设备:PIC16F1828编译器:V1.45 X IDE:V4.01HI,在那里。我在调试会话期间,由于我想知道程序流现在在哪里,我点击“暂停”,然后我遇到这个错误:目标设备没有准备好调试。请检查配置位设置并在继续之前对设备进行编程。这个失败的最常见的原因是振荡器和/或PGC/PGD设置。我发现如果我评论SLIP(),这个错误就消失了。我没有找到PGC/PGD设置,你可以把我推荐到那里吗?谢谢您。
以上来自于百度翻译 以下为原文 Device: PIC16F1828 Compiler: v1.45 X IDE: v4.01 Hi, there. I'm during the debug session, due to that I want to see where the program flow is now, I click "Pause", then I run into this error: The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings. I found that if I comment SLEEP();, this error is gone. I didn't find PGC/PGD setting, may you plz refer me to there? Thank you. |
3个回答
这是一个通用的消息,如果您能够启动调试会话,它不适用于您。我怀疑您可以调试睡眠指令,因为处理器真的会进入睡眠状态。
以上来自于百度翻译 以下为原文 That is a generic message, if you are able to start a debug session, it doesn't apply to you. I doubt you can debug a SLEEP instruction, as the processor really will go to sleep. |
设备:PIC18F420,MPLAB 8.92,MPASM振荡器设置到XT(4MHz XTAL振荡器)PGC和PGD直接连接到PICTIT3程序员(无拖拉),为什么没有设置代码MPASM中配置比特的例子?…配置位窗口没有引用错误消息中所述的错误。
以上来自于百度翻译 以下为原文 device : PIC18F4520, mplab 8.92, mpasm Oscillator set to to XT (4Mhz xtal oscillator) PGC & PGD direct connection to PIcKit3 programmer (no pull ups) Why are there no examples of setting the config bits in code Mpasm? .... the config bits window has no references to the errors stated in the error message. |
当我发布了最后一个查询时,我发现UsFieldLink帮助我识别在汇编程序中配置比特的正确语法如下:http://WW1.Microchip .com /下载/ En/DeVicoDC/PIC%20COFFIG% 20%%20FalATTySythActhIdand Dealix.PDF
以上来自于百度翻译 以下为原文 Almosgt as soon as I'd posted the last query, I found usefull link to help me identify the correct syntax for config bits dode in assembleras follows: http://ww1.microchip.com/downloads/en/DeviceDoc/PIC%20Config%20bit%20Format_Syntax_AndDefinitions.pdf |
只有小组成员才能发言,加入小组>>
5244 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3214 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2261 浏览 5 评论
779浏览 1评论
673浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
599浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
683浏览 0评论
580浏览 0评论
GMT+8, 2024-12-25 19:10 , Processed in 1.308701 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
