自己顶!求助
有Flash Loader
但是一直没成功,我下了官网的最新版本2.8,不知道哪里出了问题
下面是版本说明是不是还不支持啊
* V2.8.0 - 01-September-2015 =============================== New Features ************ + Adding support of STM32L4x6xx devices + Adding support of STM32L0xx 192K of flash devices + Adding support of STM32F74x/5x devices + Adding support of STM32F412xx/F410xx/F446xx/F469xx/F479xx devices + Adding support of STM32F303/302xD/E devices + Fix com port up to 255 + Fix GUI/command line version supporting .bin at an address offset different from base address + Fix STUARTBLLIB.dll to support non-aligned address at end of flash area. But data should be always multiple of 4 bytes. Known Limitations ***************** + Options Bytes management of STM8, STM32L1/L0/L4 and STM32F0/2/3/4/7 devices is supported only in Command line version for batch programming, + Automatic selection of some STM8 devices may not work properly. If required, use command line version with batch files customization, + on Some STM32 MCus Write protection of last pages which is controlled by the last protection bit7 in WPR3 options byte is working properly but the Graphical view of check boxes may not updated accordingly on some devices with large size greater than 128Kbytes. To enable/disable the write protection of last pages, you can check/uncheck only the first page of this group of pages on the graphical view. + STM32L "Erase all" feature is not supported. See AN2606 for more details. |
我用的是串口1,而且用mcuisp能读出bootloader版本号,但是无法下载,用官网的就连不上,我用的是u***转的422,不知道是不是有影响,总之用官网的就一直不识别设备,这个芯片的Bootloader肯定可以用,关键是不知道官网的上位机能不能支持,或者有没有第三方可以用的推荐下
boot0为1 boot1为0 进的是bootloader模式吧,您用什么上位机下载?有推荐的吗 |
isp?这个我也不懂呀。哈哈哈。支持一下
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2776 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2379 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2255 浏览 0 评论
2367 浏览 1 评论
1625 浏览 1 评论
/9
GMT+8, 2025-12-1 16:02 , Processed in 0.952858 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4324
