在我的vhfl文件中使用ibufds和obufds与使用make_diff_pair_port命令在Xdc约束文件中声明它们相同吗?它们是产生相同的结果还是它们不同?
以上来自于谷歌翻译 以下为原文 Is using ibufds and obufds in my vhfl file the same as declaring them in Xdc constraint file with the make_diff_pair_port command? Do they produce the same result or are they different? |
2个回答
嗯,意图是一样的。
您可以使用此命令稍后使用条件创建两个端口diff。 请参阅UG835#912https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Well, Intent is same. You could make two ports diff later using this command but with conditions. Refer UG835 #912 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf-Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
嗯,意图是一样的。
您可以使用此命令稍后使用条件创建两个端口diff。 请参阅UG835#912https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Well, Intent is same. You could make two ports diff later using this command but with conditions. Refer UG835 #912 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf-Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2733 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
653浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
462浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
668浏览 0评论
1860浏览 0评论
GMT+8, 2024-9-30 06:42 , Processed in 1.106040 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
