您好
我在Cemtos 5上安装了Xilinx EDKpackage 我拥有正确的许可驱动器等等。 当插入Spartan 6板时,会检测到电路板 它不仅仅是一个电路板冲击返回,没有检测到电缆。 有什么我需要添加像设备规则,或特别是任何东西 以上来自于谷歌翻译 以下为原文 HI I have installed Xilinx EDK package on Cemtos 5 i have everything set right with licensing cable drivers ect. When plug in a Spartan 6 board the board does get detected its not just one board impact returns that there is no cable detected. Is there something i need to add like Device rules,or anything in particular |
3个回答
您是否下载了驱动程序,运行安装脚本,然后更改windrvr6上的权限?
如果我没弄错的话,关于如何在Linux上安装电缆的.pdf忘记提及许可变更要求,但它在驱动程序的自述文件中列出。 以上来自于谷歌翻译 以下为原文 Did you download the driver, run the install script, and then change the permissions on the windrvr6? If I'm not mistaken, the .pdf on how to install the cables on Linux forgets to mention the permission change requirment, but it's listed in the readme with the driver. |
请你发布指南和驱动程序下载的链接。
你能告诉我一个与ISE一起安装电缆驱动器的事情吗?你建议任何其他驱动程序 你正在谈论的是什么? 谢谢 以上来自于谷歌翻译 以下为原文 can you please post the links to the guide and driver downloads. can you tell me one more thing the cable drivers are installed along with the ISE are you suggesting any other drivers what are these permissions that you are talking about Thank you |
用户指南可在此处找到:
http://www.xilinx.com/support/documentation/user_guides/ug344.pdf 司机可以在这里找到: https://secure.xilinx.com/webreg/clickthrough.do?cid=103670 在上述位置下载的存档中,您将找到一个自述文件,其中提供了在Linux上安装所需的说明。 我建议忽略上面的用户指南,因为在检查后,我可以确认它不会告诉您重置权限。 以上来自于谷歌翻译 以下为原文 The user guide is found here: http://www.xilinx.com/support/documentation/user_guides/ug344.pdf The drivers can be found here: https://secure.xilinx.com/webreg/clickthrough.do?cid=103670 In the archive downloaded at the above location you'll find a readme file that gives the directions you need to install on Linux. I suggest ignoring the user guide above since, after checking, I can confirm it doesn't tell you to reset permissions. |
只有小组成员才能发言,加入小组>>
2385 浏览 7 评论
2800 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2264 浏览 9 评论
3336 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2433 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
759浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
548浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
371浏览 1评论
1966浏览 0评论
685浏览 0评论
GMT+8, 2024-11-26 09:24 , Processed in 1.392194 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
