亲爱的大家,
我买了英特尔酷睿i7 8086K并且我的内存有问题。 我也有@ 3200MHz频率的RAM内存。 此外,我在英特尔网站上看到,i7 8086K的最大RAM频率为2666MHz。 并且有我的问题 - 每当我在我的BIOS中启用XMP(因此我的RAM工具包可以是@ 3200MHz)时系统就会出现故障并显示以下内容: “您之前的超频设置失败,按F1进入设置或F2加载默认值并进入设置(...)” 因为我的结果我无法加载Windows,需要重置我的PC,如果我没有将XMP的状态更改为“禁用”,我无法加载Windows。 当我禁用XMP并且频率回到2133MHz时,一切都很好。 我的RAM套件是G.Skill TridentZ 2x16GB 3200MHz CL14 [F4-3200C14D-32GTZ],MB是MSI Z370 Gaming M5。 您是否碰巧知道上述问题的解决方案? 处理器是否对某些问题负责? 感谢您的帮助! 最好的祝福 以上来自于谷歌翻译 以下为原文 Dear All, I have bought Intel Core i7 8086K and have problems with my RAM. I also have RAM memory @3200MHz frequency. Furthermore, I saw at Intel's website that maximum RAM frequency for i7 8086K is 2666MHz. And there is my problem - whenever I enable XMP (so my RAM kit can be @3200MHz) in my BIOS the system fails and the following shows up: "Your previous overclock setting have failed, Press F1 to enter setup or F2 to load default values and enter setup (...)" As I result I cannot load Windows and need to reset my PC and if I do not change the status of XMP as "disabled" I cannot load Windows. When I disable XMP and the frequency gets back to 2133MHz everything is fine. My RAM kit is G.Skill TridentZ 2x16GB 3200MHz CL14 [F4-3200C14D-32GTZ] and MB is MSI Z370 Gaming M5. Do you happen to know the solution to the problem that is said above? Is the processor responsible for some problems? Thanks for your help in advance! Best Regards |
6个回答
HelloPanGolan感谢您加入英特尔®社区。在查看此案例后,我发现您拥有符合规格的英特尔®酷睿™i7-8086K处理器(https://ark.intel.com/products/148263/Intel-
Core-i7-8086K-Processor-12M-Cache-up-to-5_00-GHz?q = 8086k)对于内存,它可以与DDR4-2666一起使用,最高可达64 GB。 以更高的速度使用这些规范中的处理器可以得出错误或损坏CPU的结论。 希望这可以帮助。 此致,莱昂纳多C. 以上来自于谷歌翻译 以下为原文 Hello PanGolan Thank you for joining the Intel® community. After looking into the case I see that you have an Intel® Core™ i7-8086K Processor that accosting to the specifications (https://ark.intel.com/products/148263/Intel-Core-i7-8086K-Processor-12M-Cache-up-to-5_00-GHz?q=8086k) for memory, it can be used with DDR4-2666 up to 64 GB. Using the processor out of these specifications with higher speed could conclude on errors or damage to the CPU. Hope this helps. Regards, Leonardo C. |
jerry1978 发表于 2018-11-6 11:58 所以我们要非常清楚:英特尔规格的操作高达DDR4-2666。 这不是因为不能支持以更快的速度运行内存总线(或者必然会造成损坏); 这只是因为英特尔没有在更高的设置下验证这个特定的处理器。 当然,英特尔没有说明为什么他们将它限制在DDR4-2666,所以谁知道...... 以下是我要说的:是否可以支持更快的速度是许多变量的产物 - 处理器的内存控制器,正在使用的DIMM的质量,主板上的内存总线的实现(如何 它隔离噪声,防止反射等),附近其他设备的存在等等。所有这些都可能导致总线上的噪声,如果这种噪声达到一定水平,数据将不会始终如一 隔绝了噪音。 在我多年的经验中,问题的两个最大原因是(a)质量差的DIMM(我只是说,恕我直言,你是在图腾柱的较低点玩)和(b)主板的质量 公交车实施。 我很少看到处理器内存控制器的问题 - 但是,据说,需要了解的是,当你使用XMP配置文件超频内存总线时,你在技术上会超频你的处理器。 除其他外,这可能导致热问题和热问题可能导致故障。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 So let's be very clear: Intel specs operation up to DDR4-2666. This is not because attempting to run the memory buses at faster speeds cannot be supported (or necessarily will cause damage); it is simply because Intel does not validate this particular processor at higher settings. Of course, Intel does not say why they have limited it to DDR4-2666, so who knows... Here is what I will say: Whether a faster speed can be supported is a product of a number of variables - the processor's memory controllers, the quality of the DIMMs being used, the implementation of the memory buses on the motherboard in question (how well it isolates noise, prevents reflections, etc.), the presence of other devices in the vicinity, etc. All of these can contribute to the noise on the bus and, if this noise reaches certain levels, the data is not going to be consistently isolated from the noise. In my many years of experience, the two biggest causes of problems are (a) poor quality DIMMs (and let's just say that, IMHO, you are playing at a lower point on the totem pole) and (b) the quality of the motherboard's bus implementation. Rarely have I seen an issue with the processor's memory controllers -- but, that said, it needs to be understood that you are technically overclocking your processor when you overclock the memory buses using XMP profiles. This can, amongst other things, cause thermal issues and thermal issues can cause failures. Hope this helps, ...S |
cd340823 发表于 2018-11-6 12:04 亲爱的N.Scott.Pearson - 为什么你认为我拥有的RAM存储器套件“处于图腾柱的较低点”? 我只是好奇你为什么这么认为,也许下次有帮助>更好? 最终事实证明,由于BIOS的版本,问题出现了。 闪烁和更新后一切都很好。 现在XMP配置文件和其他OC选项不会导致我在第一篇文章中提到的错误。 最好的祝福 以上来自于谷歌翻译 以下为原文 Dear N.Scott.Pearson - why do you think the RAM memory kit that I have is "at a lower point of the totem pole"? I am just curious why do you think so and maybe it helps < Eventually it turned out that the issue occured because of the version of BIOS. After flashing and updating it everything is fine . now XMP profile and other OC options do not result in the error I mentioned in the first post. Best Regards |
jerry1978 发表于 2018-11-6 12:21 我个人对GSkill的质量并不怎么看。 我还能说什么呢? 内容S 以上来自于谷歌翻译 以下为原文 I personally do not think much of GSkill's quality. What more can I say? ...S |
我想你是基于某些东西说的,我想知道这个“基础”是什么。 以上来自于谷歌翻译 以下为原文 I suppose you said it based on something and I would like to know what is this "base" . |
多年的测试板具有各种内存品牌。 我发现他们的产品质量不稳定,因此停止使用它们。 人们从他们那里购买,因为他们往往更便宜。 好吧,你得到你付出的代价...... 内容S 以上来自于谷歌翻译 以下为原文 Many years of testing boards with various memory brands. I found their products to be of inconsistent quality and stopped using them as a result. People purchase from them because they are often cheaper. Well, you get what you pay for... ...S |
只有小组成员才能发言,加入小组>>
277浏览 0评论
GMT+8, 2024-6-24 20:24 , Processed in 0.800388 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
