电子发烧友论坛|
我有一个最近出现问题的E8362B PNA(1.1GHz系统,07.50.67固件)。
启动网络分析仪应用程序时,初始化屏幕会显示很长时间,并且出现错误框 - “前面板遇到问题需要关闭”。 如果我选择“不发送”,应用程序最终将启动,但我得到一个网络分析器错误框 - '无法连接到AG82350芯片。 GPIB控件已禁用。 错误代码-3。' 然后应用程序将正常运行(因为我没有使用GPIB进行任何操作。)错误代码听起来可能是硬件问题,但我有多个硬盘用于此PNA,并且没有其他安装遇到此问题 。 我卸载了网络分析仪应用程序并重新安装了最新版本(07.50.67),但问题没有改变。 有什么想法我应该确定什么干扰GPIB芯片? 以上来自于谷歌翻译 以下为原文 I have a E8362B PNA (1.1GHz system, 07.50.67 firmware) that developed a problem recently. When starting the Network Analyzer application, the initialization screen appears for a long time and I get an error box - 'Front Panel has experienced a problem and needs to close.' If I choose 'Don't Send', the application will eventually startup, but I get a network analyzer error box - 'Unable to connect to the AG82350 chip. GPIB control disabled. Error code -3.' The application will then function normally (because I'm not using GPIB for anything.) The error code sounds like it may be a hardware issue, but I have multiple hard drives for this PNA, and none of the other installations is experiencing this issue. I uninstalled the network analyzer application and reinstalled the latest version (07.50.67), but the problem did not change. Any idea where I should look to determine what is interfering with the GPIB chip? |
2个回答
> {quote:title = SpinningTurbine写道:} {quote}>我有一个最近出现问题的E8362B PNA(1.1GHz系统,07.50.67固件)。
那个型号不是20 Ghz单位? >错误代码听起来可能是硬件问题,但我有这个PNA的多个硬盘驱动器,并没有其他安装遇到此问题。 我认为这意味着问题在于您的高清安装使用其中一个好的。 以上来自于谷歌翻译 以下为原文 > {quote:title=SpinningTurbine wrote:}{quote} > I have a E8362B PNA (1.1GHz system, 07.50.67 firmware) that developed a problem recently. That model is not a 20 Ghz unit? > The error code sounds like it may be a hardware issue, but I have multiple hard drives for this PNA, and none of the other installations is experiencing this issue. I think that means the issue is in your HD installation use one of the good ones then. |
ST,您似乎遇到了CPU电路问题。
它可能有缺陷的HDD,H / W接口。 我们可以帮助修复。 请告诉我们我们能做些什么。 戴夫 以上来自于谷歌翻译 以下为原文 ST, You appear to have a problem with the CPU circuitry. It could have defective HDD, H/W interface. We can help with the repair. PM me about what we can do. Dave |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:05 , Processed in 2.457556 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1339
