电子发烧友论坛|
我升级到Vivado 2018.1。
如果我在设备视图中单击网络,则“输入分配路由模式...”不再存在。 它已经被淘汰了,还是可以做些什么来取回它? 除此之外,它是一种非常方便的方式来查看路由延迟。 以上来自于谷歌翻译 以下为原文 I upgraded to Vivado 2018.1. If I click on a net in the device view the "Enter Assign Routing Mode ... " is no longer there. Has it been eliminated, or is it possible to do something to get it back? Among other things, it was a very handy way to look at routing delays. |
6个回答
@新用户,
问题是可重现的,我提交了一份CR,以便在未来的Vivado版本中修复它。 目前,请继续使用Netlist窗口中的选项。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @new_user, Issue was reproducible and I filed a CR to get it fixed in future release of Vivado. For now, please continue using the option from Netlist window. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
我重新启动了Vivado并返回了“输入分配路由模式”。
我调查了它。一些网络出现了选项,但其他人没有。 可能是间歇性的错误。 以上来自于谷歌翻译 以下为原文 I re-started Vivado and "Enter Assign Routing Mode" returned back. I looked into it. The option appears for some of the nets, but not for others. May be an intermittent bug. |
看起来像个bug。
我能够通过以下步骤重现它: - 打开设备视图。 选择一个网络,使其看起来是白色,并在网表树视图中突出显示。 - 右键单击“设备”视图中的节点。 “进入分配路由模式...”可能不在菜单中。 这是错误。 - 单击Netlist视图中的注释。 - 再次右键单击“设备”视图中的节点。 “输入分配RoutingMode ...”现在已经存在并且功能齐全。 以上来自于谷歌翻译 以下为原文 Looks like a bug. I was able to reproduce it with following steps: - open the device view. select a net so that it looks white and it is also highlighted in the Netlist tree view. - right click on the node in the Device view. "Enter Assign Routing Mode ..." may not be in the menu. This is the bug. - click on the note in the Netlist view. - right click on the node in the Device view again. "Enter Assign Routing Mode ..." is now there and fully functional. |
@新用户,
我还没有测试过,但如果您想知道净延迟,请选择网络并查看“连接”窗口。 单击Load Net Delays以查看值 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @new_user, I haven't tested it yet but if you would like to know the net delay then select the net and see the "connectivity" window. click on Load Net Delays to see the values --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@新用户,
问题是可重现的,我提交了一份CR,以便在未来的Vivado版本中修复它。 目前,请继续使用Netlist窗口中的选项。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @new_user, Issue was reproducible and I filed a CR to get it fixed in future release of Vivado. For now, please continue using the option from Netlist window. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 09:24 , Processed in 0.918900 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
20888
