电子发烧友论坛|
嗨我正在尝试在执行E5071C的2端口校准后提取未校正系统性能的数据。
我在网上看到,这可以在执行校准后提取但是我无法做到。 有了B系列,有一个VBA程序可以做到这一点,但该程序不适用于'C'模型。 有人可以对此有所了解吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hi I am trying to extract the data for the uncorrected sytem performance after performing a 2-port calibration of the E5071C. I've read online that this is possible to extract after performing the calibration however I have been unable to do it. With the B-series there is a VBA program available to do this but that program does not work for the 'C' model. Can anyone shed some light on this please? Thanks |
5个回答
通常,VBA源代码位于Excel文件中。
如果这是由某人编写和保护,那么你将无法达到它。 VBA是“Visual Basic for Applications”并且始终存在于文件中。 这是一个Excel文件吗? 以上来自于谷歌翻译 以下为原文 Usually the VBA source code is inside of an Excel file. If this was written and protected by someone then you won't be able to get to it. VBA is "Visual Basic for Applications" and always exists inside the file. Is this an Excel file? |
我试图在excel中打开,它不会打开。
它仅作为VBA文件列出。 我附上了以下文件谢谢 以上来自于谷歌翻译 以下为原文 I have tried to open in excel, it wont open. Its listed simply as a VBA file. I've attached the file below Thanks 附件 |
我在记事本中打开它,它看起来像VB 6.0表单文件,但它有二进制值。
我不认为VB 6.0文件中有任何bianry。 我以前记得在记事本中打开它们,它们都是ASCII字符。 如果这很简单,我可以提供帮助。 以上来自于谷歌翻译 以下为原文 I opened this up in Notepad and it looks like a VB 6.0 form file but there are binary values in it. I don't think VB 6.0 files had any bianry in them. I used to remember opening them up in Notepad and they were all ASCII characters. If it's something simple I might be able to help. |
在视觉基础方面,我再次成为新手;
该程序似乎具有我需要的所有测量,但是当我尝试在设备上运行宏时,它会给出一个错误消息,它被设计为在B系列上运行。感谢您的帮助! 以上来自于谷歌翻译 以下为原文 Again im a novice when it comes to visual basic; The program seems to have all the measurements I need however when I try to run the macro on the unit it gives an error message that it was designed to run on a series B. Thanks for your help! |
您可能需要查看收件箱。
我已经给你发了一条联系信息。 以上来自于谷歌翻译 以下为原文 You might want to check your inbox. I have sent you a message for contact purposes. |
只有小组成员才能发言,加入小组>>
1846 浏览 0 评论
2740 浏览 1 评论
2641 浏览 1 评论
2451 浏览 5 评论
3461 浏览 3 评论
1846浏览 0评论
418浏览 0评论
/9
GMT+8, 2025-12-3 02:38 , Processed in 1.736595 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1250
