我相信在我的芯片的演示代码中,POSCMD配置位设置是错误的。比特应该设置为XT模式,而不是HS。我使用的是Pig24FJ1024GB610 PIM的探索者16/32板。我下载了demo CODEExpReal1616demoV2017Y05Y2ZIP开始。我的芯片的匹配项目加载得很好。我从文件系统C复制配置位设置来启动我自己的项目。在我的开发过程中,在执行和重新编译我的代码之后,我经常使用PigiToBoad重新连接到板上。在振荡器代码的审查期间,我注意到POSCMD配置位设置为HS模式的晶体10-32兆赫。但是探险者板只有8兆赫的晶体。POSCMD应该设置为XT模式。我将配置位代码更改为POSCMD= XT,我的重新连接问题消失了。
以上来自于百度翻译 以下为原文 I believe the POSCMD config bit setting is wrong in the demo code for my chip. Bit should be set to XT mode, not HS. I'm using an Explorer 16/32 board with a PIC24FJ1024GB610 PIM. I downloaded the demo code explorer16_demo_v2017_05_26.zip to get started. The matching project for my chip loaded and went well. I copied over the config bit settings from file system.c to start my own project. During my development, I had frequent problems reconnecting to the board using PICKitOnBoard after breaking execution and recompiling my code. During a review of the oscillator code, I noticed the POSCMD config bit set to HS mode for crystals 10-32 MHz. But the Explorer board only has an 8 MHz crystal. POSCMD should have been set to XT mode. I changed the config bit code to POSCMD = XT and my reconnect problems went away. |
3个回答
在各种PIC24 MLA项目中,我看到了同样的问题。
以上来自于百度翻译 以下为原文 I see the same issue in various PIC24 MLA projects. |
前一段时间,我在Pig24e MLA项目中发现了类似的问题:PIC被配置为用PLL启动,但是在PLL运行时,演示代码改变PLL设置,这是不允许的。这两件事都是“可能大部分时间都在工作”。
以上来自于百度翻译 以下为原文 Some time ago I saw a similar issue on the PIC24E MLA projects for the Explorer 16/32: the PIC was configured to start up with the PLL, but the demo code changes the PLL settings while the PLL is running, which is not allowed. Both of these are things that "probably work most of the time." |
使用我的资源管理器16/32,无论主振荡器选择如何,与PigTigBoad的这种重新连接问题都是一个问题。无论内部FRC、XT、HS有无PLL,我仍然看到重新连接问题。使用一个真正的皮卡3为我工作。我对PKOB没有解决办法。
以上来自于百度翻译 以下为原文 With my Explorer 16/32 this reconnect problem with the PICkitOnBoard is an issue regardless of the primary oscillator selection. No matter which Internal FRC, XT, HS with and without PLL I still see reconnect problems. Using a real PICkit3 works for me. I have no solution for the PKOB. |
只有小组成员才能发言,加入小组>>
5104 浏览 9 评论
1965 浏览 8 评论
1904 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3134 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2202 浏览 5 评论
675浏览 1评论
550浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
423浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
573浏览 0评论
471浏览 0评论
GMT+8, 2024-10-20 07:58 , Processed in 1.068212 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
