电子发烧友论坛|
是否可以在N5232A PNA-L上以编程方式编辑分段扫描表?
我希望能够导入excel文件或.csv文件来编辑分段扫描表。 这可能吗? 或者还有另一种远程编程分段扫描的方法吗? 以上来自于谷歌翻译 以下为原文 Is it possible to edit a segmented sweep table programmatically on a N5232A PNA-L? I was hoping to be able to import an excel file or .csv file to edit a segmented sweep table. Is this possible? Or is there another way to program the segmented sweep remotely? |
2个回答
我不知道上传.csv文件的方法。
但是有用于创建段表的SCPI和COM命令。 这是SCPI命令。 提供了一个示例链接:http://na.support.keysight.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/Segment.htm#list 以上来自于谷歌翻译 以下为原文 I don't know of a way to upload a .csv file. But there are SCPI and COM commands for creating a segment table. Here is the SCPI command. An example link is provided: http://na.support.keysight.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/Segment.htm#list |
目前PNA无法直接从文件(.csv或其他)构建段表,但是Gary提到的:SENS:SEG:LIST命令是目前在PNA中创建段表的最快方法 (如果您正在处理大量细分 - 通常超过10个)。 如果您为csv文件编写自己的解析器,则可以将该信息提供给list命令并在一次调用中构建段表。 我在C#中有csv解析器的示例,以及知道如何将数据提供给list命令的示例方法。 如果这对你有帮助,请告诉我,我会在这里发布。 以上来自于谷歌翻译 以下为原文 currently there is no way for PNA to directly build a segment table from a file (.csv or otherwise), but the :SENS:SEG:LIST command that Gary alluded to is by far the fastest way to create a segment table in the PNA (if you are dealing with a large number of segments - typically more than 10). if you write your own parser for a csv file, you can then feed that information into the list command and build the segment table in one call. I have examples of csv parser in C# and example methods that know how to feed the data into the list command. if that is helpful to you, let me know and I will post them here. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 10:43 , Processed in 0.678598 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1859
