我想知道,是否可以在同一个物体上同时使用两个相机来接收有效的深度图像。
他们是否相互影响/干涉? 以上来自于谷歌翻译 以下为原文 I was wondering, wether it is possible to use two cameras at the same object and the same time to receive valid depth images. Do they influence/interfere each other? |
1个回答
是的,您可以同时使用两个摄像头并重叠其视野。
如果它们是RealSense 400系列型号(D415或D435),则它们不会相互干扰。 使用两个摄像头可以提供更全面的深度数据,因为收集的数据存在冗余。 例如,如果您正在扫描人体,那么您可以垂直排列摄像机,其中一个摄像头扫描上半身,另一个扫描下半身,两个视图重叠在身体的中间高度。 以上来自于谷歌翻译 以下为原文 Yes, you can use two cameras at the same time and overlap their fields of view. If they are RealSense 400 Series models (D415 or D435), they will not interfere with each other. Using two cameras can provide more comprehensive depth data, because there is redundancy in the data collected. For example, if you were scanning the human body then you could arrange the cameras vertically, with one camera scanning the upper body and the other scanning the lower body, with the two views overlapping in the middle height of the body. |
只有小组成员才能发言,加入小组>>
465浏览 0评论
GMT+8, 2024-11-22 03:48 , Processed in 0.554890 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
