系统广播的问题。
该网站已启动并正在运行,但我的中心未显示。 它正如我在日志中看到的那样与服务器进行通信,但连接似乎一直在重置 { “代码”: “ECONNRESET”, “错误号”: “ECONNRESET”, “系统调用”: “读”} 请指教 谢谢 以上来自于谷歌翻译 以下为原文 problems with system broadcast. the website is up and running but my hub does not show up. it is communicating with the server as i see in the logs but the connection seems to keep getting reset {"code":"ECONNRESET","errno":"ECONNRESET","syscall":"read"} please advise thanks |
9个回答
您好,感谢您加入我们的英特尔®社区。我了解您在设置集线器时遇到了一些问题。为了更好地为您提供帮助,请向我们提供:更长/更具体的问题描述:集线器/客户端计算机
detailsHUB制造商:HUB型号和SKU:客户端型号:Windows操作系统(如果Win10提供版本号,32位或64位)和更新版本:IntelUnite®客户端版本:如果出现问题 使用扩展显示提供版本:IntelUnite®HUB版本:IntelUnite®服务器版本:如果问题与数据库有关,请指定MS SQL版本:IntelUnite®SmallBusiness版本(如果适用):Intel Unite App Extended显示驱动程序版本(如果 适用):HUB和客户端图形驱动程序版本和供应商:受影响的系统数量:英特尔插件信息(如果适用)插件名称:插件版本: 我希望尽快收到你的来信.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello yls, Thank you for joining our Intel ® Community. I understand that you are running into some issues when setting your hub. In order to assist you better, please provide us with: A longer/more specified problem description: HUB/Client computer details HUB manufacturer(s): HUB model(s) and SKU: Client model(s): Windows OS (provide Version number if Win10, and 32- or 64-bit) and update version: Intel Unite® Client version: If problem happens with Extended Display provide version: Intel Unite® HUB version: Intel Unite® Server version: If problem is related to database please specify MS SQL version: Intel Unite® Small Business version (if applies): Intel Unite App Extended display driver version (if applies): HUB and Client Graphics Driver version and vendor: Number of systems affected: Intel Plug in information (If applies) Name of the plugin: Plugin Version: I hope to hear from you soon. Regards, Diego S. |
jerry1978 发表于 2018-10-29 10:03 更长/更具指定的问题描述: 获取系统广播插件以在服务器上安装(需要安装sql14)并将其安装在集线器上之后。 网站(系统广播插件)工作正常,但找不到任何集线器。 在调试模式下运行unite时,我一直在服务器日志中收到此错误 - {“code”:“ECONNRESET”,“errno”:“ECONNRESET”,“syscall”:“read”}并登录集线器显示重复连接 尝试 HUB /客户计算机详细信息 HUB制造商:dell HUB型号和SKU:OptiPlex7060 / 085A 客户端模型:optiplex 7020 Windows操作系统(提供版本号,如果是Win10,32或64位)和更新版本:win 10 pro v1803 build 17134.228 IntelUnite®客户端版本:3.3.150.19 如果扩展显示提供版本出现问题: IntelUnite®HUB版本:3.3.150.19 英特尔Unite®服务器版本:3.3.150.19 如果问题与数据库有关,请指定MS SQL版本:ms sqlexpress14 IntelUnite®小型企业版(如果适用): Intel Unite App Extended显示驱动程序版本(如果适用): HUB和客户端图形驱动程序版本和供应商:问题在于系统广播插件 受影响的系统数量:1个设置演示 英特尔插件信息(如果适用) 插件名称:系统广播 插件版本:1.0.0.0 另外,请确保您使用的是英特尔Unite®应用程序企业部署指南中提到的受支持的SQL之一,第11页.ms sqlexpress14 以上来自于谷歌翻译 以下为原文 A longer/more specified problem description: after getting system broadcast plugin to install on the server (needed to install sql14) and installing it on the hub . the website (system broadcast plugin ) works ok but cannot find any hubs. I keep getting this error in the server logs while running unite in debug mode - {"code":"ECONNRESET","errno":"ECONNRESET","syscall":"read"} and logs on the hub show a repeated connection attempt HUB/Client computer details HUB manufacturer(s):dell HUB model(s) and SKU: OptiPlex7060 / 085A Client model(s):optiplex 7020 Windows OS (provide Version number if Win10, and 32- or 64-bit) and update version:win 10 pro v1803 build 17134.228 Intel Unite® Client version: 3.3.150.19 If problem happens with Extended Display provide version: Intel Unite® HUB version: 3.3.150.19 Intel Unite® Server version: 3.3.150.19 If problem is related to database please specify MS SQL version: ms sqlexpress14 Intel Unite® Small Business version (if applies): Intel Unite App Extended display driver version (if applies): HUB and Client Graphics Driver version and vendor: problem is with system broadcast plugin Number of systems affected:1 setting up demo Intel Plug in information (If applies) Name of the plugin: system broadcast Plugin Version: 1.0.0.0 Also please make sure that you are using one of the supported SQLs mentioned in our Enterprise Deployment Guide for the Intel Unite® app, page 11. ms sqlexpress14 |
cd340823 发表于 2018-10-29 10:18 你好,是的, 感谢您的答复。 请注意,IntelUnite®应用程序已通过Microsoft SQL Server 2008 R2或更高版本验证。 在这种情况下,MSsqlexpress14不正式支持,我们不保证其功能。 如果您有任何其他问题或疑虑,请告诉我们。 我希望尽快获得你的消息。 问候, 迭戈S. 以上来自于谷歌翻译 以下为原文 Hello yls, Thank you for your response. Please consider that Intel Unite® app has been validated with Microsoft SQL Server 2008 R2 or greater. The MSsqlexpress14, in this case is not supported officially, and we do not guarantee its functionality. Please let us know if you have any other question or concern. I hope to hear from you soon. Regards, Diego S. |
jerry1978 发表于 2018-10-29 10:24 您好,我们只是想仔细检查您是否需要进一步的帮助?请不要犹豫与我们联系。我希望尽快收到您的回复。最诚挚的问候,Diego S. 以上来自于谷歌翻译 以下为原文 Hello yls, We just wanted to double check if you need further assistance? Please don’t hesitate on contacting us back. I hope to hear from you soon. Best Regards, Diego S. |
7346634623q 发表于 2018-10-29 10:41 还需要帮助MSsqlexpress14比MS 2008更大请帮忙 谢谢 以上来自于谷歌翻译 以下为原文 still need help MSsqlexpress14 is greater then MS 2008 please help thanks |
7346634623q 发表于 2018-10-29 10:41 我安装了Microsoft SQL Server 2017,但它无法正常工作 请告诉我到底要使用的版本 谢谢 以上来自于谷歌翻译 以下为原文 I installed Microsoft SQL Server 2017 and it did not work Please tell me exactly what version to use thanks |
你好,是的, 感谢您的答复。 在这种情况下,为了回答并帮助您,请向我们提供以下日志:IntelUnit®应用程序的客户端应用程序崩溃解决方法:使用调试开关运行应用程序并将信息保存到日志文件,例如:Intel Unite.exe / debug> log.txt。 如果日志文件包含以下消息:EXCEPTION: - 密钥无效,无法在指定状态下使用。 关闭应用程序。删除C: Users eaviles AppData Roaming Microsoft Crypto RSA [sid] d046df文件。删除应用程序需要提升的管理员权限。 由于IntelUnite®应用程序不以管理员权限运行,因此您必须手动执行此操作。 IntelUnite®卸载程序日志:要获取日志文件,请输入以下命令:msiexec / i“Intel Unite Installer Name.mui.msi”/ L * v installerlog.txtIntelUnite®依赖日志: 为了能够从Unite的webrtc组件中获取信息,请获取该工具位于http://www.dependencywalker.com/打开文件夹中的PeerClient.dll文件:C: Program Files(x86) Intel Intel Unite Client x64 在应用程序显示信息后,请保存文件并将其发送给我们。 我希望它有所帮助。注意:第三方链接是为了您的方便而提供的,不应被视为英特尔对其中提供的内容,产品或服务的认可.Regards,Diego Sanchez Campos.Intel(R)客户支持 技术人员与英特尔(R)公司签订合同 以上来自于谷歌翻译 以下为原文 Hello yls, Thank you for your response. In this case, in order to answer and to assist you please provide us with the following logs: Client Application Crash Workaround for the Intel Unite® app: Run the application with the debug switch and save information to the log file, for example: Intel Unite.exe /debug >log.txt. If the log file contains the message: EXCEPTION: - Key not valid for use in specified state. Close the application. Delete the C:UserseavilesAppDataRoamingMicrosoftCryptoRSA[sid]d046df file. Deleting the application requires elevated admin privileges. Because the Intel Unite® application does not run with admin privileges, you have to perform this action manually. Intel Unite® uninstaller log: In order to get a log file please enter the following command: msiexec /i "Intel Unite Installer Name.mui.msi" /L*v installerlog.txt Intel Unite® dependency logs: In order to be able to grab the info from the webrtc component of Unite please get the tool is at http://www.dependencywalker.com/ Open the file PeerClient.dll located at the folder: C:Program Files (x86)IntelIntel UniteClientx64 After the app shows you the info, save the file and send it over to us please. I hope it helps. Note: 3rd party links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.. Regards, Diego Sanchez Campos. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation |
jerry1978 发表于 2018-10-29 11:11 这是我得到的错误 10/8/2018 4:21:38 PM创建Web套接字:wss:// unitesy***rdcst / systembroadcast / server / ws / hub - 10/8/2018 4:21:38 PM Web Socket ConnectAsync错误 - 无法连接到远程服务器 10/8/2018 4:21:38 PM再试一次...... - 10/8/2018 4:21:39 PM创建Web套接字:wss:// unitesy***rdcst / systembroadcast / server / ws / hub - 10/8/2018 4:21:39 PM Web Socket ConnectAsync错误 - 无法连接到远程服务器 10/8/2018 4:21:39 PM再试一次...... - 10/8/2018 4:21:40 PM创建Web套接字:wss:// unitesy***rdcst / systembroadcast / server / ws / hub - 10/8/2018 4:21:40 PM Web Socket ConnectAsync错误 - 无法连接到远程服务器 10/8/2018 4:21:40 PM Web Socket State:Closed - 10/8/2018 4:21:40 PM连接到Web套接字时出错。 系统广播将继续尝试每分钟连接一次。 如果连接尝试仍然失败,请检查配置设置和服务器状态,然后尝试重新启动Unite。 - 10/8/2018 4:21:40 PM集线器与系统广播集线器服务器断开连接 - 以上来自于谷歌翻译 以下为原文 this is the error i get 10/8/2018 4:21:38 PM Creating Web Socket: wss://unitesy***rdcst/systembroadcast/server/ws/hub - 10/8/2018 4:21:38 PM Web Socket ConnectAsync Error - Unable to connect to the remote server 10/8/2018 4:21:38 PM Trying again... - 10/8/2018 4:21:39 PM Creating Web Socket: wss://unitesy***rdcst/systembroadcast/server/ws/hub - 10/8/2018 4:21:39 PM Web Socket ConnectAsync Error - Unable to connect to the remote server 10/8/2018 4:21:39 PM Trying again... - 10/8/2018 4:21:40 PM Creating Web Socket: wss://unitesy***rdcst/systembroadcast/server/ws/hub - 10/8/2018 4:21:40 PM Web Socket ConnectAsync Error - Unable to connect to the remote server 10/8/2018 4:21:40 PM Web Socket State: Closed - 10/8/2018 4:21:40 PM Error connecting to web socket. System Broadcast will continue to attempt to connect once per minute. If connection attempts continue to fail, please check configuration settings and server status and try restarting Unite. - 10/8/2018 4:21:40 PM Hub disconnected from System Broadcast hub server - |
jerry1978 发表于 2018-10-29 11:16 Helloyls,感谢您的回复。我们正在进一步调查您的案件,我们会尽快与您联系.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello yls, Thank you for your response. We are investigating your case further, We will reach you back as soon as possible. Regards, Diego S. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-12 08:58 , Processed in 0.946190 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2081
