电子发烧友论坛|
你好,
我尝试使用DVI双链路端口将我的显示器与DVI连接到HDMI电缆,但显示器无法达到2560x1440 60hz。 由于我的电脑只有VGA和DVI双链接,我无法使用其他端口达到2560x1440 60hz。 我做了一些研究,看来英特尔高清显卡530驱动程序只支持DVI单链路信号,即使端口是DVI双链路。 我怎样才能达到2560x1440 60hz? 请帮帮我。 显示器:戴尔P2416D PC:HP 280 PRO G2 MT CPU:Core i5 - 6500 HD Graphics 530。 以上来自于谷歌翻译 以下为原文 Hello, I tried to use DVI dual link port to connect my monitor with DVI to HDMI cable, but the monitor was not able to reach 2560x1440 60hz. Since there are only VGA and DVI dual link available for my PC, I am not able to use other port to reach 2560x1440 60hz. I did some research, it seems the Intel HD graphics 530 driver only support DVI single link signal even though the port is DVI dual link. How can I reach 2560x1440 60hz? Please help me. Monitor: Dell P2416D PC: HP 280 PRO G2 MT CPU: Core i5 - 6500 HD Graphics 530. |
1个回答
您好brianfu,感谢您加入此英特尔社区。如您所知,Windows的英特尔图形驱动程序仅支持DVI单链接。
在这种情况下,您需要联系您的系统制造商,了解您是否可以使用系统支持的视频输出在60hz下实现2560x1440。值得一提的是,使用DVI单链路和VGA可获得的最大分辨率为1920x1200。 这显然是硬件,视频输出,限制。此外,使用第三方适配器时可能会遇到性能问题。 遗憾的是,我们无法保证您的系统配置能够正常工作,因为始终建议使用电缆进行直通连接.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello brianfu, Thank you for joining this Intel Community. As you already know, Intel Graphics drivers for Windows only support DVI Single-link. In this case, you need to contact your system manufacturer to find out if you can achieve 2560x1440 at 60hz with the video outputs your system supports. It is worth mentioning that the maximum resolution you can get using DVI Single-link and VGA is 1920x1200. This is clearly a hardware, video output, limitation. Besides, you can experience performance issues when using 3rd party adapters. Unfortunately, we cannot guarantee that your system configuration will work since a straight-through connection with a cable is always recommended. Wanner G. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 02:15 , Processed in 2.807068 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
17042
