电子发烧友论坛|
嗨,我仍然是新的,但我有一个项目使用PIC16F87A,它是一个可编程倒数计时器与5个按钮,并驱动一个4位7段显示。电路工作,我可以选择使用按钮的时间,时间倒计时,显示工作完美,因为它应该。我的问题是,在倒计时过程中,显示和按钮会随机地死掉,计时倒计时的计时器似乎仍在运行,当计时器超时时,它会发出嘟嘟声。现在,我的逻辑告诉我,尽管与外部时钟连接的time1仍然可以运行I。如果系统时钟没有,但没有意义的是,超时将作为例程来减少系统时钟上的时间运行。我检查了我的软件,它是好的,并且显示和按钮每次都不会在同一个定时器上死掉。有人能给我一些关于T的建议吗?他的?
以上来自于百度翻译 以下为原文 Hi, I am still new to this, but I have project using a PIC16F877A, it is a programmable count down timer with 5 buttons and drives a 4 digit 7 segment display. The circuit works, I can select the time using the buttons and the time does the count down and the display works perfectly as it should. my issues is that during the count down process the display and buttons would randomly go dead, the timer that does the count down still seems to run, and it does beep when the timer times out. Now my logic tells me that although the timer1 connected with an external clock may still be able to run if the system clock does not, but it would not make sense that the time out will work as the routine to decrease the time runs on the system clock. I checked my software and it is fine, and the display and buttons do not go dead at the same timer every time. Can someone please give me some advice on this ? |
1个回答
好吧,你的逻辑有些问题。如果计时器超时,它会发出蜂鸣声,MCU使这成为可能,所以PIC应该运行…
以上来自于百度翻译 以下为原文 When Well, something is wrong with your logic. If it does beep when the timer times out, the MCU got to make this possible, so the pic should run... |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:22 , Processed in 0.766724 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2204
