agilent Technologies,53210A,MY50002282,01.12-1313.3321-1.19-4.10-127-154-35”,我认为 沟通是好的,但按下进行测量时我有问题:1。“ERR”在53210A 2. VI_ERROR_TMO:发生超时如何修复此错误? 请分享 以上来自于谷歌翻译 以下为原文 Dear All, I have bought new 53210A, and tried to write and read with Agilent Interactive IO, the result is: * Connected to: USB0::0x0957::0x1707::MY50002282::0::INSTR -> *IDN? <- Agilent Technologies,53210A,MY50002282,01.12-1313.3321-1.19-4.10-127-154-35 But, I saw at 53210a display : "ERR", what is the means of "ERR" and how to fix this ? I have tried example at folder "Basic_Measurement" with vc# 2008 express, when I press connect button, the result is "Agilent Technologies,53210A,MY50002282,01.12-1313.3321-1.19-4.10-127-154-35", I think the communication is good, but I have problem when press Make Measurement: 1. "ERR" at 53210A 2. VI_ERROR_TMO: A timeout occurred How to fix this error? please share |
1个回答
“Err”是错误信号器,表示仪器内发生编程错误。
打开Interactive IO后,按“SYST:ERR?” 键。 这将读取53210A错误队列并显示错误消息。 可能需要按“SYST:ERR?” 多次出现错误的情况。 清除错误队列时,返回+0,“无错误”。 发生超时是因为错误导致计数器在为Interactive IO设置的超时时间内未完成测量。 (此设置位于Interactive IO“选项”键下。)错误消息应描述导致错误的原因。 一旦导致错误的条件得到纠正,就不再发生超时。 以上来自于谷歌翻译 以下为原文 "Err" is the error annunciator indicating a programming error occurred within the instrument. With Interactive IO open, press the "SYST:ERR?" key. This will read the 53210A error queue and display the error message. It may be necessary to press "SYST:ERR?" multiple times in the event there is more than one error. When the error queue is cleared, +0, "No Error" is returned. The time out occurred because the error caused the counter to not complete the measurement within the timeout period set for Interactive IO. (This setting is located under the Interactive IO "Options" key.) The error message should describe what caused the error. Once the condition causing the error is corrected, the time out should no longer occur. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 10:09 , Processed in 0.797734 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3890
