在使用STM32f103做一个项目,使用串口中断发送数据时,数据出现了断帧,断帧的间隔时间从串口打印log来看,最大的达到40多ms,小的时间间隔也有20ms左右,不知道是不是因为操作系统造成了。
1.系统是用的ucos ii 2.串口使用了串口1 和 2 都是利用串口中断接收和发送 3.部分驱动代码 谢谢各位 /*======================================================================================================= *Function: Bsp_UartNVIC_Config( ) => *Input : *Uart *Output : None ========================================================================================================*/ void Bsp_UartNVIC_Config( UART_Def *Uart ) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = Uart->UARTx_IRQn; //Enable the USARTy Interrupt NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = Uart->PreemPriority; NVIC_InitStructure.NVIC_IRQChannelSubPriority = Uart->SubPriority; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /*======================================================================================================= *Function: Bsp_UartConfig( ) => *Input : *Uart *Output : None ========================================================================================================*/ void Bsp_UartConfig( UART_Def *Uart ) { USART_InitTypeDef USART_InitStructure1; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd( Uart->RCC_PinPort, ENABLE ); // config USARTx Pin clock if( Uart->USARTx == USART2 || Uart->USARTx == USART3 ) // config USARTx clock { RCC_APB1PeriphClockCmd( Uart->RCC_Uartx, ENABLE ); } else if( Uart->USARTx == USART1 ) // config USARTx clock { RCC_APB2PeriphClockCmd( Uart->RCC_Uartx, ENABLE ); } GPIO_InitStructure.GPIO_Pin = Uart->Rx_Pinx; // Configure USARTy Rx as input floating GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( Uart->PinPort, &GPIO_InitStructure ); GPIO_InitStructure.GPIO_Pin = Uart->Tx_Pinx; //Configure USARTy Tx as alternate function push-pull GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( Uart->PinPort, &GPIO_InitStructure ); USART_InitStructure1.USART_BaudRate = Baud_Table[ Uart->Baud_Rate ]; //USART1 mode config USART_InitStructure1.USART_WordLength = USART_WordLength_8b; USART_InitStructure1.USART_StopBits = USART_StopBits_1; USART_InitStructure1.USART_Parity = Parity_Table[ Uart->Parity ] ; USART_InitStructure1.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure1.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init( Uart->USARTx, &USART_InitStructure1 ); USART_ITConfig( Uart->USARTx, USART_IT_RXNE , ENABLE ); USART_ITConfig( Uart->USARTx, USART_IT_IDLE , ENABLE ); USART_ITConfig( Uart->USARTx, USART_IT_TXE , DISABLE ); USART_Cmd( Uart->USARTx, ENABLE ); } /*======================================================================================================= *Function: Bsp_UartRingSend( ) => USARTx send data from ring buff *Input : *Uart, data *Output : None ========================================================================================================*/ void Bsp_UartIntRingSend( UART_Def *Uart ) { uint8_t data; if( Get_bytes_count( &Uart->T_RingBuff ) != 0 ) { #if RS485_EN_USE == true RS485_TX_EN(); #endif Read_ring_buffer( &Uart->T_RingBuff, &data, 1 ); Bsp_UartSendData( Uart, data ); if( Uart->TxBusy == false ) { Uart->TxBusy = true; USART_ITConfig( Uart->USARTx, USART_IT_TXE , ENABLE ); } } else { #if RS485_EN_USE == true g_Time3Count.rxdelay = RS485_RxDelayTable[ Uart->Baud_Rate ]; #endif Uart->TxBusy = false; USART_ITConfig( Uart->USARTx, USART_IT_TXE , DISABLE ); } } |
6个回答
被更高等级的中断拦截了。
加个互斥信号量就可以了
系统是不是有其他更高优先级的中断发送。
没有用过103跑系统的
是不是有高优先级的中断打断了
FX1N PLC 源代码没有用过103跑系统的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2961 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2463 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2331 浏览 0 评论
2455 浏览 1 评论
1674 浏览 1 评论
/9
GMT+8, 2025-12-3 10:46 , Processed in 0.902694 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1780
