已安装Agilent IO Control v16。
根据http://cp.literature.agilent.com/litweb/pdf/5990-3731EN.pdf启用Tulip的Passprt适配器在NI-MAX和Agilent IO Control中均可识别。 但是,labview 2013没有看到它。我注意到NIVisaTulip只有32位。 这是问题吗? 它可以在LabVIEW 2013 32位中运行吗? 以上来自于谷歌翻译 以下为原文 Installed Agilent IO Control v16. Enabled Passprt for Tulip per http://cp.literature.agilent.com/litweb/pdf/5990-3731EN.pdf The adapter is recognized in both NI-MAX and Agilent IO Control. But yet, it is not seen by LabVIEW 2013. I noticed that NIVisaTulip is 32-bit only. Is this the problem? Would it work in LabVIEW 2013 32-bit? |
4个回答
你有连接的仪器吗?
如果他们出现在NI Max中,他们应该出现在Labview中。 您遵循了所有正确的步骤。 以上来自于谷歌翻译 以下为原文 Do you have any instruments connected? If they show up in NI Max they should show up in Labview. You followed all the correct steps. |
> {quote:title = lhornburg写道:} {quote}>你有连接的仪器吗? 如果他们出现在NI Max中,他们应该出现在Labview中。 >>您遵循了所有正确的步骤。 是的,我们连接了E5061A。 我应该在原帖中注意到我们能够做一个* IDN吗? 使用NI-MAX和Agilent Connection Expert进行查询。 严格的问题是在Windows 8.1上运行的LabVIEW 2013 64位我计划在周一看看LabVIEW 2013 32位会发生什么。 以上来自于谷歌翻译 以下为原文 > {quote:title=lhornburg wrote:}{quote} > Do you have any instruments connected? If they show up in NI Max they should show up in Labview. > > You followed all the correct steps. Yes, we have a E5061A connected. I should have noted in the original post that we are able to do a *IDN? query using both NI-MAX and Agilent Connection Expert. Issue is strictly with LabVIEW 2013 64-bit running on Windows 8.1 I am planning on Monday on seeing what happens with LabVIEW 2013 32-bit. |
> {quote:title = lhornburg写道:} {quote}>你有连接的仪器吗? 如果他们出现在NI Max中,他们应该出现在Labview中。 >>您遵循了所有正确的步骤。 是的,我们连接了E5061A。 我应该在原帖中注意到我们能够做一个* IDN吗? 使用NI-MAX和Agilent Connection Expert进行查询。 严格的问题是在Windows 8.1上运行的LabVIEW 2013 64位我正在计划看看LabVIEW 2013 32位的情况 以上来自于谷歌翻译 以下为原文 > {quote:title=lhornburg wrote:}{quote} > Do you have any instruments connected? If they show up in NI Max they should show up in Labview. > > You followed all the correct steps. Yes, we have a E5061A connected. I should have noted in the original post that we are able to do a *IDN? query using both NI-MAX and Agilent Connection Expert. Issue is strictly with LabVIEW 2013 64-bit running on Windows 8.1 I am planning on seeing what happens with LabVIEW 2013 32-bit which I |
更新:LabVIEW 2013(32位)没有问题。
非常感谢您如何使用LabVIEW 2013(64位)。 以上来自于谷歌翻译 以下为原文 Update: No issues with LabVIEW 2013 (32-bit). Would appreciate feedback how to get it working with LabVIEW 2013 (64-bit). |
只有小组成员才能发言,加入小组>>
1254 浏览 0 评论
2361 浏览 1 评论
2174 浏览 1 评论
2043 浏览 5 评论
2927 浏览 3 评论
1005浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
729浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
834浏览 0评论
1254浏览 0评论
GMT+8, 2024-12-5 10:18 , Processed in 1.604830 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
