你好,我刚刚开始体验这个问题。首先,一切都很好,程序以秒为单位进行编译,这是意料之中的事。然后,如果没有改变,现在程序的编译时间大约是4分钟!(我正在使用XC8)。我卸载了所有Java和所有旧版本的MPLABX,重新安装了40.5版本,重新启动计算机。经过这些步骤,编译又快了。现在,两天后,我打开电脑,编译时间又是4分钟。因为这个问题随着卸载/重新启动而消失了,看来它必须是MPLABX的一个bug /问题/不兼容。也许有些东西已经知道了?每次我需要编译4分钟是不可能的…谢谢,塞尔吉奥
以上来自于百度翻译 以下为原文 Hello, I started experiencing this problem a short while ago. Firstly everything is ok, and the program is compiling in seconds as would be normal to expect. then, without a change, now the compiling time for the same program is around 4 minutes!! (I'm using XC8). I uninstalled all Java and all older versions of MPLABX, reinstalled version 40.5 afterwards, rebooted computer. After these steps, compile is fast again. Now, two days after, I turn on the computer, and the compile time is 4 minutes again. Since the problem went away with uninstalling/reboot, it seem that it must be a bug/problem/incompatibility of MPLABX... Maybe something already knew?? It's impossible to work with 4 minutes each time I need to compile... Thanks, Sergio |
10个回答
你试过清除MPLABX“缓存”文件夹吗?我认为“帮助”盒子告诉你他们在哪里。
以上来自于百度翻译 以下为原文 Have you tried clearing the MPLABX "cache" folders? I think the "Help About" box tells you where they are. |
是的,在卸载之前,我试过了,对不起,我忘了提了。
以上来自于百度翻译 以下为原文 Yes, before uninstalling I tried that, sorry I forget to mention. |
这个问题已经解决了,但我还是不知道是什么引起的,让我们看看它是否会回来。在我的第一篇文章之后,我卸载了所有的XC8编译器,重新启动并尝试再次安装XC8。它被卡住了,酒吧没有动。我在另一个论坛上读到了关于屏幕分辨率的内容,所以我做了如下的描述:改变分辨率为1080;关闭Windows缩放;重新启动;安装XC8;将设置返回到原来是什么。在此之后,它成功安装,现在它在20秒内编译。只是不知道什么时候才会好。
以上来自于百度翻译 以下为原文 The issue is resolved, but I still don't know what caused it and let's see if it doesn't come back! After my first post, I uninstalled all XC8 compilers, reboot and tried to install xc8 again. It was stuck and the bar didn't move. I read something on another forum, about the screen resolution, so I did what was described there: - Change resolution to 1080; turn off windows scaling; reboot; install XC8; turn settings back to what is was. After this, it installed successfully and now it compiles in ~20 seconds. Just don't know until when it will be ok. |
尝试关闭病毒扫描器进行编译运行。“编译程序”对你意味着什么?你的项目只有一个C文件吗?还是很多?建筑的所有步骤都减慢了,还是只有一个?您是否尝试通过项目视图中的上下文菜单编译单个C文件?您可以使用SysStudioPalm监视器来查看MPLABX或XC8编译器在文件系统上的构建过程,以及每一步需要多长时间。但是如果您从未使用过它,那么解释(和过滤大量数据)是困难的,所以我只做最后的选择。没有其他的想法。
以上来自于百度翻译 以下为原文 Try to turn off the virus scanner for a compile run. What does "compiling the program" mean for you ? Does your project have just one C file ? Or many ? Are all steps of the Build slowed down or only a specific one ? Did you try to compile a single C file e.g. via context menu in the project view ? You could use Sysinternals Process Monitor to see what the Build Process of MpLabX or the XC8 compiler actually do on your file system, and how long each step takes. But interpretation (and filtering of the tons of data) is difficult if you never used it, so I would only do that as a last resort, if there are no other ideas. |
如果它真的回来了,那可能是硬盘的问题。希捷?第二,MPLAB X是在线的,等待繁忙的服务器。
以上来自于百度翻译 以下为原文 If it does come back then it may be a problem with your hard disk. Seagate? Secondly, is mplab x going online and waiting for a busy server. |
在解决之前也尝试过了。不起作用。从构建过程开始,每一行需要几秒钟,不管进程的哪个部分。不要这么想……不。
以上来自于百度翻译 以下为原文 Tried it also before resolving. Didn't work. Since the start of the build process, it took several seconds for each line, regardless of which part of the process. Don't think so... No. |
创建一个新项目并将原始代码复制到新项目中。也许Windows做了一些关键的更新。检查任务调度器和任务管理器(如果它再次发生,希望它不会发生)。
以上来自于百度翻译 以下为原文 Create a new project and copy your original code into the new project. Maybe Windows did some crucial update. Check Task Scheduler and also Task Manager. (If it happens again, hopefully it will not) |
嗨,这也可能是防病毒扫描“积极”文件夹的MPLAB X(只是排除它们)。
以上来自于百度翻译 以下为原文 Hi, It could also be that the antivirus is scanning "aggressively" the folders of MPLAB X (just exclude them). Regards |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
508 浏览 0 评论
5813 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3545 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-15 03:48 , Processed in 1.146780 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1596
