The ti design is for automotive high side dimming rear light, which uses BCM to supply the rear light. In the TI design the high side driver TPS1H100-Q1 is used to output PWM supply with different duty cycle. Linear LED drivers TPS92630-Q1 and TPS92638-Q1 are used to drive the LEDs in constant (...) 主要特色 • High side dimming • Wide input voltage range: 12V Typical, 9-16V Continuous • Programable current limit high side driver • LED Open circuit, LED short circuit, LED driver output short to battery, device thermal shut down protection • Thermal Foldback function for LED driver • One fail all fail (...)
只有小组成员才能发言,加入小组>>
47838 浏览 1 评论
2456 浏览 2 评论
6876 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
77430 浏览 2 评论
60703 浏览 0 评论
2461浏览 2评论
77512浏览 2评论
113025浏览 1评论
3627浏览 1评论
4888浏览 1评论
GMT+8, 2024-9-29 06:02 , Processed in 1.176891 second(s), Total 76, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
