先生,我正在尝试在EMPro2011_12中实施共同模拟的ADS设计。
我设计了基板和导体,因为我必须在设计中添加更多组件,我不知道如何互连元件。 我已经附加了共同模拟的ADS文件的图像。 请找到它提供的解决方案。 我在FDTD模式下进行设计,因为我需要为此设计找到SAR。 谢谢 以上来自于谷歌翻译 以下为原文 Sir, I am trying to implement a co-simulated ADS design in EMPro2011_12. I have designed the substrate and the conductor since I have to add more components to the design I'm unaware of how to inter connect the components. I have attached the image of the co-simulated ADS file along this. Please find it provide a solution. I am doing the design in FDTD mode since I need to find the SAR for this design. Thanks 附件
7个回答
你好,我对这个问题有点困惑。
您是否尝试在EMPro中模拟设计,但是喜欢将某些电路组件连接到设计? 如果是这种情况,EMPro支持几种类型的负载,如R,L,C,二极管,开关,非线性电容。 以上来自于谷歌翻译 以下为原文 Hello I am a bit confused with this question. Are you trying to simulate the design in EMPro but liking to have some circuit components connected to the design? If this is the case, EMPro support several type of loads such as R,L,C, diode, switch, nonlinear capacitor. |
iwqudwnd 发表于 2018-11-1 18:01 出于好奇,有没有办法在有限元模拟中包含集总元素无源元件? 例如,一个简单的天线匹配网络? 以上来自于谷歌翻译 以下为原文 Out of curiosity, is there a way to include lumped element passive components in a FEM simulation? For example, a simple matching network for an antenna? |
是的,您可以在FEM中添加被动负载。 但是,您需要将其设置为非端口,您可以通过该端口上的“右键单击”将其关闭。 以上来自于谷歌翻译 以下为原文 Yes you can add a passive load in FEM. However you need to make it as a non-port, which is you can simply turn it off by "right click" on that port. |
你用的是什么版本? 在旧版本(2010或2012?)中,不支持此功能。 以上来自于谷歌翻译 以下为原文 What version are you using? In the older version (2010 or 2012?), this feature is not supported. |
坏消息! 我在2010年 以上来自于谷歌翻译 以下为原文 Bummer! I'm on 2010 |
很抱歉听到...为什么不转到最新版本,它有很多改进? 例如,对于相同的设计,您将看到产品的后期版本的速度提升。 以上来自于谷歌翻译 以下为原文 Sorry to hear... Why don't you move to the latest release which comes with lots of improvement? For example, you will see great speed improvement from the later release of product for the same designs. |
我正在检查许可证订阅的状态:)我们将看看是否可以升级 以上来自于谷歌翻译 以下为原文 I'm checking on the status of our license subscription :) We'll see if I can get an upgrade |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 13:20 , Processed in 0.793700 second(s), Total 56, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3504
