我刚刚获得了16702B,我需要重新点燃,因为它无法正常启动。
我找到了这篇知识库文章:http://www.keysight.com/main/editorial.jspx?cc = us& pl = eng& ckey = 375133& nid = -536902551.536880914&amp ;id = 375133这表明我可以得到 免费提供CD-ROM,但它引用旧的Agilent URL而不是Keysight URL。 因此,当我点击链接时,它就是404。 有没有办法让我获得一张重新点播的CD-ROM光盘? 以上来自于谷歌翻译 以下为原文 I just acquired a 16702B and I need to reignite as it is not booting properly. I found this knowledge base article: http://www.keysight.com/main/edi ... 80914&id=375133 It indicates that I can get a CD-ROM for free but it references the old Agilent URL rather than the Keysight URL. As such, it 404's when I click the link. Is there a way for me to get a reignite CD-ROM disc? |
8个回答
16702B“失去了支持”,这实际上意味着过时,并且在2010年2月被Keysight(或安捷伦)以任何方式支持。我们创建HP-UX CD的能力在此之后的一个月内就消失了。
也就是说,你可以试试这个:ftp://ftp.keysight.com/cos/outbound/16700/16700_A0290.iso。 将其刻录到CD-ROM而不是DVD上,然后尝试一下。 如果这不起作用,也许观看论坛的其他人可能会有答案。 我会看到修复该网页的问题。 如果此链接适合您,请告诉我们。 我不再有16702试用了。 人 以上来自于谷歌翻译 以下为原文 The 16702B went "out of support", which essentially means obsolete, and not supported in any way by Keysight (or Agilent), in February, 2010. Our ability to create HP-UX CD's went away within a month after that. That said, you might try this: ftp://ftp.keysight.com/cos/outbound/16700/16700_A0290.iso. Burn that onto a CD-Rom, not a DVD, and give it a try. If that doesn't work, maybe someone else who watches the forums might have an answer. I'll see about getting that web page fixed. Let us know if this link works for you. I no longer have a 16702 to try it with. Al |
nvywyerwer 发表于 2018-10-22 17:56 谢谢你的链接!! 我试一试。 是否有可能将文章擦洗掉,以便没有其他人得到我所做的错误印象,仍然可以获得该光盘? 以上来自于谷歌翻译 以下为原文 thanks for the link!! I'll give it a try. Is it possible to get the article scrubbed, then, so that no one else gets the false impression that I did that it's still possible to get that disc? |
嗯,没有快乐可以启动。 但是,谢谢你的帮助。 我会看看我是否可以在易趣上找到一个。 以上来自于谷歌翻译 以下为原文 Well, no joy on it being bootable. But, thanks for your help anyway. I'll see if I can find one on eBay or something. |
以下是可能有用的更多信息(来自Keysight的下一级支持):Al非常正确,ftp://ftp.keysight.com/cos/outbound/16700/16700_A0290.iso应该是一个很好的.iso映像。 但是,也许使用的CD刻录机软件并没有创造出好的CD。 可能16702B中的硬盘可能实际上是坏的。 虽然我认为库存中没有剩余的SCSI硬盘,但我们可以为您提供替代硬盘驱动器的制造商和MPN。 还有4 GB和9 GB以及18 GB和36 GB甚至72 GB大小的替代SCSI硬盘。如果当前在16702B中的硬盘是新的“原始”硬盘,则需要对硬盘进行分区。 通常,这是通过重新点火程序自动完成的。 但是,如果硬盘驱动器是早期的2 GB,那么这将无法工作,16702B的最新操作系统将无法在其上运行。我认为任何操作系统版本的2.0或更高版本至少需要4 GB硬盘驱动器。 此外,*这是最可能出现的问题*,16702B可能已经存放了很长时间,并且CPU板上的电池已经死亡。 如果设备已经处于未插入状态一段时间,那么CPU板上的电池很可能已经死亡。 这意味着CPU板上的时钟保持时间已经停止。 重新插入后,HP-UX操作系统将假定时间是Unix时间的开始,大约是1970年左右。 重新启动过程的第一件事是,许多很多文件都从CD复制到HDD上的临时位置。 并且,在该临时位置,他们将获得当前系统时钟的日期戳,该日期戳将在1970年左右左右。 因此,当需要将它们从临时位置复制到其真实位置时,安装将抱怨它们比实际位置中的文件的日期戳“更旧”。 因此,他们不会被复制,重新点燃将失败。 对此的直接解决方案如下: - 通过反复敲击ESC键来中断启动 - 当您收到提示时,输入CO命令以查看可用的所有命令 - 您关心的命令是TI( 时间设定)命令。 输入TI的命令以查看它认为当前日期是什么。 使用TI命令输入正确的当前日期和时间以更正日期格式为cn:yy:mm:dd:hh:mm:ss for century:year:month:day:hr:min:sec例如,as I 输入它:20:09:08:11:14:35:00电池是CPU板上的BR2325。 它很容易被替换。 原件可能是松下的,但任何人都会工作。 如果我没记错的话,它只是一个扁平纽扣电池。 以上来自于谷歌翻译 以下为原文 Here is more information that might help (from the next level of support at Keysight): Al is very correct that ftp://ftp.keysight.com/cos/outbound/16700/16700_A0290.iso should be a good .iso image.. However, perhaps the CD burner software used did not create a good CD. Possibly the HDD in the 16702B might actually be bad. While I do not think that there are any remaining SCSI HDDs in stock, we could get you the manufacturers and MPN of alternative HDDs. There were alternative SCSI HDD in 4 GB and 9 GB and 18 GB and 36 GB and even 72 GB sizes.. If the HDD currently in the 16702B is a new ‘raw’ HDD, then the HDD would need to be partitioned. Normally this is done automatically by the reignite procedure. However, if the HDD is an early 2 GB one then this will not work and the latest OS for the 16702B won’t run on it.. Any OS version of 2.0 or later required at least a 4 GB HDD, I think. Also, and *this is the most probable problem*, the 16702B may have been in storage for a long time and the Battery on the CPU board has died. If the unit has been sitting in an unplugged state for quite a while, then the battery on the CPU board has very probably died. This means that the clock keeping time on the CPU board has stopped. Upon plugging it back in, the HP-UX Operating System will presume that the time is the beginning of Unix time which was about 1970 or so. The first thing that happens with a reignite procedure is that many, many files are copied from the CD to a temporary location on the HDD. And, in that temporary location, they will acquire the date stamp of the current system clock which would be around 1970 or so. So then, when it comes time for them to be copied from the temporary location to their real location, the installation will gripe that they are ‘older’ than the date stamp of the files in the real location. Thus, they will not get copied and the reignite will fail. The immediate solution to this is as follows: - Interrupt the boot by repeatedly whacking the ESC key - When you get a prompt, enter a CO command to see all of the commands available to you - The command about which you care is the TI (time set) command. Enter a command of TI to see what it thinks the present date is. Enter the correct current date and time with a TI command to correct the date The format is cn:yy:mm:dd:hh:mm:ss for century:year:month:day:hr:min:sec For example, as I type this it would be: 20:09:08:11:14:35:00 The battery is a BR2325 on the CPU board. It is very easily replaced. The originals were probably by Panasonic , but anyone’s will work. It is just a flat button battery, if I recall correctly. |
nvywyerwer 发表于 2018-10-22 18:46 感谢电池的提示。 我需要花几天时间才能拿到2325个电池中的一个,但是现在我已经设法让时间情况得到解决。 我现在卡住试图启动重新点火CD。 我烧了图像,范围看到驱动器中的光盘,但是当我这样做时:BO P1,它访问驱动器,然后启动过程挂起“HARD Booted”。 信息。 我可以让它坐在那里好几个小时(而且有)没有任何反应。 我正在遵循服务指南(16700-97015.pdf)文档(第44页)中的“Reignite:重新安装操作系统”说明。我是否错过了一些明显的内容? 以上来自于谷歌翻译 以下为原文 thanks for the tip on the battery. It took several days to get my hands on one of the 2325 batteries but now that I have, I've managed to get the time situation sorted out. I'm now stuck trying to boot the re-ignite CD. I have burned the image and the scope sees the disc in the drive but when I do: BO P1, it accesses the drive and then the boot process hangs at the "HARD Booted." message. I can leave it sitting there for hours (and have) and nothing happens. I'm following the "Reignite: Re-installing the operating system" instructions from the service guide (16700-97015.pdf) document, page 44. Have I missed something obvious?? |
我知道你刚才这样问过,但我刚看了你的留言。 我订购了HP 16702B逻辑分析仪,并且正在寻找操作系统光盘。 根据我的阅读,Keysight FTP站点上的光盘缺少一些非常重要的字节(大约225字节或类似的东西)。 无论如何,EEVBlog上的用户能够上传他多年来从惠普获得的官方光盘的一些图像。 如果你仍然需要一份副本而且它没有违反论坛规则,我可以给你一个最新版本的链接(我相信这是至少最新的)2.90.00。 如果Keysight想要,我可以为他们提供一个链接,他们可以用我可用的可启动的ISO替换不可启动的ISO。 或者他们至少可以比较两个ISO,即我的FTP服务器上的ISO。 如果有兴趣的话,我可以提供关于Keysight FTP站点上ISO的实际错误的技术信息。 发现问题的人在他的研究中非常彻底,并解释了它究竟出了什么问题。 另外,Keysight可以为16702B发布一些源代码吗? 如果系统已经过时,它会伤害到什么,或者你不能这样做吗? 我希望能够尝试更新代码。 谢谢!编辑:Spork Schivago于2016年1月6日上午10:48 以上来自于谷歌翻译 以下为原文 I know you asked a while ago for this but I just read your message. I've ordered an HP 16702B Logic Analyzer and was looking for the OS disc as well. From what I've read, the disc on Keysight's FTP site is missing a few very important bytes (around 225 bytes or something like that). Anyway, a user over at EEVBlog was able to upload some images of the official discs he got from HP over the years. If you still need a copy and it doesn't violate the forum rules, I could give you a link to the latest version (I believe it's the latest at least) 2.90.00. If Keysight wanted, I could provide them with a link and they could replace the non-bootable ISO with the working bootable one that I have. Or they could at least compare the two ISOs, the one I have with the one on their FTP server. I can provide technical information as to what's actually wrong with the ISO on Keysight's FTP site if anyone is interested. The person that discovered the problem was very thorough in his research and explained exactly what is wrong with it. On a side note, would it be possible for Keysight to release some source code for the 16702B? If the system is obsolete, would it hurt anything or can't you guys do that? I'd love to be able to try to update the code a bit. Thanks! Edited by: Spork Schivago on Jan 6, 2016 10:48 AM |
gwerwfe 发表于 2018-10-22 19:10 Spork,我发了一个PM。 人 以上来自于谷歌翻译 以下为原文 Spork, I'm sending a PM. Al |
我回答了PM。 如果您有任何问题,请告诉我。 由于历史原因,可能值得将所有版本放在FTP站点上。 叉勺 以上来自于谷歌翻译 以下为原文 Al, I responded to the PM. Please let me know if you have any problems with anything. Might be worth putting all the versions up on the FTP site, just for historical reasons. Spork |
只有小组成员才能发言,加入小组>>
1074 浏览 0 评论
2307 浏览 1 评论
2094 浏览 1 评论
1968 浏览 5 评论
2839 浏览 3 评论
843浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
717浏览 0评论
1400浏览 0评论
1075浏览 0评论
GMT+8, 2024-10-2 06:07 , Processed in 1.257004 second(s), Total 61, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
