扫一扫,分享给好友
我收到这条消息:
“安装过程中遇到以下错误: 11:无法找到存档按重试再试一次,否则按取消退出安装“ 操作系统:windows xp professionalsp2 取消安装后,似乎ise正在工作,我甚至更新了软件 但我怎么知道是否缺少某些东西? 谢谢 以上来自于谷歌翻译 以下为原文 i got this message: "the following erro was encountered during installation: 11: archive could not be located press retry to try again, otherwise press cancel to exit the installation" OS : windows xp professional sp2 after cancelling the installation it seems that ise is working and i even updated the software but how can i know if somthing is missing? thanks |
3个回答
错误发生在什么时候?
我不知道如何检查你是否遗漏了一些东西,除了将文件和文件夹与已知的工作安装进行比较,或者只是等到某些东西不起作用。 如果在安装过程中出现错误并且您点击取消而不是重试,则不应期望安装正常。 只是为了确保您应该卸载或删除发生错误的安装并重新安装。 大卫 以上来自于谷歌翻译 以下为原文 At what point did the error occur? I'm not sure how you can check if you are missing something except either comparing the files and folders to a known working installation or just waiting until something doesn't work. You shouldn't expect the install to be alright if it gave an error during installation and you hit cancel instead of retry. Just to be sure you should uninstall or delete the install where the error occurred and re-install. David |
首先,谢谢
当错误发生时留下深刻的印象,但它没有任何帮助,所以我按下取消。 现在关于chipcope如何安装一些插件? 谢谢 以上来自于谷歌翻译 以下为原文 first thanks when the error occur i pressed the retry but it didnt helped in any way so i pressed cancel. now about the chipscope how can i install some plugins ? thanks |
嗨Efis,
我不确定您对ChipScope插件的意思,因为您已经安装了更新。 你能说清楚你指的是什么吗? 大卫 以上来自于谷歌翻译 以下为原文 Hi Efis, I'm not sure what you mean by plugins for ChipScope as you've already installed the updates. Can you clarify what you are referring to? David |
只有小组成员才能发言,加入小组>>
2218 浏览 7 评论
2642 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2121 浏览 9 评论
3192 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2246 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
491浏览 1评论
1570浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2217浏览 0评论
543浏览 0评论
1704浏览 0评论
GMT+8, 2024-6-27 00:21 , Processed in 1.066480 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
