电子发烧友论坛|
大家好,我的ENA配置了8个窗口,如附图所示,12个跟踪。
我想配置显示器,因此左侧只显示1个跟踪窗口列,右侧列显示2个跟踪。 这可能吗? 当我尝试设置它时,它似乎只配置自己的前4个窗口有2条跟踪,以下4个有1条跟踪。 谢谢PaulEdited:2014年9月4日上午11:03分析器100 以上来自于谷歌翻译 以下为原文 Hi All, I have my ENA configured with 8 windows as shown in the attached picture, and 12 traces. I would like to configure the display, so only 1 trace is shown on the left had column of windows, and 2 traces on the right hand column. Is this possible? When I try to set this up, it just seems to configure itself with the first 4 windows having 2 traces, and the following 4 having 1 trace. Thanks, Paul Edited by: analyzer100 on Sep 4, 2014 11:03 AM 附件
3个回答
我不是ENA专家,但我的桌子上有一个。
所以我很好奇是否可以这样做。 我无法想办法完全按照你想要的方式行事,但我确实认为你可以去16条痕迹,每边8条,然后它们有一个关闭数据的功能。 因此,在左侧,对于½轨迹,您可以关闭数据。 标签仍然留在那里,所以它不干净,但你没有看到痕迹。 这样,左侧有四条活动迹线,右侧有8条活动迹线。 Afsi Moaveni 以上来自于谷歌翻译 以下为原文 I am not an ENA expert, but I have one at my desk. So I was curious if this could be done. I couldn’t figure a way to do what you wanted exactly, but I did figure you can go to 16 traces, so 8 on each side, and then they have a feature to turn data off. So on the left side, for ½ the traces you turn data off. The label still stays there, so it’s not clean, but you don’t see a trace. That gives you four active traces on the left, 8 active traces on the right. Afsi Moaveni |
dsgdadsad 发表于 2018-11-15 08:45 感谢您的建议。 它看起来有点混乱,但似乎这是你能做到这一点的唯一方法。 谢谢您的帮助! 以上来自于谷歌翻译 以下为原文 Thank you for the suggestion. It looks a little messy like that, but it seems like that's the only way you can do this. Thanks for the help! |
dsgdadsad 发表于 2018-11-15 08:45 。 以上来自于谷歌翻译 以下为原文 . |
只有小组成员才能发言,加入小组>>
90 浏览 0 评论
1857 浏览 0 评论
2751 浏览 1 评论
2654 浏览 1 评论
2476 浏览 5 评论
1859浏览 0评论
430浏览 0评论
233浏览 0评论
/9
GMT+8, 2025-12-10 18:47 , Processed in 0.678833 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1250
