扫一扫,分享给好友
当我尝试创建一个新的conda环境时,我得到了CondaMemoryError。
以上来自于谷歌翻译 以下为原文 I am getting CondaMemoryError when I trying to create a new conda environment. |
4个回答
嗨Toqi,感谢您与我们联系。您可以尝试以下建议。
输入计算节点(qsub -I)并尝试创建conda环境。 如果这不能解决您的问题,请删除工作空间中不需要的conda环境。 请按照以下步骤。将环境列为:a)conda env list删除不需要的环境b)conda env remove -n希望这可以解决你的问题.RegardsAswathy 以上来自于谷歌翻译 以下为原文 Hi Toqi, Thanks for reaching out to us. You can try out the below suggestions. 1. Enter the compute node (qsub -I) and try creating the conda environment. 2. If this does not solve your issue, delete the unwanted conda environment in your working space. Please follow the below steps. List the environments as: a) conda env list Delete the unwanted environment b) conda env remove -n Hope this solves your issue. Regards Aswathy |
jerry1978 发表于 2018-10-25 16:44 谢谢,它有效。 我在基础环境中安装了Tensorflow 1.7,支持多节点培训。 如何重置基础环境? 以上来自于谷歌翻译 以下为原文 Thanks, it worked. I have installed Tensorflow 1.7 with multi-node training support in the base environment. How do I reset the base environment? |
嗨,感谢您的回复。如果您可以为新问题提出新线程,那将会很棒。这是为了方便其他人参考。在新线程中包含更多关于基本环境和步骤的含义的详细信息 你跟着。注意,Aswathy 以上来自于谷歌翻译 以下为原文 Hi, Thanks for your response. It would be great if you could raise a new thread for the new issue. This is for ease of reference of others. Kindly include more details in the new thread about what you meant by base environment and the steps you have followed. Regards, Aswathy |
jerry1978 发表于 2018-10-25 17:07 嗨Toqi,听不到你的声音。 在先前的问题得到解决后关闭线程。为其他查询打开一个新的.RegardsAswathy 以上来自于谷歌翻译 以下为原文 Hi Toqi, Couldn't hear from you. Closing the thread as the prior issue got resolved. Kindly open a new one for other queries. Regards Aswathy |
只有小组成员才能发言,加入小组>>
382浏览 0评论
GMT+8, 2024-10-1 14:52 , Processed in 0.576527 second(s), Total 73, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
