你好!
首先,非常感谢您在Wandboard上运行Ubuntu 18.04 LTS的指导! 基本设置工作正常,我可以在控制台上登录系统。 在“通过Etnaviv项目的2D / 3D视频加速”部分中,您将介绍如何安装xserver-xorg-video-ARMada-etnaviv驱动程序。 不幸的是,“sudo apt-get install xserver-xorg-video-armada-etnaviv”产生了一个“E:无法找到包xserver-xorg-video-armada-etnaviv”错误。 事实上似乎http://repos.rcn-ee.com/ubuntu/pool/main/x/xf86-video-armada/只有xenial的文件,但不是bionic的文件。 任何人都可以确认这种行为吗? 我想知道:如果确实只是遗漏了,是否有人有如何创建必要的Debian软件包的指令,类似于xenial存在的软件包? 谢谢! 以上来自于谷歌翻译 以下为原文 Hello! First of all thank you very much for your instruction to get Ubuntu 18.04 LTS on Wandboard running! The basic setup works just fine and I can log into the system on the console. In section “2D/3D Video Acceleration via Etnaviv Project” you describe how to install the xserver-xorg-video-armada-etnaviv driver. Unfortunately a “sudo apt-get install xserver-xorg-video-armada-etnaviv” produces a “E: Unable to locate package xserver-xorg-video-armada-etnaviv” error. Indeed it seems that http://repos.rcn-ee.com/ubuntu/pool/main/x/xf86-video-armada/ only has the files for xenial, but not for bionic. Can anybody please confirm this behavior? I am wondering: if it is indeed simply missing, does anybody have an instruction how to create the necessary Debian package, similar to the one that is existing for xenial? Thanks! |
9个回答
@ pideu-mh我需要为仿生重建那个包,我想我已经假设Ubuntu已经合并了所有的etnaviv位。
问候, 以上来自于谷歌翻译 以下为原文 @pideu-mh I’ll need to rebuild that package for bionic, I guess I had assumed Ubuntu had merged all the etnaviv bits by now. Regards, |
非常感谢您的回答。
你能粗略估计你何时有时间这样做? (对我而言,这并不紧急,我有一个正常工作的Ubuntu 16.04。我可以简单地计划什么时候继续我的实验。) 如果你可以分享如何重建这个包的信息并且可能将指令添加到维基页面,那将是很棒的。 这些对非Ubuntu和/或非Debian用户也很有用。 再次感谢! 以上来自于谷歌翻译 以下为原文 Thank you very much for your answer. Can you give a rough estimation of when you have the time to do this? (For me it is not urgent, I have a working Ubuntu 16.04 setup. I can simply plan better when to continue with my experiments.) It would be great if you could share the information how to rebuild this package as well and maybe add the instructions to the wiki page. These could be useful for non-Ubuntu and/or non-Debian users as well. Thanks again! |
@ pideu-mh,没有时间的承诺,这是我去年的笔记,xf86-video-armada已经改变了很多:
gist.github.com https://gist.github.com/RobertCNelson/fc6d07157b0fcc13b9c28c5832fdc74b#file-src-step-by-step 目前一步一步 #start with:https://rcn-ee.net/rootfs/bb.org/testing/2016-11-06/lxqt-4gb/ # #packaging更改: #galcore-headers,move / usr / local / include / HAL - > / usr / include / HAL #libetnaviv-dev:打包... #libdrm-armada-dev:打包... #xserver-xorg-video-armada:打包... cd / opt / scripts / tools /; git pull; sudo ./update_kernel.sh 此文件已被截断。 显示原创 src一步一步 #start with:https://rcn-ee.net/rootfs/bb.org/testing/2016-11-06/lxqt-4gb/ cd / opt / scripts / tools /; git pull; sudo ./update_kernel.sh sudo apt-get install xorg-dev xutils-dev cd〜/ git clone https://github.com/etnaviv/galcore_headers sudo cp -frv galcore_headers / include_v4 / usr / include / HAL 此文件已被截断。 显示原创 xorg日志 [11.328] X.Org X Server 1.16.4 发布日期:2014-12-20 [11.328] X协议版本11,修订版0 [11.328]构建操作系统:Linux 3.16.0-0.bpo.4-armmp-lpae armv7l Debian [11.329]当前操作系统:Linux beaglebone 4.4.32-ti-r68#1 SMP Thu 11月17日12:17:45 UTC 2016 armv7l [11.329]内核命令行:console = ttyO2,115200n8 root = / dev / mmcblk0p1 ro rootfstype = ext4 rootwait coherent_pool = 1M quiet [11.329]建造日期:2015年2月11日01:18:06 AM [11.329] xorg-server 2:1.16.4-1(http://www.debian.org/support) [11.329]当前版本的pixman:0.32.6 此文件已被截断。 显示原创 现在几天,它很好地融入了yocto / etc。 问候, 以上来自于谷歌翻译 以下为原文 @pideu-mh, no time promises, here are my notes from last year, xf86-video-armada has changed alot: gist.github.com https://gist.github.com/RobertCNelson/fc6d07157b0fcc13b9c28c5832fdc74b#file-src-step-by-step Current Step-by-Step #start with: https://rcn-ee.net/rootfs/bb.org/testing/2016-11-06/lxqt-4gb/##packaging changes:#galcore-headers, moved /usr/local/include/HAL -> /usr/include/HAL#libetnaviv-dev: packaged...#libdrm-armada-dev: packaged...#xserver-xorg-video-armada: packaged...cd /opt/scripts/tools/ ; git pull ; sudo ./update_kernel.shThis file has been truncated. show originalsrc step by step #start with: https://rcn-ee.net/rootfs/bb.org/testing/2016-11-06/lxqt-4gb/cd /opt/scripts/tools/ ; git pull ; sudo ./update_kernel.shsudo apt-get install xorg-dev xutils-dev cd ~/git clone https://github.com/etnaviv/galcore_headerssudo cp -frv galcore_headers/include_v4 /usr/include/HALThis file has been truncated. show originalxorg log [ 11.328] X.Org X Server 1.16.4Release Date: 2014-12-20[ 11.328] X Protocol Version 11, Revision 0[ 11.328] Build Operating System: Linux 3.16.0-0.bpo.4-armmp-lpae armv7l Debian[ 11.329] Current Operating System: Linux beaglebone 4.4.32-ti-r68 #1 SMP Thu Nov 17 12:17:45 UTC 2016 armv7l[ 11.329] Kernel command line: console=ttyO2,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M quiet[ 11.329] Build Date: 11 February 2015 01:18:06AM[ 11.329] xorg-server 2:1.16.4-1 (http://www.debian.org/support) [ 11.329] Current version of pixman: 0.32.6This file has been truncated. show original Now days, it’s pretty well integrated into yocto/etc. Regards, |
好的,让它工作......
包正在建立最终上传。 问候, 以上来自于谷歌翻译 以下为原文 Okay, got it working… Regards, |
非常感谢你。
我可以确认它对我也有用 - 至少部分是这样。 安装xserver-xorg-video-armada-etnaviv之后我注意到根本没有安装任何图形环境,所以我完全安装了xubuntu-desktop。 重置后,登录屏幕出现,但现在鼠标和键盘都没有工作。 两者都被正确识别,我可以看到相应的消息 [220.729623] u*** 1-1:USB断开,设备编号2 [222.590474] u*** 1-1:使用ci_hdrc的新型低速USB设备3 [222.798008] u*** 1-1:找到新的USB设备,idVendor = 0461,idProduct = 4d51 [222.798039] u*** 1-1:新的USB设备字符串:Mfr = 0,Product = 2,SerialNumber = 0 [222.798059] u*** 1-1:产品:戴尔激光鼠标 [222.822768]输入:DELL激光鼠标为/devices/soc0/soc/2100000.aips-bus/2184200.u***/ci_hdrc.1/u***1/1-1/1-1:1.0/0003:0461:4D51.0002/ 输入/ INPUT1 [222.827624] hid-generic 0003:0461:4D51.0002:输入,hidraw0:USB HID v1.11鼠标[DELL Laser Mouse] on u***-ci_hdrc.1-1 / input0 这有点奇怪,我正在尝试解决它 - 但这可能是一个不同的问题,与失踪的驱动程序无关。 以上来自于谷歌翻译 以下为原文 Thank you very much. I can confirm that it works for me as well - at least partially. After installing xserver-xorg-video-armada-etnaviv I noticed that no graphical environment was installed at all, so I did a full install of xubuntu-desktop. After a reset the login screen came up, but neither mouse nor keyboard are working now. Both are recognized correctly though, I can see the corresponding messages like [ 220.729623] u*** 1-1: USB disconnect, device number 2[ 222.590474] u*** 1-1: new low-speed USB device number 3 using ci_hdrc[ 222.798008] u*** 1-1: New USB device found, idVendor=0461, idProduct=4d51[ 222.798039] u*** 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0[ 222.798059] u*** 1-1: Product: DELL Laser Mouse[ 222.822768] input: DELL Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.u***/ci_hdrc.1/u***1/1-1/1-1:1.0/0003:0461:4D51.0002/input/input1[ 222.827624] hid-generic 0003:0461:4D51.0002: input,hidraw0: USB HID v1.11 Mouse [DELL Laser Mouse] on u***-ci_hdrc.1-1/input0That is a little bit strange and I am currently trying to solve it - but this is probably a different problem and has nothing to do with the missing driver. |
我忘了问:
我认为Ubuntu 18.04.1映像还有一些其他小问题。 我可以在这里或其他地方报道吗? 在论坛? 如果是这样,作为单独的线程? 或者我应该通过邮件给你写信? 请指教。 以上来自于谷歌翻译 以下为原文 I forgot to ask: I think there are a few other minor problems with the Ubuntu 18.04.1 image. Shall I report them here or somewhere else? In the forum? If so, as separate threads? Or shall I write them to you via mail? Please advise. |
这是正确的,xserver-xorg-video-armada-etnaviv包没有引入默认的xorg windows管理器。
这取决于你安装。 至于为什么键盘/鼠标不起作用。 你可以试试: sudo update-initramfs -ck`uname -r` 看看ubuntu是否更早期待鼠标/键盘驱动程序...... 问候, 以上来自于谷歌翻译 以下为原文 That is correct, the xserver-xorg-video-armada-etnaviv package doesn’t bring in a default xorg windows manager. That’s up to you to install. As far as why the keyboard/mouse doesn’t work. You can try: sudo update-initramfs -ck `uname -r`To see if ubuntu was expecting the mouse/keyboard drivers earlier… Regards, |
这取决于“ubuntu”问题使用ubuntu的启动板。
我们只构建u-boot,内核和一些启用包。 问候, 以上来自于谷歌翻译 以下为原文 That depends, for “ubuntu” problems use ubuntu’s launchpad. We are only building u-boot, kernel and a few enablement packages. Regards, |
你好@RobertCNelson。
鼠标和键盘现在正在工作。 问题是sudo depmod -a还没有在目标上执行。 因此,evdev模块未加载,因此输入设备不存在。 再次感谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hello @RobertCNelson. Mouse and keyboard are now working. The problem was that sudo depmod -a had not been executed on the target yet. Because of that the evdev module was not loaded and so the input devices were not present. Thanks again for your help. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 07:07 , Processed in 1.116541 second(s), Total 109, Slave 92 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1461
