电子发烧友论坛|
你好,我有一个问题,我的电路只工作时,我有PICtiT3插入。我先对微芯片进行编码,然后我构建了整个电路,效果非常好。在我的设计中,我忽略了一扇非门。我把女性头放在电路里,这样我就可以在电路中编程PIC了。因为我省掉了一个非门,我所做的就是改变什么动作,当输入是1,而不是0(代码明智)。在编程和运行之后不久,当我移除PICTIT3时,电路不再正确操作。我得到了奇怪的电压,我的LED很暗,而不是光明。然后我开始从PICTIT3中去掉电线,它去除了每根电线,但是从PICTIT3中取出了VDD和GND。于是我开始检查电路中的GND和功率的连续性。电路的连续性良好。不久我就意识到,PICTIT3甚至不必***入,当VDD和GND从我的电路上的PICTIT3连接到母头时,电路将工作得很好。我不知道这里发生了什么事。一切都很顺利,直到我在焊接电路中把芯片编程好。如果你有什么想法,请告诉我。我已经发布了图片来告诉你我的意思。图片显示,当PICTIT3***入时,LED打开。当PICTIT3没有***入时,LED是昏暗的。编译器:XC8(V1.44)MPLAB X V4.05PIC:PIC16F503PICTIT3
以上来自于百度翻译 以下为原文 Hello, I am having an issue with my circuit only working when I have the Pickit3 is plugged in. I coded the microchip first then I built the whole circuit, it worked great. I left out a not gate in my design. I put female headers in the circuit so i can program the Pic in the circuit. Since I left out a not gate, all I did was change what action to preform when the input is 1 instead of 0(code wise). Shortly after programming and running, when I removed the Pickit3, the circuit no longer operated correctly. I was getting weird voltages and my LED was very dim instead of being bright. I then began removing wires from the Pickit3 and it worked with every wire removed but the VDD and GND from the Pickit3. So I began to check continuity of GND and power in my circuit. The circuits continuity is fine. I shortly after realized that the Pickit3 doesn't even have to be plugged in and the circuit will work great when the VDD and GND is connected from the Pickit3 to the female headers on my circuit. I have no guess of what is going on here. Everything was running fine till I programmed the microchip in the soldered circuit. If you have any ideas please let me know. I have posted pictures to show you what I mean. The pictures show that when the the Pickit3 is plugged in the LED turns on. When the Pickit3 is not plugged in, the LED is dim. Compiler: XC8 (v1.44) MPLAB X v4.05 PIC: PIC16F1503 PICKIT3 Attached Image(s) |
14个回答
你有你的电路板的原理图吗?是否有任何旁路电容连接在GND和VDD之间?
以上来自于百度翻译 以下为原文 Do you have a schematic of your board? Are there any bypass capacitors connected between GND and VDD on your board? |
我只是画了一个示意图。对不起,这不是最容易的事情。如果事情没有意义,让我知道。我把照片贴在原来的帖子里了。我不认为我说过,但电路从未改变。我第一次用外部电源供电时,电路工作良好。然后我意识到我想改变代码中的某些东西。一旦我改变了密码,它就停止工作了,除非插入到PICTIT3中。
以上来自于百度翻译 以下为原文 I just drew up a schematic. Sorry, its not the easiest thing to follow. If something doesn't make sense, let me know. I have attached the picture in the original post. I don't think I said it above but the circuit never changed. The first time I built it the circuit worked fine with an external power supply. Then I realized I wanted to change something in the code. Once i changed the code, then it stopped working unless plugged into the pickit3 |
我没有看到任何一个电容器输出在你的调节器上。你应该考虑在每个调节器的输出上增加100NF与22-100UF并联。
以上来自于百度翻译 以下为原文 I don't see ANY capacitors on the output of either of your regulators. You should consider adding 100nF in parallel with 22-100 uF on the output of each regulator. |
在您的示意图中,我没有看到旁路电容器(如100 NF 50 V X7R陶瓷)紧密耦合到PIC的电源引脚。我也看不到电容器的输入和输出的78xx电压调节器。这些是真的遗漏或只是没有显示在您的示意图?
以上来自于百度翻译 以下为原文 In your schematic I do not see a bypass capacitor (such as 100 nF 50 V X7R ceramic) closely coupled to the PIC's power pins. I also do not see capacitors on the inputs and outputs of the 78xx voltage regulators. Are these really missing or just not shown on your schematic? |
是的,我知道有人会称赞这一点。是的,我应该把它们交给监管者。我打算把它们加起来,但还没有找到。但我想把我现在的东西贴上。谢谢你的建议。
以上来自于百度翻译 以下为原文 Yeah, I knew someone was going to compliment on that. Yes, I should have them to the regulators. I was going to add them but haven't got around to it yet. But i wanted to post exactly what I have currently. Thanks for the advice |
电路无疑需要CAPS(我还没有订购CAPS),但据我所知和经验,CAPS不应该影响电路运行的能力。它以前运行得很好。我相当肯定,如果我要建立相同的电路,但最终程序(编码)之前,我把它焊接在一起,电路将正确运作。如果其他人不同意,请告诉我。它对我来说没有什么意义,它只是正确操作时,皮卡有VDD和GND插入,但它甚至不需要插入到计算机中。这是我第一次尝试用一个外部电源在已经建成的电路编程PIC。通常我最终完成代码,然后把PIC导入到电路中,它总是工作得很好吗?我可以再拿一个PIC程序,把旧的除掉,再焊接一个新的。但我想解决这个问题,而不仅仅是解决问题。
以上来自于百度翻译 以下为原文 The circuit needs caps no doubt(I haven't ordered the caps yet) but to my knowledge and experience, the caps shouldn't impend on the ability of this circuit to operate. It operated fine like this before. I am fairly certain that if I was to build the same circuit but finalize the program(coding) before I solder it all together, the circuit would operate correctly. < This is the first time i tried to program a PIC with an external power supply in the already built circuit. Normally I finalized the code then implement the pic into the circuit and it always works fine?? I could just grab another Pic program it, desolder the old one and solder in a new one. But I want to solve the issue, not just work around it |
我认为“恭维话”不是我们所做的事!是的,你应该。振荡调节器不利于你的PIC的健康。经验丰富的设计师知道,首先要做的是节省时间。这正是你应该做的。张贴你真正使用的东西,而不是你知道你应该使用的东西。
以上来自于百度翻译 以下为原文 I don't think "compliment" is quite what we did! ;) Yes you should. Oscillating regulators are not good for your PIC's health. Experienced designers know it saves time to do it right first. That's exactly what you should do. Post what you are REALLY using, not what you know you should be using. |
这是你的提示,唯一的区别是增加一些电容到VDD轨道上。
以上来自于百度翻译 以下为原文 There's your hint. The only difference it is making is adding some capacitance to the VDD rail. |
哦…^ ^ ^谢谢大家,我明天早上第一件事就试试看。我可能不得不撕开一些电路来获得一些盖帽。我认为“恭维”不是我们所做的。只有在我试图重新编程的时候,它才起作用。也许我太担心这个想法了,在我尝试重新编程之前。我永远不会知道,直到我尝试…弄脏双手的时间
以上来自于百度翻译 以下为原文 OH....^^^^ Thanks guys, Ill give it a try first thing in the morning. I might have to tear apart some circuits to obtain some caps. I don't think "compliment" is quite what we did! ;)<<< LOL...OPS The only thing that makes me skeptical is that it worked fine before I tried to reprogram it. Maybe I'm too hung up on the idea that it worked before i tried to reprogram it.. Ill never know till I try.. Time to get the hands dirty |
坏的电路有时会起作用,这取决于你把电线挂在哪里,湿度是什么,你的手在哪里,等等。一个好的电路总是有效的。:)
以上来自于百度翻译 以下为原文 A bad circuit may sometimes work, depending upon where you drape the wires, what the humidity is, where your hand is, and so on. A good circuit will ALWAYS work! :) |
更新:我在等待上限,因为我找不到任何旧项目,我想撕开。明天他们应该进来,我会让你知道情况如何
以上来自于百度翻译 以下为原文 Update: I am waiting on caps because I couldn't find any old projects I want to tear apart. Tomorrow they should be in and ill let you know how it goes |
OP已经声明,他们只需要从PK3连接GND和VDD就可以产生差异。
以上来自于百度翻译 以下为原文 The OP has stated that they only need to connect GND and VDD from the PK3 to make a difference... |
这是你的提示。唯一的区别是在VDD轨道上增加一些电容。好消息,伙计们,我终于可以得到一些陶瓷帽了。我实现了5个上限。每个LM调节器上的两个(像应该是LOL)和一个在PIC到GND上。它的工作很好。我学到的东西:1)不要半美元$2)比PIC更聪明。
以上来自于百度翻译 以下为原文 There's your hint. The only difference it is making is adding some capacitance to the VDD rail. Good news guys, I was finally able to get some ceramic caps. I implemented 5 caps. Two on each of the LM regulators (Like there should be lol) and one on the PIC to GND. It works great. Things I learned: 1) Don't half a$$ circuits 2) Be smarter than the PIC |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1125浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 19:08 , Processed in 1.025795 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2951
