我一直在使用通过USB与IO Libraries v16连接到PC的E5071C没有问题。
当我更新到最新的v17 IO Libraries软件时,它不再检测到分析仪,并且似乎无论如何都没有手动添加它。 然后我卸载了v17,并重新安装了v16,它再次正常工作。 我附上了v16和v17的图片,根本没有触摸分析仪或USB线。 v17 IO Libraries软件是否存在已知问题,或者我是否需要一些特殊方法来设置Analyzer? IO库V16.png424.9 KB 以上来自于谷歌翻译 以下为原文 I've been using an E5071C connected to a PC via the USB with IO Libraries v16 without a problem. When I updated to the latest v17 IO Libraries software, it no longer detected the analyzer, and there didnt seem to be anyway to manually add it. I then un-installed v17, and re-installed v16, and it worked fine again. I've attached pictures of both v16 and v17, without touching the analyzer or USB cable at all. Is there a known issue with the v17 IO Libraries software, or do I need some special way to set the Analyzer up on it? 附件
2个回答
只是对这个问题的后续跟进。
我随后第二次重新安装了v17软件,这次它确实检测到了USB连接分析仪。 所以遇到这个问题的其他人,或许尝试卸载,然后重新安装IO库,看看是否能解决这个问题。 以上来自于谷歌翻译 以下为原文 Just a follow-up to this question. I subsequently re-installed the v17 software a second time, and this time, it did detect the USB connected Analyzer. So anyone else who experiences this problem, perhaps try un-installing, then re-installing the IO Libraries to see if this fixes it. |
感谢您的回复,我想您必须在我发布上述回复的同时发送回复。 它似乎现在正在工作,只需再次重新安装v17,所以现在一切都很好。 感谢您抽出宝贵时间尝试复制问题。 以上来自于谷歌翻译 以下为原文 Thanks for the reply, I think you must have sent it at the same time as I posted my response above. It seems to be working now, just by re-installing v17 again, so everything is all good now. Thank you for taking the time to try to replicate the problem. |
只有小组成员才能发言,加入小组>>
1294 浏览 0 评论
2377 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1131浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
759浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
939浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 03:37 , Processed in 1.245074 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
