您好,我正在使用Virtex7 FPGA运行Vivado 2017.2。
在合成并实现我的设计之后,我导航到我的sdf文件并将LUT的延迟值从以下(INTERCONNECT nand2_inst / O nand1_inst / I1(141.6:165.6:165.6)(141.6:165.6:165.6))更改为(INTERCONNECT nand2_inst / O nand1_inst / I1(0:0:0)(0:0:0))当我重新运行后实现时序仿真时,该sdf文件将重新生成实际/先前的延迟约束。 有没有办法保留编辑过的sdf文件并模拟而不重新生成它? 提前致谢 以上来自于谷歌翻译 以下为原文 Hello, I'm running Vivado 2017.2 with Virtex7 FPGA. After synthesizing and implementing my design, I navigate to my sdf file and change delay values of a LUT from following (INTERCONNECT nand2_inst/O nand1_inst/I1 (141.6:165.6:165.6) (141.6:165.6:165.6)) to (INTERCONNECT nand2_inst/O nand1_inst/I1 (0:0:0) (0:0:0)) When I re-run post -implementation timing simulation, this sdf file is regenrated with actual/previous delay constraints. Is there any way to preserve the edited sdf file and simulate without regenrating it? Thanks in advance |
2个回答
我认为没有办法阻止它写出SDF文件。
基思 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 I don''t think there is a way to prevent it writing out an SDF file. Keith ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
感谢您的回复。
我记得在ISE那不是问题。 只要您不运行“生成后置和路径模拟”任务,就不会重新生成SDF文件。 在Vivado上有解决方法吗? 以上来自于谷歌翻译 以下为原文 Thanks for your reply. I remember in ISE that wasn't a problem. As long as you don't run "Generate post-place&route simulation" task the SDF file won't be regenerated. Is there any workaround for this on Vivado? |
只有小组成员才能发言,加入小组>>
2424 浏览 7 评论
2826 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2294 浏览 9 评论
3375 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2465 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1242浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
590浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
453浏览 1评论
2008浏览 0评论
732浏览 0评论
GMT+8, 2024-12-25 17:47 , Processed in 1.313701 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
