Bios没有看到系统盘。我通过clonezilla设置图像并出现磁盘。安装系统后,磁盘不会出现在BOOT部分。
我尝试从Legacy和UEFI开始。 Plz谁可以帮忙解决这个问题? 对不起,我的英语不好。 info.png 97.6 K. 以上来自于谷歌翻译 以下为原文 Bios does not see the system disk.I set the image through the clonezilla and the disk appears.After installing the system, the disk does not appear in the section BOOT. I try to start with Legacy and UEFI. Plz who can help in this matter? Sorry for my bad english.
3个回答
HelloTren12,
我正在审查您一直面临的问题,我想通知您,由于它是第三方软件,因此不支持Clonezilla。 我想与您分享来自Clonezilla的链接,它可以帮助您找出问题的根源: https://drbl.org/faq/fine-print.php?path=./2_System/65_Clonezilla_support_RAID.faq#65_Clonezilla_support_RAID.faq另一方面,如果使用没有Clonezilla配置的磁盘安装操作系统,则服务器系统 识别磁盘? 最诚挚的问候,Emeth O. 以上来自于谷歌翻译 以下为原文 Hello Tren12, I was reviewing the issue that you have been facing and I would like to inform you Intel does not support Clonezilla due to the fact that it is a third party software. I would like to share with you a link from Clonezilla that may help you in order to figure out the root of this issue: https://drbl.org/faq/fine-print.php?path=./2_System/65_Clonezilla_support_RAID.faq#65_Clonezilla_support_RAID.faq On the other hand, if you install the operating system using a disk without the Clonezilla configuration does the server system recognize the disk? Best regards, Emeth O |
jerry1978 发表于 2018-10-17 12:29 我没有在系统盘上安装操作系统。 我能够启动并通过带有分区的“l***lk”看到磁盘,但我无法启动它。 磁盘不在BIOS中。 感谢您的信息:) 以上来自于谷歌翻译 以下为原文 I installed the operating system not on the system disk. I was able to boot and saw the disk through "l***lk" with partitions, but I can not boot from it. The disk is not in bios. Thank you for the information:) |
你好, 没问题,我很乐意帮助你。 然而; 由于Clonezilla是第三方工具,因此我们没有任何关于使用此工具可能产生的结果的文档。 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, No problem, It is my pleasure to assist you. However; Since Clonezilla is a third party tool and we do not have any documentation regarding the possible results from using this tool. Best regards, Emeth O |
只有小组成员才能发言,加入小组>>
496浏览 0评论
GMT+8, 2024-12-3 02:07 , Processed in 0.755027 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
