电子发烧友论坛|
我以前遇到过这个问题,但几分钟或几小时后我的电脑再次启动。
但是这次3天前我不得不在我的主板BIOS上激活虚拟化技术,因为我正在学习移动开发,我不得不模仿Android,在我保存BIOS设置之后,PC没有重新启动。 它只是没有显示任何屏幕,似乎我的外围设备(有LED)没有发光,好像他们没有接受任何能量。 PC会持续数小时重启,但不会显示任何屏幕。 我试图移除主板的电池,将其设置为出厂重置,但无法正常工作。 此外,MemOK Led保持闪烁,但没有声音反馈。 按MemOk按钮无法解决此问题。 一位男士给出了修复虚拟化的提示。 他建议使用名为CrystalCPUID的软件。 该软件能够强制将值写入处理器寄存器,这样我就可以强制启用虚拟化。 但是当我尝试写任何值时,它就没有。 我注意到在Aida64上它启用了虚拟化,但当我转到CrystalCPUID时,它返回处理器寄存器中的信息,它表示虚拟化被禁用。 我的设置有一台I7 3770,一台华硕P8H77-M和两台4Gb RAM 1333Mhz由金士顿。 以上来自于谷歌翻译 以下为原文 I had this problem before, but after some minutes or hours my PC booted up again. But this time 3 days ago i had to activate the virtualization techonology at my mobo's BIOS because I was learning mobile development and I had to emulate Android, after I saved the BIOS setup the PC didn't booted up again. It just doesn't show any screen, also seems my periphals (that have LEDs) aren't glowing as if they weren't receiving any energy. The PC keeps restarting for hours along, but just doesn't show any screen. I tried to remove the motherboard's battery to set it's setup as factory reset, but didn't work. Also, the MemOK Led keeps blinking, but no sound feedback. Pressing the MemOk button didn't fix that. A man gave a tip to fix the virtualization. He suggested to use a software called CrystalCPUID. This software is able to force write a value into the processor registers, this way I could force to enable virtualization. But when I try to write any value, it just doesn't. I noticed at Aida64 it says Virtualization enabled, but when I go to CrystalCPUID, that returns the information from the processor registers, it says the virtualization is disabled. My setup has an I7 3770, an Asus P8H77-M and 2 sticks of 4Gb RAM 1333Mhz by Kingston. |
6个回答
您好Loumier,感谢您在此社区中发布您的查询。在这种情况下,激活您的Asus * P8H77-M中的虚拟化技术不应该影响您的机器启动方式,除非BIOS上有其他更改直接相关
到了Boot.Do你还记得做其他任何改变吗?你是否有机会再次访问BIOS来禁用虚拟化并查看计算机是否启动了?你有任何错误信息或蓝屏图片的截图吗?我 希望能尽快收到你的来信.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Loumier, Thank you for posting your inquiry in this Community. In this case activating the virtualization technology in your Asus* P8H77-M is not supposed to be affecting the way that your machine boots, unless there are other changes on the BIOS directly related to the Boot. Do you remember making any other change? Is there a chance that you can access the BIOS again to disable the virtualization and see if the computer boots? Do you have any screenshots of picture of any error message or blue screen? I hope to hear from you soon. Regards, Diego S. |
jerry1978 发表于 2018-11-9 18:35 正如我之前所说,我已经从任何电源中移除了主板,包括它自己的电池。 这应该将设置恢复为出厂配置。 但即便这样做,PC也无法正常开启。 现在没机会拍摄任何截图。 正如我所说,没有视频信号。 似乎电源也没有到达外围设备。 以上来自于谷歌翻译 以下为原文 As I said before, I've already removed the motherboard from any power souce, including it's own battery. This should restore the setup to it's factory configurations. But even after doing that the PC isn't turning on properly. No chance to take any screenshot now. As I said, there's no video signal. Also seems the power isn't reaching the peripherals. |
你好Loumier,谢谢你的回复。我们将进一步调查我们的问题; 我们会尽快联系你。我希望这有帮助.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Loumier, Thank you for response. We will investigate further regarding our issue; we will reach you back as soon as possible. I hope this helps. Regards, Diego S. |
我希望很快能得到答案。 以上来自于谷歌翻译 以下为原文 I hope to get an answer soon. |
你好Loumier,谢谢你的耐心。在这种情况下,我们最好的建议是在你的主板上尝试另一个CPU,或者用你当前的CPU测试另一块主板,以便找出问题并找出罪魁祸首是董事会本身还是 处理器。我希望这有帮助.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Loumier, Thank you for patience. In this case our best recommendation is either to try another CPU on your board, or test another board with your current CPU, in order to isolate the issue and find out if the culprit is the board itself or the processor. I hope this helps. Regards, Diego S. |
jerry1978 发表于 2018-11-9 19:13 你好Loumier,如果你需要进一步的帮助我们只想加倍吗?请不要犹豫与我们联系。我希望尽快收到你的回复。最好的问候,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Loumier, We just wanted to double if you need further assistance? Please don’t hesitate on contacting us back. I hope to hear from you soon. Best Regards, Diego S. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 07:54 , Processed in 0.947985 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
609
