电子发烧友论坛|
我注意到许多安捷伦(HP,Keysight)频谱分析仪型号都有一个最大保持和最小保持跟踪检测器。
使用“* Min Hold *”功能可以使用哪些测量示例? 此外,在测量相位噪声时 - 应使用哪种类型的检测:最大保持,最小保持或跟踪平均? SteveEdited:Steve Reeves于2014年8月7日上午9点25分 以上来自于谷歌翻译 以下为原文 I notice that many of the Agilent (HP, Keysight) spectrum analyzer models have a Max Hold and Min Hold trace detector. What examples of measurements are useful using the "*Min Hold*" function? Also, when measuring phase noise - which type of detection should be use: Max Hold, Min Hold or Trace Averaging? Steve Edited by: Steve Reeves on Aug 7, 2014 9:25 AM |
1个回答
嗨,史蒂夫,我使用最大和最小跟踪功能来长时间查找短时间事件。
例如,如果您想监视信号以查看信号是否熄灭或功率降低,您可以在信号出现时设置最小保持跟踪。 这可以让你离开它并让它运行很长时间。 如果信号下降,则将通过最小跟踪记录(只要事件长于扫描时间)。 同样具有最大保持力。 要查看大于噪声中存在的峰值的短持续时间杂散事件,请使用最大保持曲线(再次扫描时间和RBW可以是因子)。 我不认为Min和Max hold对于测量相位噪声有用,因为它们会随时间记录峰值或最小值,因此不代表平均功率。 唐K. 以上来自于谷歌翻译 以下为原文 Hi Steve, I use the max and min trace functions to look for short duration events for a long period of time. For example, if you want to monitor a signal to see if it ever drops out or experiences a power reduction you can set up a trace with min hold when the signal is present. This allows you to walk away from it and let it run for a long time. If the signal ever drops it will be recorded by the min trace (as long as the event is longer than the sweep time). Likewise with the max hold. To see a short duration spurious event that is larger than the peaks present in the noise, use a max hold trace (again the sweep time and RBW can be factors). I don't think Min and Max hold would be useful for measuring phase noise because they record peak or min levels over time and therefore don't represent the average power. Don K. |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:54 , Processed in 1.289766 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2887
